Thermostat Housing gasket?
Old January 18th, 2012, 10:31 PM   #1
2005 Mustang V6
cmay is on a distinguished road
So, my Mustang overheated yesterday(05' V6). I smelled burning coolant but didn't notice an obvious leak. Today I searched again while she ran and again couldn't find a leak.. until.. I turned the engine off and noticed a hissing coming from (what I think is) the thermostat housing. I noticed coolant bubbling out of the crack that separates the top and bottom housing pieces. My question is A) Is this in fact the thermostat housing (black, plastic, top and bottom piece joined by a few bolts and what appears to have been a gasket or rubber seal. Has a hose going to the top of it). And B) To fix this apparent leak, do I just swap out the gasket or do I need to replace the whole unit? Thanks for the help. I don't know jack sh*t about cars but I figure this is a good way to learn.
Old January 19th, 2012, 11:31 AM   #2
2001 v6 premium
xtreme 2 will become famous soon enough
Send a message via AIM to xtreme 2 Send a message via MSN to xtreme 2 Send a message via Yahoo to xtreme 2
Better steal some intellectual property while I still can.
All the thermostat housing is is the connector where the top radiator hose connects to. Just a metal connector with 2 bolts.
Can you get a picture (or mark this image) to show where your leak it coming from? It almost seems like the leak you are talking about is where the lower manifold meets the block.
Screw it, coming to play with the big boys...
5.4L Vortech COMING SOON!
Old January 19th, 2012, 02:26 PM   #3
2005 Mustang V6
Here's a few pictures with some arrows pointing to the part in question/ where the coolant is coming out of.
Old January 19th, 2012, 02:36 PM   #4
2005 Mustang V6
Best picture of part in question...
Top view of engine for reference..
Old January 19th, 2012, 02:56 PM   #5
2001 v6 premium
can't view those, I'm at work :*(
Old January 19th, 2012, 09:08 PM   #6
2005 Mustang V6
So I checked again today to see if the coolant was bubbling out of the same spot..and it wasn't... so I'm either out of coolant or it doesn't do it all the time.
Old January 19th, 2012, 10:49 PM   #7
2001 v6 premium
have you checked your coolant levels?
BTW, just realized you have a 2005. there is a specific section for that, this is the 99-04 section. just saying so you may be able to get the proper knowledge from the people that know your engine. ;-)
Old January 20th, 2012, 06:43 AM   #8
2005 Mustang V6
Oh, damn sorry about that haha
Old January 20th, 2012, 08:45 AM   #9
stephen has a spectacular aura aboutstephen has a spectacular aura about
You should fill up the coolant and bleed the cooling system then put a pressure tester on it. If it's an external leak that will show it.
Old January 20th, 2012, 08:47 AM   #10
2001 v6 premium
no issues. Check your coolant level and report back.
Wherever it's bubbling, I would assume the gasket is bad and needs to be replaced. Change the gasket before refilling the coolant so you don't have to do it twice
Old January 20th, 2012, 08:47 AM   #11
BTW, Your car is a 2005 which looks quite different form the earlier 3.8 L V6.
Old January 20th, 2012, 08:03 PM   #12
94 v6 mustang
Puffy93 is on a distinguished road
either your gasket or housing is bad, unfortunately the ford 4.0 is notorious for cracking that lower housing so that may be your problem.
94 mustang 3.8
Steeda Tri-ax, FRPP aluminum driveshaft. Soon to get built 351W
Threads Similar to: Thermostat Housing gasket?
Question About Thermostat Housing Gasket Dan_T_Mustang 94-95 7 December 29th, 2011 10:22 PM
Crack going down thermostat housing TheOdessa 99-04 27 July 9th, 2011 08:58 PM
Thermostat housing question '99 GT sillyrabbit0420 99-04 12 April 28th, 2011 04:00 AM
HELP with thermostat housing 01 blue bullitt 99-04 9 December 13th, 2008 12:52 PM
Chrome Thermostat housing. jrfan4life 99-04 9 April 17th, 2007 05:37 AM
