2002 3.8 Hesitation problem - Page 2
Old February 3rd, 2012, 07:44 AM   #21
Resident badass
Mr. Red Pony's Avatar
01 Built V6 (3.9)
13.91 @ 99.1 N/A
iTrader: 10 reviews
You have a 95 though. OBD2 didn't start until 96. In OBD1 MAF would not turn on the CEL.
But it sounds like a fuel delivery problem. You need to check you TPs for a bad spot too. When I get on my laptop tonight I'll get the intrusions to check it. In the mean time, go get a DVOM. Radioshacks cheapest will do fine.
271rwhp N/A V6
Suck it.
Old February 4th, 2012, 12:56 AM   #22
Very homosexually
str8chillng's Avatar
1998 Mustang BASE
17.3
str8chillng is on a distinguished road
Send a message via AIM to str8chillng
Cool
Originally Posted by Hoofinstien View Post
I do all my own work, just wish I had someone that could pinpoint the exact problem. Without codes this is tricky. At idle it is very smooth and this hesitation is completely random, comes and goes. I have never had to replace a coil pack, can this lead to random hesitation and no codes.
Believe it or not, try replacing the alternator. It fixed all my problems on my mustang with that strange hesitation problem.
Old February 4th, 2012, 08:56 AM   #23
Resident badass
01 Built V6 (3.9)
13.91 @ 99.1 N/A
iTrader: 10 reviews
Not a good way to diagnose a problem.
271rwhp N/A V6
Suck it.
Old February 4th, 2012, 10:55 PM   #24
Green_6er's Avatar
2000 Mustang 3.8
ehh w/e the mostly stock time is
Green_6er has a spectacular aura aboutGreen_6er has a spectacular aura aboutGreen_6er has a spectacular aura about
i would say get a multimeter and test the coil pack, wires, battery, and everything else you can that you think could lead to being your problem.
Originally Posted by 6ER THEN I 8ER! View Post
If you don't scrape you did it wrong
Diablo-Eibach-Pacesetter-Flowsound-MGW-BBK
How to paint your rims:
http://www.moddedmustangs.com/forums...ml#post3931042
Old February 8th, 2012, 09:33 PM   #25
Hoofinstien is on a distinguished road
I will pick up a dvom tommorow and start poking around.
Where should I test the fuel pump and injectors at?
THis is also a strange revelation. I was tracking back things I done to my car trying to see where im at with reapairs and I remembered this.
When I changed my fuel filler neck ring to stop my fuel leak, I had the peice at the end of the filler tube break off and fall into my tank. Could this be getting caught up in the syphon and causing my hesitation problem. This could be why it is intermittent and random. I will drop the tank and fish this out anyway just to be sure.
2002 3.8 Auto
17x8 Black Bullitt replica's
FRPP lowering springs
Chin Spoiler
Stainless American Thunder catback with divorced midpipe
AM CAI
Old February 9th, 2012, 12:07 PM   #26
MM's Official Lucifer
goren813's Avatar
'00 3.8L & '05 4.6L
Might as well be to be sure. From my math you replaced the plugs 50k miles ago. They'd stand to change out, not sure if you've checked them yet from this.
Old February 12th, 2012, 09:47 PM   #27
Guess the next semi warm day , I am going to drop the tank and fish out that piece and possible some of that rubber fuel neck ring. Then test the pump and injectors and coil pack.
2002 3.8 Auto
Chin Spoiler
AM CAI
Old February 15th, 2012, 10:13 PM   #28
Trying to run the gas out, this car is a backup/project car so trying to find time to drive it is kinda wierd. Going to run the gas out tonight however. Obviously I need to get any obstruction out of my gas tank before I continue but could this actually lead to a fuel delivery problem?
2002 3.8 Auto
Chin Spoiler
AM CAI
Old February 15th, 2012, 11:16 PM   #29
eleanorGT's Avatar
2001 Mustang 3.8
eleanorGT will become famous soon enough
i know on my car.. i have this problem after a bit of constant driving.. like no hard accel, but constant accel.. Then when i do want to accel more rapidly, it will hesitate, and jolt.. so I pull over, and shut the car off, turn the key back and forth(because my theory is my fuel pump is going bad, to i turn the key on and off to pump fuel into the line) and then start it back up.. and there is no more hesitation on hard accells even up to 5500 RPMS.. so your fuel pump could be going bad.. First dont spend any money, baby the car.. clean wires, check corrosion on the plugs, clean MAF, clean Throttle body, Clean Air intake filter.. Then spend 10$ on a new fuel filter.. See how she drives, and if it starts to hesitate, do what i said to do above.. see how she responds... Let me know how it goes for you.
Old February 25th, 2012, 10:30 PM   #30
I am going to drive the rest of the fuel out by tuesday and drop the tank and at least fish all of the crap out of the tank, IE: Pieces of rubber grommet and the end of the fuel neck filler tube.
I am going to purchase a fuel pressure tester and see if I can rule out or confirm the fuel problem.
What is the model number for the svt focus replacement pump. I am getting different numbers and would like clarification.
Also after I run and turn the car off I hear a loud clank for a few minutes every minute or so from under the car around where the cats and mid pipe would be at. I am thinking of a possible cat clog except no codes.
Any tips on testing the fuel pump?
2002 3.8 Auto
Chin Spoiler
AM CAI
Threads Similar to: 2002 3.8 Hesitation problem
95 Mustang Gt 5spd Bucking and Hesitation problem Also ECU Prob 95whiteGT 5.0 Mustangs 0 December 30th, 2011 05:39 PM
fuel hesitation problem 03saleen 99-04 0 April 30th, 2010 11:47 PM
Hesitation Problem nHuman 96-98 23 June 3rd, 2009 04:55 PM
2002 V6 Problem Stang1118 V6 Mustangs 13 May 25th, 2009 03:41 PM
Problem with hesitation after installing side exhaust w/pro charger 254gt254 2005 - 2010 10 April 10th, 2009 08:24 AM
