96 mustang 3.8
Old January 13th, 2012, 01:28 PM   #1
96 3.8
1996 mustang 3.8
Nate3.8 is on a distinguished road
96 mustang 3.8
i am still having the same issue with my 96 3.8 mustang. having hesitation issues and car will not acclerate at all i can floor it and it will sputter.at times will stall out a 55 mph. also i can ride at 2200 rpm and will run ok on highway but push to WOT and will bog down.
I have now changed plugs, cam sensor, cranksensor, tps, fuel pump and filter, computer, MAF.
Cats have been removed has dual exhaust. (car ran great after exhaust and cat removal for about a month.)
have cleaned IAC and throttle body.
Please need help even ford dealer has givin up they put computer and MAF on and didnt fix.
Old January 13th, 2012, 01:37 PM   #2
2001 v6 premium
xtreme 2 will become famous soon enough
Send a message via AIM to xtreme 2 Send a message via MSN to xtreme 2 Send a message via Yahoo to xtreme 2
didn't see any mention of O2 sensors. Have you checked them?
Have you by chance check your a/f ratio?
Do you have a handheld tuner? Checking your short term fuel trims would be a good notation.
1.) Start the car with the tuner plugged in.
2.) Go to Datalog and select to view your short term fuel trims (the abbreviations are different depending on the tuner)
3.) Watch the variance of the trims at idle for 10 seconds.
4.) 1500 rpm for 10 seconds.
5.) 2000 rpm for 10 seconds.
6.) 2500 rpm for 10 seconds.
7.) 3000 rpm for 10 seconds.
How do they look? At each point they should not vary from 0 much. On a diablosport they should stay between +-3%. On an SCT I believe it should stay between +-1.5.
How is your fuel pressure?
Screw it, coming to play with the big boys...
5.4L Vortech COMING SOON!
Old January 13th, 2012, 02:10 PM   #3
96 3.8
1996 mustang 3.8
fuel pressure is good. dont have a tuner but have a OTC scanner that can run datastream.
yeah i show have a b1s1 bad O2 will be getting one today. just didnt think that the O2 would make it run as bad as it does.
Old January 13th, 2012, 02:16 PM   #4
mustangmike!'s Avatar
2004,1994,1967
14.37 @ 96
mustangmike! is a jewel in the roughmustangmike! is a jewel in the roughmustangmike! is a jewel in the rough
check vacuum hoses ?
227whp N/A V6
Now w/ 8th Mile 8s !
How To Jmod Your Late Model 4R70W
Old January 13th, 2012, 02:19 PM   #5
2001 v6 premium
totally will... O2 sensor controls your A/F. Get that fixed and reset the computer to see if it fixes.
Old January 13th, 2012, 02:44 PM   #6
2004,1994,1967
14.37 @ 96
This is true, but surely not that bad would it ? Never seen an O2 cause that big of a problem but hey you never know I guess
227whp N/A V6
Old January 13th, 2012, 02:47 PM   #7
2001 v6 premium
mine bogged like ass on WOT accelleration.
If you think only one is bad, swap the O2s and see if the problem jumps to the other bank. Generally it's the passenger side that goes bad first.
Old January 13th, 2012, 02:54 PM   #8
2004,1994,1967
14.37 @ 96
Yup and I wonder if that AC issue contributes to that at all lol
227whp N/A V6
Old January 13th, 2012, 02:58 PM   #9
2001 v6 premium
which AC issue?
Old January 13th, 2012, 03:03 PM   #10
2004,1994,1967
14.37 @ 96
dripping on the manifold
227whp N/A V6
Old January 13th, 2012, 03:06 PM   #11
2001 v6 premium
oh I'm sure it does. had mine bust on me last summer...
Old January 13th, 2012, 04:34 PM   #12
mustang227's Avatar
mustang227 is on a distinguished road
You might have an air leak somewhere. Check all over your intake past the MAF. Also check the vacuum hoses like mustangmike! said.
UDP, Cai, MAC LT's, Divorced duals with original 40's, Predator performance tune
Old January 13th, 2012, 08:14 PM   #13
96 3.8
1996 mustang 3.8
I have replaced about ever vaccum hose. But yeah its throwing an O2 code and to lean code for that bank.
Old January 17th, 2012, 12:48 PM   #14
96 3.8
1996 mustang 3.8
finally got it fixed. Passenger side upper O2 sensor was the issue. i couldnt get it out of the manifold. so i had to get a new O2 bung and weld a new on in. but runs so much better. i am going to change the driver side soon just to avoid this issue again.
Threads Similar to: 96 mustang 3.8
Fastlane Motorsports Mustang Hits Wall at Mustang Week Video gtjohnny The Clubhouse 13 July 24th, 2011 09:25 PM
Gateway Classic Mustang to produce limited edition Steve McQueen Mustang PsyAbe The Clubhouse 4 March 21st, 2011 02:49 AM
iRacing.com Launches Virtual Mustang Cup with Ford Racing Mustang Challenge FR500S AutoGuide.com The Clubhouse 11 July 8th, 2010 01:00 PM
Live Broadcast at 5:30 PM Central: Mustang Stories Contest Winner Gets His Mustang unlicensed to drive The Clubhouse 30 July 7th, 2009 09:03 PM
MOFO Production-Turbo 5.4 Stang-600HP Mustang GT-408w mustang-Ported Blower Cobra!! mofobucs Multimedia 24 August 20th, 2008 01:19 PM
