96 3.8 running rough when warm
Old February 6th, 2012, 03:17 PM   #1
96 3.8
1996 mustang 3.8
Nate3.8 is on a distinguished road
i have a 96 3.8 mustang. i have been through alot with this car over the past month. finally got it runnign better but still have an issue. runs great when cold even runs ok when first warms up but once i gets hot and i drive it about 15 when warm she wants to run rough check engine light flashes ans pops a code for misfire #4 cylinder ever time. plugs and wire are new. also wants to stall and is hard to crank back up when it does this and smell like gas bad. need help.
i have changed alot on this car cam, crank sensor. fuel pump, filter, TPS, MaF
also have changed computers and still same issue. o2 sensor.
car has flow exhaust, cold air intake.
Old February 7th, 2012, 12:06 AM   #2
Skar Gone
Skargon's Avatar
1998 Mustang V6
17.27@76.66
Skargon will become famous soon enoughSkargon will become famous soon enough
Try cleaning your IAT, Air Filter, Take a look at the Spark plug after it happens a few times, That could Diagnose the whole problem. Hopefully its nothing too bad, Check the Color of your oil, If it is Milky or Very bubbley, You might want to start saving alittle money..
Try to get a friend with a code reader to check it for you because with some programs like the one I use, I can Pinpoint exactally what and how my car was running when the code appeared
1998 5 Speed, CAI, Exhaust, Rear Seat Delete.
Old February 7th, 2012, 12:47 PM   #3
96 3.8
1996 mustang 3.8
yeah oil is ok so not head gaskets. i know it needs valve cover gaskets but i did notice right before it starts to run rough i can hear what sounds like the rocker arms, i know these motors are bad about rocker arms getting loose. and i finally got a code to pop up beside miss fire #4 code. i got a p1150 code. so it may be the injector causing some of this issue.
Old February 8th, 2012, 02:28 PM   #4
96 3.8
1996 mustang 3.8
well i may have a small exhaust leak near the passenger side o2. but still have miss fire #4.
Threads Similar to: 96 3.8 running rough when warm
2.3 N/A Running Rough 1993MustangNotch 2.3 Mustangs 3 June 27th, 2011 08:27 PM
98 GT running rough Jermsjunk 96-98 4 May 25th, 2011 10:22 PM
car running rough bottled2v 99-04 13 March 18th, 2011 10:32 PM
Running Rough!! flamed 98 gt 96-98 11 June 13th, 2008 11:48 AM
Stang wont stay running, after warm up...???? ttop5.0 5.0 Mustangs 2 November 28th, 2006 04:10 PM
