Bad rack and pinon?
Old February 5th, 2012, 02:52 PM   #1
04 Mustang-40th
davo is on a distinguished road
Bad rack and pinon?
I have a knocking noise when I wiggle my steering wheel. Both outer tie rods are in good shape, one of them was just replaced. I thought it might be an inner tie rod but when I pulled the dust boot off and had someone wiggle the steering wheel I saw that the part of the rack and pinion that the inner tie rod bolts on to was moving up and down. I've never dealt with a rack and pinion problems before. Does the whole thing need to be replaced or is it re-buildable? Thanks
Old February 5th, 2012, 07:07 PM   #2
stephen has a spectacular aura aboutstephen has a spectacular aura about
Rebuilt rack and pinion assemblies are available or some parts are available.
Rock auto is one place to buy one.
Old February 5th, 2012, 07:41 PM   #3
04 Mustang-40th
thia is what it sounds like:
The only thing I see is when turning the wheel back and forth, the shaft that the inner tie rod is screwed on to moves up and down. I think it is bad but just trying to see if anyone has had a similer experience before I replace it?
Old February 6th, 2012, 01:10 PM   #4
I don't think that much movement is normal.
I looked in the Ford shop manual but it doesn't show anything about the internal parts
of the rack and pinion. It says to install a rebuilt one if it has a problem. Ford has them for about $250 or aftermarket is $100-$150 (from Rock auto).
Threads Similar to: Bad rack and pinon?
Pinon Bearing CandyredGT 2005 - 2010 5 July 25th, 2010 12:51 PM
rack and pin unit xtian96gt 96-98 6 January 7th, 2010 03:06 PM
2008 gt pinon angle adjustment? JakeGT08 2005 - 2010 21 April 23rd, 2009 11:37 PM
Pinon Seal Replacement SKRMNGT 99-04 2 June 26th, 2008 03:03 AM
