need help
Old January 10th, 2012, 07:30 PM   #1
keyba's Avatar
1999 Mustang v6
16.2
keyba is on a distinguished road
Send a message via AIM to keyba
need help
ok i have a 99 mustang v6 with 238000 miles
now it runs fine
but lately it has been having a weird electrical problem lights dimming and all. Makes me think the alternator but now randomly just did it twice within a block the car and the entire electrical system just went completely blank. Everything shut off then next it all came back on like nothin happened.
The only other problem i have is that the odometer it goes in and out randomly as well idk if it could be an issue with the gauge cluster
much help would be appreciated
Old January 10th, 2012, 08:24 PM   #2
[{4114 K-73}]
Reaper_88's Avatar
2000 Mustang V6 Manual
Reaper_88 will become famous soon enoughReaper_88 will become famous soon enough
Go t your local auto parts store and have them test your alternator, that's what im thinking is the issue
BAMA-K&N-C&L-TI LLC-VAP Auto-Steeda-MAC-Thrush-Koni-H&R-Maximum Motorsports
WTB MAC Flow Path mufflers or Bassani mufflers PM me if you have a pair
Old January 10th, 2012, 08:28 PM   #3
keyba's Avatar
1999 Mustang v6
16.2
thats what i thought but it wouldn't make since. It restarted right away on its own but i am testing it at work tomorrow. Also kinda goig towards the pats system screwing up.
Old January 11th, 2012, 11:31 AM   #4
Tang Stang's Avatar
Tang Stang is just really niceTang Stang is just really niceTang Stang is just really niceTang Stang is just really nice
I'd inspect the ground cable and make certain it is getting a good connection at the engine block, as that tends to be overlooked.
Rod @ AzzKicker Cars
2004 Ford Mustang GT-The Driver-BBK CAI, PP TB & Inlet, Steeda UD's, SLP LM1, & 3.73's.
1990 Mercury Cougar XR7-The Meth Addict-5.0L DOHC Stroker w/2.1L KB SC.
1995 Ford F150-Mud Toy-5.0L, 4x4, 33's, & Warn 8274 Winch
Old January 11th, 2012, 11:37 AM   #5
2001 v6 premium
xtreme 2 will become famous soon enough
Send a message via AIM to xtreme 2 Send a message via MSN to xtreme 2 Send a message via Yahoo to xtreme 2
I was gonna say, check the grounds. Sounds like something is loose.
Screw it, coming to play with the big boys...
5.4L Vortech COMING SOON!
Old January 11th, 2012, 08:55 PM   #6
keyba's Avatar
1999 Mustang v6
16.2
well the grounds where all tight the battery one was a little loose. They are look very worn I'm wondering about corrosion i am going to replace them and see what happens
Old January 12th, 2012, 01:47 PM   #7
2001 v6 premium
corrosion could be the key. A pretty simple fix if that's it. I've seen a lot of times where a car won't start because of corroded battery cables.
Old January 12th, 2012, 02:02 PM   #8
WhiteShadow's Avatar
2001 Mustang V6
WhiteShadow will become famous soon enoughWhiteShadow will become famous soon enough
Send a message via AIM to WhiteShadow
+1 to this. used to happen all the time in my dads old suburban. finally got new cables
Whiteshadow build Thread
Updated 4/10/2012
Divorced Dual Borla Stinger Exhaust Catback Video
