Running Lean
Old January 18th, 2012, 06:08 PM   #1
94 Mustang 3.8
Huff94 is on a distinguished road
Running Lean
Everything was running good until a few days after changing my airfilter to a K&N filter. Now im getting a code that im running lean. Any ideas?
Old January 18th, 2012, 06:32 PM   #2
94 Mustang 3.8
I put a new fuel filter,crank/cam sensor,maf,and plugs. It is acting very sluggish. also have Accel Coil pack
Old January 19th, 2012, 10:00 AM   #3
2001 v6 premium
xtreme 2 will become famous soon enough
Send a message via AIM to xtreme 2 Send a message via MSN to xtreme 2 Send a message via Yahoo to xtreme 2
can't see a filter change causing those problems.
describe sluggish? there is v6 engine sluggish, then there is problematic sluggish, LOL
Screw it, coming to play with the big boys...
5.4L Vortech COMING SOON!
Old January 19th, 2012, 11:08 AM   #4
MM's king of Neon's
WickedSnake00's Avatar
404 - car not found
17.81@87
WickedSnake00 has much to be proud ofWickedSnake00 has much to be proud ofWickedSnake00 has much to be proud ofWickedSnake00 has much to be proud ofWickedSnake00 has much to be proud ofWickedSnake00 has much to be proud ofWickedSnake00 has much to be proud ofWickedSnake00 has much to be proud of
Just some random thoughts for possibilities-
Did you modify anything that may be causing a vacuum leak when you installed your filter and MAF? Maybe the MAF isn't installed properly?
Is is the correct MAF?
A MAF with the wrong transfer function can cause you to run lean.
Official Secondhand Snake Build Thread Here
Looks Like a Cobra, Sounds Like a Cobra, Tastes Like a Cobra, Not a Cobra.
For Sale: P71 Interceptor motor
Old January 19th, 2012, 11:19 AM   #5
2001 v6 premium
that's true. If it's calibrated for a different injector setup it will throw you off.
Same if you forgot to plug the IAT back in or anything of the sort.
Any CELs?
Old January 19th, 2012, 07:19 PM   #6
94 Mustang 3.8
no i didnt mess with the MAF or anything when i swaped to the K&N filter. I just opened the box took the old filter out put the new one in. I just took the MAF out and cleaned it with the MAF cleaner. still running lean.
Old January 19th, 2012, 07:28 PM   #7
94 Mustang 3.8
sluggish as in problematic. once its going there is power but trying to get it going is like im trying to take off in 2nd. a few of my sparkplugs are black and sooty
Old January 19th, 2012, 07:36 PM   #8
MM's king of Neon's
404 - car not found
17.81@87
Well you also said you changed MAF's. Is it the correct P/N? An incorrect transfer function can cause you to run lean, as well as unmetered air, aka a vacuum leak. Take a look at those.
Old January 19th, 2012, 07:44 PM   #9
94 Mustang 3.8
i changed the maf a few months back so i was just guessing that it wouldnt be a bad maf now..when i start the car up cold it boggs down and some smoke comes out the pipes for a min then its all good.
Old January 20th, 2012, 10:09 AM   #10
96 3.8
1996 mustang 3.8
Nate3.8 is on a distinguished road
mine was doing the same thing was passenger side upper o2 sensor. now runs good
Old January 20th, 2012, 12:12 PM   #11
94 Mustang 3.8
yeah thats what im thinking im going to have to change.. im going to take it to autozone to have them read it again to see if its still running lean. see if cleaning the MAF fixed it or not
Old January 20th, 2012, 02:08 PM   #12
2001 v6 premium
what is the exact code you are getting?
which side are the spark plugs messed up on?
Old January 20th, 2012, 07:39 PM   #13
94 Mustang 3.8
i changed back to the stock airfilter and drove 70miles and no code came up. now i just changed back to the K&N . im going to see if it starts running lean again
Old January 20th, 2012, 07:59 PM   #14
94 v6 mustang
Puffy93 is on a distinguished road
try disconnecting your battery for a couple of minutes to reset the computer, the computer is used to the air flow from the stock filter and the increased flow from the K&N is confusing it and making it think its going lean.
94 mustang 3.8
Steeda Tri-ax, FRPP aluminum driveshaft. Soon to get built 351W
Old January 20th, 2012, 08:07 PM   #15
94 Mustang 3.8
i did every time i swapped it out..thats why i dont under stand why it says its lean every time i put the K&N in
Old January 20th, 2012, 08:27 PM   #16
94 Mustang 3.8
i took out my spark plugs and a few of them are indicating that that cylinder is running lean. im starting to think that all of my problems are coming from some bad injectors. what do you think
Old January 20th, 2012, 08:38 PM   #17
94 v6 mustang
Try starting the engine and spray the area you worked on down with carb cleaner or starter fluid around the area you worked on, if the idle raises then there is a vacuum leak there causing you to go lean. i would do this before you start replacing injectors.
94 mustang 3.8
Old January 20th, 2012, 09:28 PM   #18
94 Mustang 3.8
will try it
accel coil pack,K&N airfilter,divorce exhaust dumped before rear axle
Old January 20th, 2012, 09:41 PM   #19
MM's king of Neon's
404 - car not found
17.81@87
Yup. Check the major ones before you go replacing injectors.
Check for vacuum leaks, check that your MAF is correct, and test your oxygen sensors.
Old January 20th, 2012, 10:09 PM   #20
94 Mustang 3.8
whats the best way to test the o2's
Threads Similar to: Running Lean
running lean. daschaffa17 2005 - 2010 11 April 22nd, 2009 11:55 AM
My car is running lean again ByPopularDemand V6 Mustangs 5 March 9th, 2009 09:53 PM
car running to lean Wiley V6 Mustangs 7 September 12th, 2008 12:26 PM
Car keeps running lean nicklo 5.0 Mustangs 8 January 29th, 2008 11:50 PM
running lean 91cobra5.0 5.0 Mustangs 26 January 24th, 2008 09:59 PM
