V6 RIDICULOUS SHAKING
I have a 1999 V6 foxbody mustang 3.8, recently it had been running really hard and shaking a bit, so I change the motor mounts and now the shaking is worse! It Idles ok once it is below 1,000 rpms at 1,000 the shaking is the worst and feels like the car is gonna fall apart once it is above 1,500-2,000 rpms it normal, but it will not rev past 4,000 RPM its as if its hitting the rev limiter (my car is a manual). On top of that there is a slight knocking noise not loud but quiet and faint. I have changed:
the spark plugs Spark plug wires Igition coil Ive cleaned the Throttle bottle recently I changed the Idle control valve I am lost and dont know what else to do please someone help me!
2000 Mustang 3.8
ehh w/e the mostly stock time is
They made a 1999 v6 foxbody? huh, thought those ended in 1993
but i would try the TPS sensor. is there a CEL?
![]() Diablo-Eibach-Pacesetter-Flowsound-MGW-BBK How to paint your rims: http://www.moddedmustangs.com/forums...ml#post3931042 |
no there is not a check engine light
2000 Mustang 3.8
are the rpm's sticking at all?
00 3.8 Mustang
Slow@slow
![]() iTrader: 2 reviews
check your balancer, mine didnt look bad until i took it off, the rubber was dry rotted and the weightwas thrown off, got a new one and the shaking was gone, i have a 2000 and the 99 00 are external just to let ya know
and mine shook around the same rpm, and yeah it feels as if the thing is getting read to blow lol
![]() Windstar Swap, Asp 25% UDP, Jegs off road h-pipe/Supper 44's, Tri hook Quadrant |
Balancer? where is that?
MM's king of Neon's
404 - car not found
17.81@87
That big round crank pulley on the front.
Official Secondhand Snake Build Thread Here Looks Like a Cobra, Sounds Like a Cobra, Tastes Like a Cobra, Not a Cobra. For Sale: P71 Interceptor motor ![]() |
The soul stealing Ginger
wicked are you referencing the harmonic balancer? if so could the balancer do it every now and then or would it do it all the time?
OP you said you cleaned the throttle body? you didnt by chance happen to turn a screw on the TB by the Throttle cable? |
#9 | |
MM's king of Neon's
404 - car not found
17.81@87
If it was very bad I could see it being constant, but if it's only slightly bad it may manifest itself in harmonics at certain frequencies. But after re-reading it, I'm wondering about misfire. Does it feel like it's missing? You can usually hear a miss, and it causes large vibration by disturbing the natural firing frequency of the engine. Have you checked your spark plug gap?
2000 Mustang v6
i just fixed a serious vibration problem yesterday. After trying like 5 other things it ended up being my harmonic balancer that fixed the problem
I'm curious about my own problem since you mentioned that....interesting.
rafter what were your symptoms?
#13 | |
14.37 @ 96
more info on those blue spots please. And look up detonation and read about what it is. |
2000 Mustang v6
Replaced TPS car still shakes and now it stalls out when you accelarate, is there anything special you need to do for the TPS its just bolt of bolt on right?
Fuel filter / fuel pump?
2002 Ford Mustang
Did you replace the IAC Valve before or after the vibrations started? I've put mine on backwards before and experienced "some" of your symptoms.
Like said above, check the harmonic balancer. If T5 make sure the counter-weight is still on your flywheel. If 4R70W I would suspect the converter. Otherwise I would have to suggest something internally engine-wise, you don't even want to know those reasons. If your shaking is as bad as it sounds, I wouldn't drive/run the car more than necessary until fixed.
![]() K&N CAI, MSD Wires, MAC L/T's, MAC O/R H-Pipe, Super 44's, MGW Shifter, SPEC Aluminum Flywheel, RAM HDX Clutch, FRPP Aluminum Driveshaft, 4.10's, Trac-Lok, Mach 1 17's, Nitto NT555 275's & 315's! Need Mustang help in MO? PM me! |
14.37 @ 96
stop replacing stuff and find the problem.
And give me more details on the stuff I highlighted in blue please. will help 10x more. |
Threads Similar to: V6 RIDICULOUS SHAKING
| This Is Just RIDICULOUS!!!!!! | Youngin | The Clubhouse | 8 | June 26th, 2010 12:01 PM |
| you know what is ridiculous? | WLJohnson05 | The Clubhouse | 21 | September 25th, 2008 10:30 PM |
| This is ridiculous!! | chris1 | American Muscle | 27 | March 26th, 2008 02:51 PM |
| This is ridiculous | dshep | 99-04 | 6 | April 18th, 2007 04:57 AM |
