#21 |
14.37 @ 96
Inspect you block and the internals the best you can.
If it looks ok, get a new set of heads. Id sell you my stock ones cheap cause the passenger side one has a valve cover bolt that broke off in it. But its on the top half and I used a little RTV on it and had no oil leaks. But it shouldn't be hard to find a good set of heads, the 3.8 and 4.2 heads are the same thing. You can always helicoil the bad spark plug hole. But you might need too check out the valve stems and seats. Make sure its all sealing well. Go have your heads tested before they go on. |
#22 |
Wax on, Wax off
Talked to the guy today. He said 90PSI on the compression test was good, but I see much higher numbers from everyone else. I mean, this guy does know what he is doing... so I want to trust him, but I feel like he is wrong here. Not sure what to do in that situation. Is 90 to low for a warmed up engine with 93k miles?
Plan right now:
What I did before it went to him:
So, hopefully after all of this it will be running good again.
![]() Black Bullitt Rims FT/FS Looking to Sell or Trade for Silver FR500s Looking to buy a lot of 99-04 Interior Pieces If you have any for sale, PM me |
#23 |
RLY SRS
Just install some NGK plugs and you will be fine as far as spark goes...
#24 |
Wax on, Wax off
He said he put AC's? I am guessing Acdelco?
My main concern is that he is wrong about the cly compression. He says with the new plugs its running smooth however... shurg. Guess we will see.
#26 |
Wax on, Wax off
What do you mean? You can find them listed for a 2003 V6 on Autzone... Acdelco Rpdfire Plat/Spark Plug (14) | 2003 Ford Mustang 6 Cylinders 4 3.8L SFI | AutoZone.com
#27 | |
RLY SRS
I always use NGK or motorcraft in fords and AC Delco in GM's... |
#28 |
1996 V6
No need to seafoam if you're already cleaning the heads up .. imo, anyway
1996 3.8L.. Split Port Swap, CAI, True Dual Exhaust, the car accident mod. Need cheap parts? CLICK MEEEEEEEEE!! =] |
#29 |
Wax on, Wax off
Were not cleaning the heads.
The guy also said theres different types of sea foam for different parts of the car. I feel this guy knows what he is doing, but on some things he does not... as with all repair mechanics Lol. So... back to the REAL issue I was asking... 90 PSI... he says good, thoughts?
#30 | |
RLY SRS
Was this the same cylinder that had the plug issue? |
#31 | |
Pretty much. Sea Foam | Products I know quite a few posters on BITOG like to soak the cylinders in Deep Creep in an effort to free up stuck rings. Otherwise, the Seafoam Spray is just an aerosol version of the regular Seafoam.
Rod @ AzzKicker Cars 2004 Ford Mustang GT-The Driver-BBK CAI, PP TB & Inlet, Steeda UD's, SLP LM1, & 3.73's. ![]() 1990 Mercury Cougar XR7-The Meth Addict-5.0L DOHC Stroker w/2.1L KB SC. ![]() 1995 Ford F150-Mud Toy-5.0L, 4x4, 33's, & Warn 8274 Winch |
#32 |
Formerly 01silversixer
2001 V6
15.47@89.57
His guage is way off on the compression test or he doesn't know what he is doing imo...
You should probably be seeing numbers 130+. I'm not really sure what its supposed to be on the 3.8 motor but 90 seems bad |
#33 | ||
Wax on, Wax off
I may ask him to do a reading for me to see if my guage is bad.
#34 | |
14.37 @ 96
I see a highly important thing going on here that im questioning. Head gaskets/bolts are not on this list and he's wanting to fix the spark plug hole ? That head better not be on that engine before anything touches it. Gonna be lucky if a "bad spark plug hole" didn't already get metal into the cylinder and cause a few bad spots ... You need to have him pull the heads off.Otherwise you'll have metal shavings from repairing the heads in there. Gaskets are like 45$ a piece. Get them from Ford. Tousley is a good place. head bolts aint cheap either Look into new valve seals and lifters POSSIBLY. |
#35 | |
14.37 @ 96
I see a highly important thing going on here that im questioning. Head gaskets/bolts are not on this list and he's wanting to fix the spark plug hole ? That head better not be on that engine before anything touches it. Gonna be lucky if a "bad spark plug hole" didn't already get metal into the cylinder and cause a few bad spots ... You need to have him pull the heads off.Otherwise you'll have metal shavings from repairing the heads in there. Gaskets are like 45$ a piece. Get them from Ford. Tousley is a good place. head bolts aint cheap either Look into new valve seals and lifters POSSIBLY. Also main seals. |
Threads Similar to: It starts...
| Car starts, then dies. | Nightmare | 99-04 | 7 | December 25th, 2011 09:04 PM |
| it starts good....... then it gets better | BWAL | Videos | 8 | September 3rd, 2009 09:04 PM |
| Help! My car starts when it wants to..... | OutKast09 | General Tech | 1 | June 24th, 2009 03:55 AM |
| Starts | Gt98 | 96-98 | 6 | October 2nd, 2008 12:26 AM |
| OSU starts it off right! | 03 R Code | The Clubhouse | 23 | September 2nd, 2007 09:38 PM |
