Oil leaking around lower intake?
Old January 9th, 2012, 10:40 PM   #1
Wax on, Wax off
Zatrekaz's Avatar
2003 Mustang V6
16.8@83.3
Zatrekaz has much to be proud ofZatrekaz has much to be proud ofZatrekaz has much to be proud ofZatrekaz has much to be proud ofZatrekaz has much to be proud ofZatrekaz has much to be proud ofZatrekaz has much to be proud ofZatrekaz has much to be proud ofZatrekaz has much to be proud of
iTrader: 15 reviews
Would this happen? I was looking at the engine and I can see a large accumilation of oil sepping from what looks like the lower intake gasket.
I would imagine no oil would even be in the lower intake... am I wrong?
Should I replace the gasket for the lower intake? If so... is this what I need? Felpro/Intake Manifold Gasket (MS95985) | 2003 Ford Mustang 6 Cylinders 4 3.8L SFI | AutoZone.com
Black Bullitt Rims FT/FS
Looking to Sell or Trade for Silver FR500s
Looking to buy a lot of 99-04 Interior Pieces
If you have any for sale, PM me
Old January 9th, 2012, 10:46 PM   #2
stephen has a spectacular aura aboutstephen has a spectacular aura about
Yes. Oil could leak from the lower intake manifold gasket. If you replace it be sure to put some RTV at the corners where the gaskets come together.
If the leak is around the front of the engine it could also be the front cover gasket.
Old January 9th, 2012, 10:49 PM   #3
Wax on, Wax off
Zatrekaz's Avatar
2003 Mustang V6
16.8@83.3
iTrader: 15 reviews
It is on the front. Should I go with the gasket I linked? Seems hella expensive for just a gasket.
Old January 9th, 2012, 11:10 PM   #4
mustangmike!'s Avatar
2004,1994,1967
14.37 @ 96
mustangmike! is a jewel in the roughmustangmike! is a jewel in the roughmustangmike! is a jewel in the rough
lower intake gaskets are not cheap, its a 4 peice kit, and you need some RTV with it. I love RTV used it on many gaskets in my car.
227whp N/A V6
Now w/ 8th Mile 8s !
How To Jmod Your Late Model 4R70W
Old January 9th, 2012, 11:11 PM   #5
2004,1994,1967
14.37 @ 96
Id go to a store for it in person, and not autozone, but thats jsut me. Bad experience w/ out autozone....
227whp N/A V6
Old January 10th, 2012, 03:11 AM   #6
Wax on, Wax off
Zatrekaz's Avatar
2003 Mustang V6
16.8@83.3
iTrader: 15 reviews
I started taking it apart tonight, but reilized I need a special tool to disconnect the fuel line. I also have to drain the coolant, which I JUST replaced. I did notice a lot of oil in the runners however. Is that normal? One of them had no oil... kinda odd.
I may wait a few to do this. I don't think its that big of a worry... right?
Old January 10th, 2012, 04:01 AM   #7
Very homosexually
str8chillng's Avatar
1998 Mustang BASE
17.3
str8chillng is on a distinguished road
Send a message via AIM to str8chillng
Here's the tool you'll need
OEM/5/16, 3/8, 1/2, 5/8, 3/4 and 7/8 in. A/C and fuel line disconnect tool set (25052) | Line Disconnect Tool | AutoZone.com
I’d be suspicious about the oil though.
Old January 10th, 2012, 04:09 AM   #8
Wax on, Wax off
Zatrekaz's Avatar
2003 Mustang V6
16.8@83.3
iTrader: 15 reviews
ya... I think I am gonna take one of the oil covered plugs to a shop and show them along with the info about the intake paths bein covered in oil and see what they tell me.
Wish I had a friend who lived near by that had done more internal work that me
Old January 10th, 2012, 09:21 AM   #9
2001 v6 premium
xtreme 2 will become famous soon enough
Send a message via AIM to xtreme 2 Send a message via MSN to xtreme 2 Send a message via Yahoo to xtreme 2
yea there is oil in the lifter valley that can seep up through the lower gasket if it's not sealing properly.
Don't disconnect the fuel line, just move the fuel rail to the side. Keeps you from dealing with the mess it makes.
Screw it, coming to play with the big boys...
5.4L Vortech COMING SOON!
Old January 10th, 2012, 10:57 AM   #10
Wax on, Wax off
Zatrekaz's Avatar
2003 Mustang V6
16.8@83.3
iTrader: 15 reviews
It looked like I had to remove the fuel injectors however. How can I do that without disconnecting the fuel?
Old January 10th, 2012, 11:25 AM   #11
2001 v6 premium
just pull slightly where the injectors seat in to the head. They are just held in with an o-ring. Pop them all off and then the fuel rail will come up as a complete unit.
There is enough fuel line that allows to lay it on the strut tower.
Threads Similar to: Oil leaking around lower intake?
leaking intake fastbike02 99-04 10 September 2nd, 2011 02:47 PM
Intake Manifold Swapped... AIR LEAKING? HELP bebo109 99-04 3 December 4th, 2010 02:45 PM
Well the intake manifold started leaking Nossit 99-04 0 June 2nd, 2010 01:12 PM
01 v6 lower intake leaking? white01stang V6 Mustangs 8 May 1st, 2008 08:05 PM
Need help using a 5.0 upper intake on a 5.8 lower intake Washington5.0 5.0 Mustangs 4 March 9th, 2007 01:54 AM
