ONE BOLT!
currently am doing a clutch job on my car w/ 150000mi on it, needless to say everything sucks to get off. i have the entire exhaust off and the tranny out. im down to the bell housing and got every bolt out except the top right one. it keeps turning off the socket (coming from underneath on a lift with an extension a swivel) the socket sits on the bolt but will turn off as soon as torque is added, i believe because the slight angle from the swivel.the engine is lifted in the front via jack for a better backside angel. we tried air tools, torque bars, pipes on torque bars...seemingly everything. can anyone give me some better insight, ideas, or last resorts?
If the upper intake manifold is removed that bolt can be reached from the top. I have used a wrench and length of pipe. I think it would be possible to get a socket on it. Use a 6 point socket.
2000 m112'd 3.8
double wrench it from the top
2002 Ford Mustang
I use the Snap-On Impact Swivel Sockets. Instead of pinned-block connections like standard swivels, it uses a ball-joint socket permanently attached to a socket that doesn't bind and throw your socket off at tough angles. They are pretty expensive at about $30 a piece, but they are a lifesaver.
![]() K&N CAI, MSD Wires, MAC L/T's, MAC O/R H-Pipe, Super 44's, MGW Shifter, SPEC Aluminum Flywheel, RAM HDX Clutch, FRPP Aluminum Driveshaft, 4.10's, Trac-Lok, Mach 1 17's, Nitto NT555 275's & 315's! Need Mustang help in MO? PM me! |
MM's Official Lucifer
I managed to get it off from underneath with diff. combos of extensions and sockets. PB blaster or something similar to try and loosen it up, but just going to take elbow grease and a little bit of luck unless you attack it from up top which is a whole 'nother list of things to remove.
2001 Mustang 3.8
long extension, and swivel socket
Threads Similar to: ONE BOLT!
| looking for bolt ons!! | wxexs92 | 94-95 | 1 | April 27th, 2011 05:02 PM |
| Striped Pan Bolt hole And Exhaust manifold bolt hole what to do? | TX77 | 99-04 | 1 | November 29th, 2010 11:36 PM |
| Bolt on GT vs Bolt on WS-6 with video | 00gtCoolGuy | Drag | 4 | July 20th, 2009 10:10 AM |
| HELP! SOHC 6 bolt crank/ cobra 8 bolt crank interchangability? | the1968jeepthing | 99-04 | 2 | September 29th, 2008 11:39 PM |
| Bolt Ons for v6 | supermachone | The Clubhouse | 22 | May 5th, 2008 10:34 PM |
