2002 Mustang V6
Rear end has lots of movement around corners?
Ok, so at first this never bothered me.. but its been progressively getting worse. When i take corners, if there is even the slightest bump, the back of my car will sway pretty bad side to side. I put new shocks on the back hoping it would hide some of it, but nothing. Any ideas?
2002 Mustang V6, GT Rims, Cold Air intake, Blue LED interior.
Have you checked your control arm bushings? With the car on jackstands and the rear axle hanging freely, can you move the axle side to side?
Rod @ AzzKicker Cars 2004 Ford Mustang GT-The Driver-BBK CAI, PP TB & Inlet, Steeda UD's, SLP LM1, & 3.73's. ![]() 1990 Mercury Cougar XR7-The Meth Addict-5.0L DOHC Stroker w/2.1L KB SC. ![]() 1995 Ford F150-Mud Toy-5.0L, 4x4, 33's, & Warn 8274 Winch |
2002 Mustang V6
not sure, i have noticed though when its jacked up. the driver side tire stays higher then my right side tire. when its on the ground the back sags to the left side about an inch.. i measured it, and its definitely not right
1999 V6 Mustang
Putting a rear swaybar on my car and locking the two lower control arms together eliminated the tail wagging session your talking about, unfortunately due to how soft the stock rubber bushings are a swaybar actually does help keep the axle centered, or at least provides some resistance to dampen the movements when the axle moves off center. New bushings will help to fix this problem and are the more correct way to do it but then your really talking about new control arms which can get pretty expensive.
2002 Mustang V6
hmm.. alright, thanks a ton guys, im looking into it right now.
2001 v6 premium
yup, look at the upper and lower control arm bushings and check for tears or cracks. Also, ensure that the bolts are tight.
Do you have a sway bar yet?
![]() Screw it, coming to play with the big boys... 5.4L Vortech COMING SOON! |
2002 Mustang V6
no sway bar
looking to see if i can get one off of a wreck or junkyard.
2001 v6 premium
just go to a used car lot. take a 14mm wrench and a 15mm socket...
are your back wheels on tight?....i know it sounds silly, but i've lost a wheel on the hwy due to that bump feeling and not double checking....the bump feeling lasted for a few days until it finally flew off
Priest of the Car Gods
While you might have something exacerbating it, the ass-waggle is inherent in the 4-link. Even when it's "tight", the rear axle can shift an inch either direction under load.
If your UCA bushings are shot you'll notice it more, but to fix it you need to either go to spherically-bushed UCAs or install a panhard bar or watt's link.
I wonder if it just axle steer from the lateral movement axle. A pan hard bar can fix that.
![]() Sig by Tricep |
the rear bumper needed to be heated back into shape...needed paint....i had to replace the rotor and all the studs...and after that i started getting paranoid about every little bump in the road...
hell i still am a little lol...i check my lugs at least once a week now...i know they're good, but it makes me feel better 100% knowing
Skar Gone
1998 Mustang V6
17.27@76.66
Which car threw a wheel sixxer? o.O
![]() 1998 5 Speed, CAI, Exhaust, Rear Seat Delete. |
2001 v6 premium
I would have gotten them to pay a lot more than that....
14.37 @ 96
I have a how to put on a sway bar thread on the first page as we speak ...
94-95 V6's have them and idk what all years GT's have them... Same size though I think. 30$ and 15 mins of your time. |
2001 v6 premium
size differs depending on year. Can come off a GT, Mach 1, or Cobra.
14.37 @ 96
Bigger better
2001 v6 premium
Cobra is biggest, but it also has the tendency to break at the welds. Never knew why...
Threads Similar to: Rear end has lots of movement around corners?
| clear corners or smoked corners? | blackGTstang | 2005 - 2010 | 12 | August 16th, 2010 04:06 PM |
| Rear end movement??? | Hawaiianbro | 99-04 | 8 | May 21st, 2009 09:03 PM |
| rear suspension movement | ia07gt | 2005 - 2010 | 20 | October 28th, 2008 09:46 AM |
| amber corners or clear corners | Badasstang281 | 99-04 | 5 | February 11th, 2007 05:02 AM |
