Flickering headlights \ Car Sputters
Old January 21st, 2012, 08:56 PM   #1
mrTr0ut is on a distinguished road
I posted earlier today about the hood latch issue and got that resolved..so here's my real issue, now that I got my hood opened: (2002, v6 mustang)
While the car is on or off, doesn't matter,the headlights will flicker then eventually go stable. While the car is on, the car will sputter a bit from time to time then followed by the headlights flickering. This just started happening in the past 2 days.
So...I took the car to advance auto parts to test the battery and alternator, they showed, and printed out, a report showing the alternator to be good and the battery to only be outputting half of what it should be. Dead cells and whatnot. They said the sputtering could be the alternator trying to compensate for the battery and could be bringing the engine down to do so..or something like that. They advised me to take it to auto zone, since I may have a warranty left on the battery.
I get to auto zone and they bring out their test kit and show me a single screen that says the battery is "98% charged" and then test the alternator and claim it failed. And wanted me to buy an alternator right on the spot.
Then after talking to some other people, they believe I may have a bad ground directly related to my headlights.
I'm really not sure who to believe, and unfortunately, don't have much experience or knowledge with cars in this fashion. I'm hoping someone here can point me in the right direction, thanks!
Old January 21st, 2012, 09:48 PM   #2
Very homosexually
str8chillng's Avatar
1998 Mustang BASE
17.3
str8chillng is on a distinguished road
Send a message via AIM to str8chillng
Could be bad alternator. I was throwing codes for a malfuctioned CPS but strangly when I replaced the alternator things went back to normal operation except for that P0420 code the PCM keeps throwing out. But for the light flickering, just check your ground wire.
Old January 22nd, 2012, 02:32 AM   #3
Green_6er's Avatar
2000 Mustang 3.8
ehh w/e the mostly stock time is
Green_6er has a spectacular aura aboutGreen_6er has a spectacular aura aboutGreen_6er has a spectacular aura about
alternators are a common problem on these cars, so could very possibly be your alternator.
Originally Posted by 6ER THEN I 8ER! View Post
If you don't scrape you did it wrong
Diablo-Eibach-Pacesetter-Flowsound-MGW-BBK
How to paint your rims:
http://www.moddedmustangs.com/forums...ml#post3931042
Old January 22nd, 2012, 08:39 AM   #4
I'm gonna take it to a third store and have them test the alternator and see what they say.
Old January 23rd, 2012, 12:57 AM   #5
I haven't had the alternator tested/replaced yet I'll probably do that tomorrow. But I was wondering where I can look up information/pictures of where to find the headlight grounds? I'm really not too knowledgeable about electrical wiring but I think I could at least take a look if I knew where to start...(I checked google)
Thanks!
Old January 23rd, 2012, 12:58 AM   #6
Shelby's Minion
RZNCAIN's Avatar
2007 Mustang Shelby GT
(Mach1) Sept. '10 ROTM
RZNCAIN has much to be proud ofRZNCAIN has much to be proud ofRZNCAIN has much to be proud ofRZNCAIN has much to be proud ofRZNCAIN has much to be proud ofRZNCAIN has much to be proud ofRZNCAIN has much to be proud ofRZNCAIN has much to be proud ofRZNCAIN has much to be proud ofRZNCAIN has much to be proud of
I was gonna saw bad alternator.
Sponsored by Specialty Coatings
Car Salesman Club- Founder
2007 Shelby GT- Hardparked
2003 Mach 1- Hardparked
1988 LX 5.0- Umm...Driver?
Old January 23rd, 2012, 01:00 AM   #7
Not Banned
southfour!'s Avatar
2000 Mustang V6
2000 Silverado 1500
southfour! is a glorious beacon of lightsouthfour! is a glorious beacon of lightsouthfour! is a glorious beacon of lightsouthfour! is a glorious beacon of lightsouthfour! is a glorious beacon of lightsouthfour! is a glorious beacon of light
Send a message via AIM to southfour! Send a message via MSN to southfour!
cutting off the bad alt wont solve his problems
H/C/I V6
BMC Member: 12521
Old January 23rd, 2012, 01:01 AM   #8
[{4114 K-73}]
Reaper_88's Avatar
2000 Mustang V6 Manual
Reaper_88 will become famous soon enoughReaper_88 will become famous soon enough
BAMA-K&N-C&L-TI LLC-VAP Auto-Steeda-MAC-Thrush-Koni-H&R-Maximum Motorsports
WTB MAC Flow Path mufflers or Bassani mufflers PM me if you have a pair
Old January 23rd, 2012, 01:16 AM   #9
Shelby's Minion
RZNCAIN's Avatar
Old January 23rd, 2012, 11:16 PM   #10
eleanorGT's Avatar
2001 Mustang 3.8
eleanorGT will become famous soon enough
HAhaha.. I havnt had mine checked, and i have over 100K, and its stock, for a fact.. could solve my sputtering issues to
Old January 23rd, 2012, 11:20 PM   #11
Shelby's Minion
RZNCAIN's Avatar
I think we all want to know. Did you cut that fucker off yet!
Old January 24th, 2012, 10:40 PM   #12
Very homosexually
1998 Mustang BASE
17.3
I had major sputtering issues before I replaced my alternator, also backfiring aswell as codes being thrown. Since I had replaced it, it runs at a consistant 14.8 volts. Old one was running at 11.9-12.3 volts.
Old January 24th, 2012, 11:27 PM   #13
Zoolander
04 Cobra #2260/3768 1/820
iTrader: 5 reviews
I would say the alternator. The whole story of it compensating for your battery when your car is on is ridiculous. When your car is not on your car should be putting out 14-15 volts. When the car is on and the alternator is running correctly the volts should drop to around 9ish volts. The alternator is a small generator that runs to run your accessories instead of your battery, and also recharges your battery while you drive.
MM Cobra Club #18
Team Tini Racing
I don't know jack shit...
Old January 26th, 2012, 02:45 AM   #14
Matt.'s Avatar
2002 Nitrous Injected V6
12's?
Matt. is a jewel in the roughMatt. is a jewel in the roughMatt. is a jewel in the roughMatt. is a jewel in the rough
Tighten all your grounds, a good thing to check.
Project Red Magic
-Full Intake, Full Exhuast,Geared, Tune, Sprayed, Dropped-
-18 Inch Hypercoated Saleens wrapped in Nittos-
Old January 26th, 2012, 04:01 AM   #15
iPoopke Regular
2004 Mustang
iPAPKE will become famous soon enoughiPAPKE will become famous soon enough
I'd say alternator, had same issue. Fixed with replacement.
Old January 27th, 2012, 10:01 AM   #16
Zoolander
iTrader: 5 reviews
Another thing to think about is if you do replace your alternator is you may want to get your old one rebuilt for just in case.
MM Cobra Club #18
Team Tini Racing
Threads Similar to: Flickering headlights \ Car Sputters
Flickering lights? black88 5.0 Mustangs 2 October 12th, 2011 12:40 PM
headlights flickering Truth223 99-04 7 July 11th, 2011 02:42 PM
HID Headlights Flickering buddyantunez1 99-04 13 June 18th, 2010 03:29 PM
HID flickering when car is off Saleen0101 99-04 8 October 7th, 2009 03:14 AM
Car sputters when hot. dr.gonzo! 5.0 Mustangs 5 August 17th, 2007 02:57 PM
