2001 Mustang V6
low on oil problem
so i decided to check the oil in my car the other day and it was a whole 2 1/2 quarts low. it had an oil change probable around 1000 miles ago. ne idea on why it would be this low. im just glad i checked it when i did. im gonna have to keep an eye on it until i figure out the problem
on another note has anybody ever thought about swapping out their v6 with a 351? i just came into a free truck with a 351 in it and i dont plan on doing a swap but the question did cross my mind if it would even be possible. lol |
14.37 @ 96
do you have a leak, or are you buring oil that you know of ?
Was it filled completely ;p And yes anything is possible with enough money. Drive that truck down to texas and leave it with me, I need a 351 for my 67 |
2001 Mustang V6
Every once in awhile it smells like hot oil inside the car
14.37 @ 96
odd
2002 Ford Mustang
It's pretty common to smell hot oil when your valve covers are leaking onto the manifolds and burning off, rear main seal leak, cylinder head rears leaks, etc. Oil must be leaking onto the exhaust somewhere to be smelling it. But 2-1/2 quarts in 1000 miles is quite a bit of oil.
Jeff city huh? You never hang out in the walmart/target parking lots do you? Word is thats the place to be on weekend nights.
![]() K&N CAI, MSD Wires, MAC L/T's, MAC O/R H-Pipe, Super 44's, MGW Shifter, SPEC Aluminum Flywheel, RAM HDX Clutch, FRPP Aluminum Driveshaft, 4.10's, Trac-Lok, Mach 1 17's, Nitto NT555 275's & 315's! Need Mustang help in MO? PM me! |
#6 | |
14.37 @ 96
#7 | |
2001 Mustang V6
04 Stang 1.0Gallon V6
14.45 @95.8
![]() ![]() iTrader: 2 reviews
Very important question. its the car leaking oil or burning oil
Burning- valve seals, head gasket Leaking- rear main seal, oil pan, valve cover Start your car up and give it a small rev or two and have a friend smell your tail pipe
2004 Bolt on & Cammed 3.9L V6 |
Skar Gone
1998 Mustang V6
17.27@76.66
Tell them to smell the tail pipe.
Not In hail and die.
![]() 1998 5 Speed, CAI, Exhaust, Rear Seat Delete. |
Very homosexually
Or take it out on the highway and downshift, if you see smoke coming out your tailpipe, you know what's up then. Dark black would indicate you're burning rich and blue would mean you're burning oil.
Threads Similar to: low on oil problem
| misfire problem, probelms, probably a problem? | rewadferger | 96-98 | 5 | September 13th, 2010 12:17 PM |
| just solved my evap problem now a more serious problem arises I NEED HELP please | sj408 | 96-98 | 5 | July 16th, 2010 08:12 PM |
| AC problem = Tune problem? | SKRAPR | 2005 - 2010 | 11 | May 16th, 2009 12:29 AM |
| Transmission problem??? need help diagnosing the problem... | Tmac3320 | 99-04 | 19 | April 13th, 2009 12:58 AM |
| umm have a weird problem? idle problem? | blue03mach1 | 99-04 | 16 | March 4th, 2008 12:03 PM |
