2000 3.8 V6
Not Ready Yet
Engine Shuts off while driving
Help! Ok i am new to Modded and i am a noob with mustang but i want to learn.
Here is my problem I drive a V6 3.8 2000 and i recently went to a shop to install Long Tube Headers by Pacesetter. I installed them and had to cut off my EGR valve so i did. I had to do this in order for the LT to fit because they did not have EGR. So the shop disconnected it and capped off my EGR vavle. I got my car back and had to install resignators ( silencers) because it was to loud and i didnt have the cash for super 40s. which I will be installing soon. My problem is now when i come to a stop i shift out of gear and in Neutral the car's RPMs fall to 0 and the car seems to stall even though it is moving. As the RPMs fall if i accelerate they can rise before it hits 0 but it sounds messed up like its about to stall. It sounds as if you are at .5 rpm and accelerate not to stall. P.S My Exhaust set up is only LT and resignators no cats nor mufflers. My plan is to remove the resignators and have LTs with O/R H pipe and Super 40s Please help if you need more info just ask and this is my first post. |
1993 Mustang GT
Could be your fuel pump.
1993 Mustang GT (Reef Blue on platinum) 105k Miles, still strong. BBK CAI Dual Flowmasters Hurst Shortshifter Smog Delete Gatorback pulleys. FULL LED Tailights NEWEST ADDITION: Eaton M90 supercharger kit |
2000 3.8 V6
Not Ready Yet
They didn't touch it could it be anything to do with the header installation. How can i check the Pump
The soul stealing Ginger
How is the egr capped off? is it actually secure? could be a bad vacuum leak.
2000 3.8 V6
Not Ready Yet
i need to check that out. ALso i havent removed the EGR from the computer could this be a problem??
1993 Mustang GT
Sometimes fuel pumps just crap out with age, that happened on my old carb setup, it would drive okay if it was revved but if it got low rpms, for instance at a stoplight, it would die. Your fuel pump should be right by the gas tank, its a simple fix. But check vacuums also. Throwing any codes?
He would have to be throwing a code if they cut off the EGR, without a tuner to turn it off. I would look in the relevant places first the EGR system, fuel pump does not seem logical to be dead if he is able to start, just has the problem while driving.
1993 Mustang GT
is it hard to start at all?usually if something goes wrong after you do something, it has something to do with what you just did, more than likely its soomething to do with your EGR.
2000 3.8 V6
Not Ready Yet
no the only time it was hard to start was today after it turned off in like 3rd when i was runing it hard. I had to pump the gas to start it up.
1993 Mustang GT
mine was never hard to start up in the morning, but it would be hard to start after it died..(fuel pump issue for me). i would check out what they did with your EGR, then proceed to a fuel pump change if you cant find anything wrong, its a cheap part and a 5 minute fix.
2000 3.8 V6
Not Ready Yet
beside today it would restart right up without a problem. Also it has no check engine light and i need a computer to see if any codes are coming up but i think the shop reset the light because they removed the EGR and no light came up.
2000 3.8 V6
Not Ready Yet
Yea thats whats going on it is easy start in the Am then today for the first time it wouldnt start up after it died i had to pump the gas to start it up.
Money is on the EGR system.
1993 Mustang GT
slap a fuel pump on it.let me know how it goes,might want to throw some fuel injector cleaner or StaBil in there, ccould have had debree that might have torn up your fuel filter. Ive been saying fuel pump this whole time i meant fuel filter...sorry.
lol how do you justify fuel pump? when the work was done on the exhaust system DIRECTLY cutting something off?
[{4114 K-73}]
2000 Mustang V6 Manual
Id say take it back to the shop, sounds like they fucked something up
![]() BAMA-K&N-C&L-TI LLC-VAP Auto-Steeda-MAC-Thrush-Koni-H&R-Maximum Motorsports WTB MAC Flow Path mufflers or Bassani mufflers PM me if you have a pair |
2000 3.8 V6
Not Ready Yet
I went by the shop today and they were busy ima go back tomorrow and see its a pain the the #@!$ because i suck at Spanish and communicating is difficult with them..
Ill take a pic of my EGR and show u guys. Do you all have an EGR still ? And where is the fuel filter, i acess it through the trunk where the pump is |
2000 3.8 V6
Not Ready Yet
Reaper 88 do u have the SCT tuner did u disable EGR?
KP, You HAVE to disable your EGR. Its not a choice really. You WILL throw a code, and if this shop was shady like someones backyard then you probably have a huge leak on the system somewhere. Am i invisibile or something lol, why would you waste money on fuel filter? its like 4.00 bucks but still. think about it, your car starts right? you have pressure right? so its getting through.
2000 3.8 V6
Not Ready Yet
no man your not invisible lol sorry . No the shop is legit just in the Spanish part of town here in miami. I havent disabled my EGR i need the Tuner for that right?
Could it be a gas leak or exhaust? |
Threads Similar to: Engine Shuts off while driving
| Car shuts off while driving, or wont start at all | dothedew1654 | 94-95 | 9 | June 23rd, 2010 04:46 PM |
| Engine Shut off while driving | 91 gt 5.0 | 5.0 Mustangs | 9 | July 12th, 2009 12:17 PM |
| '06 GT Engine Noise Driving Me Insane! | Windveil Blues | 2005 - 2010 | 26 | February 25th, 2008 02:19 PM |
| Engine Lagging After Stop-Go Driving | OcOnnor220 | 99-04 | 7 | October 7th, 2007 07:29 PM |
| Engine Dies While Driving | Mystic Mama | 96-98 | 7 | May 6th, 2006 07:55 PM |
