Start up squealing 3.9l 2004 - Forums at Modded Mustangs
post #1 of 18 Old February 9th, 2012, 12:42 PM Thread Starter
Filly's Avatar
I have extensively searched for a solution and have not found out what this noise is. When I start up the car on a cold day a squealing noise comes from what seems to be below or behind the engine. The noise always goes away after 10 minutes of driving. The pitch will change if I push the clutch in or out. I have already tried replacing the belt... Any suggestions???
Thanks
http://www.youtube.com/watch?v=YeJl-2iN2Nw]
Video link
Filly is offline
post #2 of 18 Old February 9th, 2012, 12:47 PM
The soul stealing Ginger
dgt_mustang's Avatar
Send a message via Skype™ to dgt_mustang
Welcome to MM!!!!
Pully maybe? i hear the idler pulley is one that squeeks quite often. you can try buying some anti belt squeel from a parts store and spray one pulley before starting it. narrow it down at least.
Dr.Gonzo! is the Ultimate IT master, the king of tech, The Dong.
The Dong^?? ZIP!!!
dgt_mustang is offline
post #3 of 18 Old February 9th, 2012, 01:02 PM
MM's Official Lucifer
goren813's Avatar
If you start the car without the belt on you can eliminate pulleys if the noise is still there. Do not run the car for more than a minute or so like this, but should be more than enough time to know that the noise is there or not.
If it changes with the clutch being engaged/disengaged then I'm gonna have to say it's something in the clutch system. Most likely the throw out bearing is that's the case. Normally this noise will persist longer than just ten minutes of driving.
how many miles on clutch?
goren813 is offline
post #4 of 18 Old February 9th, 2012, 01:04 PM
goren813's Avatar
Another good possibility is the Cam synchro. About $60 to replace, install can be a little tricky if you have limited mechanical knowledge. Since you mentioned the clutch I'd start there however.
goren813 is offline
post #5 of 18 Old February 9th, 2012, 01:17 PM Thread Starter
Filly's Avatar
57,000 miles on car. Not sure if the clutch has ever been replaced. I bought it at 52,000. I'll try narrowing down the pulleys when I get home and go from there. As that is the simplest thing to eliminate.
Filly is offline
post #6 of 18 Old February 9th, 2012, 01:24 PM
goren813's Avatar
Right, always start at the easiest and cheapest. I'd guess you've got a stock clutch. Unless it's been beaten up it should have plenty of life left on it.
goren813 is offline
post #7 of 18 Old February 9th, 2012, 05:21 PM
throwout bearing. replace with oem one.
Mods in Garage
My Youtube Channel watch my funny videos, make me daz moneyz
Originally Posted by walt1120 View Post
Listen hoe, the terminator cobra is the most baddest piece of engineering ever to exist. A man becomes baddest the moment he sits in one.
mycurse01 is offline
post #8 of 18 Old February 9th, 2012, 05:45 PM
This
1999 e46 328i BMW - Daily Driver
2001 SVT Cobra - Project
1995 v6 vert - SOLD
1996 v6 vert - SOLD
1995 v6 vert #2 - SOLD
1995 GT - SOLD
1997 v6 coupe - Parting
Stang6899 is offline
post #9 of 18 Old February 9th, 2012, 07:43 PM Thread Starter
Filly's Avatar
Im not sure if that is it or not. I youtubed the sound of that and it is diffrent than what I'm experiencing, or atleast I believe so. I'll post a video once my car has had time to cool down. Some other symptoms is the noise will increase with the slight pushing of the throttle and will get steadily louder.
Filly is offline
post #10 of 18 Old February 10th, 2012, 10:51 AM Thread Starter
Filly's Avatar
Well here is the video link
I was not able to pop the hood because I was in a hurry.
The noise almost seems like it is coming from the catalytic converter.
Filly is offline
post #11 of 18 Old February 10th, 2012, 02:56 PM
goren813's Avatar
Vid fail?
Cat would never make a squealing noise. If it's that general area the TOB is a likely cause. As said, always use OEM piece there. If you're going to swap that, I'd suggest inspecting the rest of the clutch as well.
goren813 is offline
post #12 of 18 Old February 11th, 2012, 01:53 AM Thread Starter
Filly's Avatar
Alright, the last link didnt work. probably something to do with sending it from my iphone. This one should work...
Filly is offline
post #13 of 18 Old February 11th, 2012, 03:40 AM
iPoopke Regular
Doesnt sound like a belt. Cant really make out the noise all too well
iPAPKE is offline
post #14 of 18 Old February 11th, 2012, 10:53 AM Thread Starter
Filly's Avatar
I'll post a better video probably Sunday morning. You can hear the noise better starting around 18 seconds.
Filly is offline
post #15 of 18 Old February 11th, 2012, 04:35 PM Thread Starter
Filly's Avatar
well it is definately not the pulleys or belt. I took of the serpentine and the noise still occurred. I think it is the TOB because when i slightly push in the clutch or let it out, the noise will change pitch and will cause the noise to either stutter or go constantly depending on how far in and out... does this sound like a weakening TOB? because the noise goes away after driving for awhile.
Filly is offline
post #16 of 18 Old February 11th, 2012, 04:46 PM
goren813's Avatar
Yes. After warming up it's expanding slightly, but if you're hearing the change when disengaging the clutch, it's def. something in the clutch system, and the TOB is what makes the noise.
How mechanically inclined are you? Pull the trans and the clutch inspection cover and get the TOB off. Replace with OEM as said, if clutch is working fine then you should be good with just that.
goren813 is offline
post #17 of 18 Old February 11th, 2012, 05:50 PM Thread Starter
Filly's Avatar
mechanically inclined to do just about anything including pulling a trans, or stubborn enough to attempt something if i didn't know how.
Filly is offline
post #18 of 18 Old February 12th, 2012, 02:12 AM
goren813's Avatar
Good man! The way to be. Isn't too tough, just don't crack your sternum if you'll have the car on jack stands when pulling the trans.
goren813 is offline
Human Verification
