2000 V6 Stang No Start - Probing Fuel Pump?
Old January 22nd, 2012, 04:47 PM   #1
Nurmi_CEO is on a distinguished road
I'm working on a friends 00 V6 stang that doesn't start. The vehicle has a spark, but I suspect no fuel. On the fuel rail at the front of the motor there is a small black cap, and we stuck a screwdriver in there and got nothing out. I figure if there was pressure it would squirt out.
Tried both keys, both did not work.
So I tested for voltage at the plug for the fuel tank and this is what I came up with.
Looking at the plug, there are 7 pins. If you look at it like this:
X X X X
...X X X
If they are number liked this:
1 2 3 4
...5 6 7
I get 11V at pin 4 and 5 volts at pin 7.
The battery is brand new. Would this point to a bad CCRM not supplying a full 12V to the fuel pump or do you think the fuel pump would still work with that voltage and the fuel pump is bad? I do hear a brief whine by the tank when the key goes to the "On" position.
-Inertia switch is correct
Old January 22nd, 2012, 06:11 PM   #2
Very homosexually
str8chillng's Avatar
1998 Mustang BASE
17.3
str8chillng is on a distinguished road
Send a message via AIM to str8chillng
X X X X
...X X X
1 2 3 4
...5 6 7
any check engine lights lately?
Old January 23rd, 2012, 11:29 PM   #3
No CEL
Threads Similar to: 2000 V6 Stang No Start - Probing Fuel Pump?
2000 v6 fuel pump not pressurizing Theunderdodge V6 Mustangs 3 November 20th, 2010 01:45 AM
No Start this morning! Need a new fuel pump? OutKast09 99-04 6 August 3rd, 2010 02:28 PM
2000 GT Fuel Pump stitch2008 99-04 27 November 19th, 2009 11:01 AM
2000 cavalier fuel pump connections adam0421 All Other Vehicles 0 September 20th, 2009 09:59 PM
just changed fuel pump but won't start JAYBIZ_5.0 94-95 15 December 30th, 2008 08:56 AM
