2004 Mustang V6
Need Help!!!!
ok so i just finished up the cam swap i bought comp cams 44-704-9 cam, springs and retainers....the car tried to start 2 times and cranked really slow then all of a sudden it started cranking normal.. the car runs and revs fine but no aggressive idle at all (sounds almost stock). my rocker arms have alot of lash in them, how can i adjust them?
2004 Mustang V6
also installed new lifters
14.37 @ 96
by installing correctly and having correctly sized pushrods
2004 Mustang V6
what should the clearence be between the rocker arm and pushrod?
2001 v6 premium
have you shimmed at all?
http://www.supersixmotorsports.com/p...PakInstall.pdf skip to the section about setting the rockers.
![]() Screw it, coming to play with the big boys... 5.4L Vortech COMING SOON! |
2004 Mustang V6
no, im new to the pedistal mount rocker arms.
14.37 @ 96
new lifters huh ? Maybe the new lifters aren't expanded all the way ? hydrolic w/o pressure inside wont be expanded? < any1 feel free to chime in on that, Ive never had "new" lifters.
But FYI, Once the rocker arm is in place while that cylinder is in TDC on the compression stroke, the valves should be completely closed. And at that point, their should be NO slack between the rocker arm, pushrod, and lifter. If any movement you MIGHT can spin it with your fingers ... maybe. But NO up and down play. This is where you should have a pushrod length tester tool. @ compression TDC, and the lifter on the base circle of the cam lobe, you would instert this tool and expand until no slack. At that point you must not let the tool contract or expand. remove rocker, pull the tool out. Measure down to the .005 of an inch. If this does not match the size of your pushrods, then you need to order the correct size. |
2001 v6 premium
yea sounds like you need shims. Read up on that article then do some shimming.
#9 | |
2001 v6 premium
14.37 @ 96
I have my stupid moments lol I was like wtf did he spell there, looked back and seen where you got it
![]() Atleast the info was good
2001 v6 premium
it's alright, I already knew the medical profession was full of crack jobs...
2004 Mustang V6
how long would it take the lifters to pump up if that is the problem? do i need to run the engine at 2000rpm for a certain amount of time?
2001 v6 premium
generally I soak them in oil before putting them in so that they become saturated and expand.
#14 | |
14.37 @ 96
your "supposed to" some say. BUTTTT I never did ![]() Also you can rig up a way to turn the oil pump w/ a drill if you want to prime the pump. Its the last thing I did basicaly on my build. Primed it, put the cps in. Intake tube, wiring. Start. |
2004 Mustang V6
i let them soak over night and could still push down on the plunger with my finger, it would move but not much
14.37 @ 96
oh yuck 0_o
Well google some info on use of brand new lifters ... or call the company you ordered them from and ask them what to do. |
2001 v6 premium
yea I dunno. I just re-use mine unless I notice a problem.
Do you still have the stockers?
2004 Mustang V6
yea i shure do but the only problem is i have already put the motor back together...
14.37 @ 96
Obviously it needs to come back apart
14.37 @ 96
