WONT START - Page 2
Old February 1st, 2012, 04:27 PM   #21
The soul stealing Ginger
dgt_mustang's Avatar
2001 Mustang 3.8l
dgt_mustang is a jewel in the roughdgt_mustang is a jewel in the roughdgt_mustang is a jewel in the rough
Send a message via AIM to dgt_mustang Send a message via Skype™ to dgt_mustang
Surprise, the part came in today instead of tomorrow! throwing it in here shortly and will post an update.
Get another job, get 2 more jobs, get your own place, work, live, fuck, eat, life, happy.
Old February 1st, 2012, 05:53 PM   #22
stephen has a spectacular aura aboutstephen has a spectacular aura about
Are you sure you didn't put diesel fuel in it?
Old February 1st, 2012, 06:55 PM   #23
2001 Mustang 3.8l
^I'm going to disregard that...
***Update***
CCRM has been replaced.
Fuel Filter has been replaced.
check for spark and i have it on both sides of the coil pack, not all the plugs.
No change. however when i took the spark plug wire off to check for spark it cranked up and ran for a few seconds before i turned it off. I could not duplicate this so im assuming it was just fumes somehow. I'm stuck...my gf keeps saying to change the plugs but there is clearly a code that says fuel pump area. only thing left to do that i can see is replace the fuel pump.
Old February 1st, 2012, 09:35 PM   #24
2001 Mustang 3.8l
I found my Fuel Pump Driver Module. Part number XR3F-9D372-AE. I'm mainly posting this here so that when i go to work in the morning i can refer back to this since it has all my information. code and now the part number.
Old February 2nd, 2012, 01:27 PM   #25
Originally Posted by dgt_mustang View Post
Heres is the story:
Car was really low on gas, no low fuel light yet. I pull into my local gas station (Murphys) put 25.01 in. start the car and immediately it feels like an earthquake. I'm thinking it will subside so i wait a min. It doesnt. i start to pull out and things get a little by but not by much. I'm about to get on the main road when i think to myself it will be better to go the back way, no traffic. i turn the car around and right when i do It Dies.
I get it towed back to my house and am going to try a few things tomorrow.
Heres what i think.
Bad gas - pumping out the tank, relieve the fuel in the lines via the front fuel rail, changing the fuel filter, adding premium gas and a fuel injector cleaner and then will start it.
your opinions?
This sounds like one of two things. 1. very bad gas (I suggested maybe somehow it was diesel not gas). 2. the fuel pump failed due to low fuel level.
The chance that it isn't somehow related to just filling up the gas tank is very small.
Old February 3rd, 2012, 07:34 AM   #26
2001 Mustang 3.8l
I was thinking bad gas because of the circumstances but it does have a code for either fuel pump, or fuel pump driver module. I am purchasing the fuel pump driver module from a member on here and go from there.
Old February 5th, 2012, 11:32 AM   #27
alowe28's Avatar
alowe28 is on a distinguished road
Check fuel pressure with a gauge?
Old February 6th, 2012, 05:40 PM   #28
2001 Mustang 3.8l
Replaced the fuel pump driver module its still a no start. It cranked up after the install and ran up till i touched the gas pedal then died, it is now doing the same thing again. Only thing left to try and change is the fuel pump...what are your takes? keep in mind it has a P1237 code.
Old February 6th, 2012, 10:46 PM   #29
I would drop the gas tank and drain it and clean it out then replace the fuel pump and put in new gas from a different gas station. Likely contaminated fuel damaged the fuel pump.
Save the removed gasoline and if the new fuel pump and new gas fixes it have the old gasoline checked out by a lab to determine if you have cause for legal action.
Old February 10th, 2012, 08:37 PM   #30
2001 Mustang 3.8l
My car is fixed!!!! its sounds beautiful, i just wanted to put a resolution on my thread.
it also irritated me when i searched and searched for my car problems that everytime i came across something that sounded similiar the thread that i was reading just suddenly died off so there it is, one of the first threads that i know of thats shows the problem from the beginning, to the steps, to the end. SO HAPPY.
Old February 10th, 2012, 09:41 PM   #31
Formerly 01silversixer
SlowSix's Avatar
2001 V6
15.47@89.57
SlowSix has a spectacular aura aboutSlowSix has a spectacular aura aboutSlowSix has a spectacular aura about
so wait..what was the fix?
Build Thread
Old February 11th, 2012, 01:13 AM   #32
Needs 2 cylinder bolt on
Mach Stang's Avatar
'03 Mustang V6
It's a six so what do you expect?
Mach Stang is a jewel in the roughMach Stang is a jewel in the roughMach Stang is a jewel in the rough
Lol I'm guessing fuel pump was bad.
"you're alive for a reason, DON'T GIVE UP"
Originally Posted by SoMDWhite03GT View Post
Going down to NC for the NASCAR race!
When I seek that kind of entertainment I sit by the the red light near my house and watch all the cars turn left
Threads Similar to: WONT START
car wont start OBD II wont read. ECU? ForestGRN_Ghost 99-04 7 September 14th, 2011 11:38 AM
Wont start ....AGAIN! 1sl0w88 5.0 Mustangs 3 October 10th, 2010 03:57 PM
My Car wont start. Fir3controlman 99-04 3 February 15th, 2010 07:56 PM
Ehh car wont start... Youngin 2005 - 2010 V6 1 August 2nd, 2009 06:55 AM
