2003 v6
![]() iTrader: 2 reviews
Sputter when coming to a stop
Hey Guys, I recently noticed my car sputtering when i come to a stop... it doesn't do this all the time but it will do it a lot more often if I have my heater on. RPMs drop a decent amount but not enough to cause the car to stall. Anyone know what might be causing this? I'm getting my battery and alternator checked out right after work.
2003 v6
Is there a specific cleaner i should buy? I'm stopping at advanced auto on my way back from work and will pick some up.
Also I have a good feeling its the battery since a couple months ago i had to replace the alternator.
2001 v6 premium
nah battery wouldn't cause that. Once you start the car, the battery has no effect on the engine. You can disconnect the battery and drive around forever.
If you belt is slipping you could have those symptoms though.
![]() Screw it, coming to play with the big boys... 5.4L Vortech COMING SOON! |
2003 v6
Gotcha, thanks for the help ill be sure to check into all the things mentioned above.
2004 Mustang V6
Idk about that, you cars battery does a lot more than just start the engine.
iPoopke Regular
2004 Mustang
Take your alternator up to local autostore and get a diagnostic ran on it
2001 v6 premium
Not for the engine. All engine controls are run off the alternator. Your stereo, gauges, etc. won't work if you pull the battery connection, but the engine will not die. Fuel injectors, spark, etc. is all run by the alternator once the car starts.
2003 v6
Got it fixed, it was carbon build up in the throttle body. Thanks for the pointers guys. Car feels a lot cleaner/healthier at start up and when its running.
The soul stealing Ginger
f i was taught correctly the battery keeps all that excess voltage from the alternator from reaching other electronics so it actually does have a purpose after the car has been started.
Congrats OP. takes me alot longer to find my problems on the car lol
2001 v6 premium
hmm, so some throttle body cleaner fixed your issue... was the throttle plate sticking open just a little?
2000 3.8L v6
when i finished track was closed
my car recently did this too. it sputtered for a good 3 months or so and i never thought anything of it until one day it wouldnt start anymore. turns out it was my fuel pump. i tryed cleaning all the sensors that everyone suggested, my advice would be clean all the sensors and if it persists check your fuel pressure
Threads Similar to: Sputter when coming to a stop
| Spit sputter sputter pop, ignition timing WTF? | the_Chad | 5.0 Mustangs | 4 | November 30th, 2011 01:40 AM |
| stalling when coming to a stop | 00MustangGtPremium | 99-04 | 32 | August 11th, 2011 10:16 PM |
| car dies when coming to a stop | bullitt ak | 99-04 | 16 | January 26th, 2011 07:20 AM |
| What is this country coming to? You cant stop the desecration of the flag? | 03_StangGuy | Politics | 31 | August 20th, 2010 01:41 PM |
| car stalls when coming to a stop | joseph296 | 5.0 Mustangs | 25 | October 20th, 2009 10:04 PM |
