Hood latch issue
Old January 21st, 2012, 02:04 PM   #1
mrTr0ut is on a distinguished road
Hood latch issue
First time poster with V6 2002 mustang...
My problem seems to be pretty common, I've searched this forum and many others but none of the solutions seem to be working.
Basically, pulling the hood release handle inside the car pulls the cable at the latch but doesn't release anything. I've had someone else pull the lever while I pull up/down on the hood and that doesn't do anything. I've gotten under the car, stuck my arm up around the cable and tried pulling on it as hard as I could with my hand/tools and nothing.
I really am not sure what to do at this point...can I pry up the yellow release handle under the hood somehow??
Thanks in advance.
Old January 21st, 2012, 03:18 PM   #2
Green_6er's Avatar
2000 Mustang 3.8
ehh w/e the mostly stock time is
Green_6er has a spectacular aura aboutGreen_6er has a spectacular aura aboutGreen_6er has a spectacular aura about
really long piece of rod?
Originally Posted by 6ER THEN I 8ER! View Post
If you don't scrape you did it wrong
Diablo-Eibach-Pacesetter-Flowsound-MGW-BBK
How to paint your rims:
http://www.moddedmustangs.com/forums...ml#post3931042
Old January 21st, 2012, 04:41 PM   #3
Skar Gone
Skargon's Avatar
1998 Mustang V6
17.27@76.66
Skargon will become famous soon enoughSkargon will become famous soon enough
Well if you cant fix the problem, Do what I did..
use a Flathead screwdriver, But chances are you have a Grill so you wont be able to access the hook to pull it.. I would see if it's frozen shut or if the Pull handle inside the car is actually attached to anything, etc.
1998 5 Speed, CAI, Exhaust, Rear Seat Delete.
Old January 21st, 2012, 08:44 PM   #4
I was able to spray WD40 from under the car and threw the grille and after pressing down on the hood, while the lever was pulled it finally popped opened. I soaked it in WD40 now, it was pretty rusted and i did that washer mod I seen that props the latch up some so it doesn't jam.
Works so far
I'll post a new thread for my real issue now that I finally got the hood open
Threads Similar to: Hood latch issue
Aftermarket fiberglass hood. Hood pins or factory hood latch??? Saleen0101 Modular Mustangs 11 November 9th, 2011 04:09 PM
Hood latch broke w/ hood shut..now what! mrjucs 96-98 3 April 29th, 2011 02:44 PM
hood latch keeps failing... other alternative than hood pins? R3dFyre02 99-04 2 June 12th, 2010 04:41 PM
Carbonwire Cobra R Hood latch issue BBMUSTANG V6 Mustangs 16 January 30th, 2010 02:24 AM
Hood latch kit? ma67cpe Classic Mustangs 8 December 8th, 2008 03:12 PM
