2000 mustang v6
CANT START MY MUSTANG
I just replace the fuel pump thinking that was the problem.. my car will get fuel pressure but when i try to start it all you hear is the starter kicking but engine wont even move what do i do
Modded V6
![]() iTrader: 1 reviews
What did the car do to make you think it was the fuel pump?
![]() 1999 e46 328i BMW - Daily Driver 2001 SVT Cobra - Project 1995 v6 vert - SOLD 1996 v6 vert - SOLD 1995 v6 vert #2 - SOLD 1995 GT - SOLD 1997 v6 coupe - Parting |
The soul stealing Ginger
Before you replaced the pump and you were trying to start it, is it possible you ran down your battery?
2000 mustang v6
fuel rail didnt have any pressure, now it does i have try jumping the car too. just checked the starter at autozone and it was good what else helps the starter crank the engine because the engine wont even move a little but if i move it with a tool it turns so its not locked the engine i mean
No codes?
2000 mustang v6
p1000 thats it got it from my sct i dont think it has anything to do with it
2000 mustang v6
would the engine turn even if i had no spark or does the engine have to move for it to make spark
I think p1000 just means the computer doesn't have enough drive cycles.
Not having spark won't keep the engine from turning, but it won't have spark unless it is turning. It gets signals off the ring on the harmonic damper etc. If the engine turns OK with a wrench and the starter spins but doesn't turn the engine there must be something wrong with the starter or ring gear. When the starter engages the drive end moves out to engage the ring gear. The drive part of the starter could be bad. Possibly the starter isn't installed right so it doesn't line up right with the ring gear? That's all I can think of. |
2000 mustang v6
i took starter out today and will install it tomorrow ill make sure everything lines up together so the starter alone can spin the engine right
2000 Mustang 3.8
ehh w/e the mostly stock time is
did you re charge the battery?
![]() Diablo-Eibach-Pacesetter-Flowsound-MGW-BBK How to paint your rims: http://www.moddedmustangs.com/forums...ml#post3931042 |
2000 mustang v6
yeah battery its good I used jumper cables from my tbss to the stang and its good
maybe check the spindle on the starter, make sure it does spin so freely that when it engages instead of kicking the engine up it just spins itself
2000 mustang v6
yeah im gonna take all the wires that connect to the starter and check them and the starte does spin freely
2000 mustang v6
ok new battery new starter and got the engine to move a lil but it sounds like if it didnt have enough battery i tryed jumping it and same the wires get really really hot what can it be i checked battery cables and clean the hell oout of them and they still get super hot help please
iPoopke Regular
2004 Mustang
The engine started?
#16 | |
^sounds like a good reason to check
MM's Official Lucifer
OP says new starter... new or reman.? If warrantied I'd get another, I'd hope for that over the engine being the issue.
2000 mustang v6
thanks guys for all your help it was my ground wire got a new one and it started on first try thank you guys
Where is the "any" key???
1998 Mustang Coupe
Never heard of a ground wire causing a starter to spin freely but not engage the flywheel. Hmm...learn sumthin new e'vry day.
Threads Similar to: CANT START MY MUSTANG
| 87 Mustang GT 5.0 won't start! | Frozen_Joker | 5.0 Mustangs | 6 | October 6th, 2010 07:31 AM |
| 06 mustang gt smokes on start up and idles bad on start up | slick06gt | 2005 - 2010 | 23 | September 30th, 2010 04:18 PM |
| Mustang Won't Start Please Help | brad12 | 5.0 Mustangs | 6 | April 15th, 2010 11:51 AM |
| what should i do with my v6 mustang to start with? | Millan2007 | V6 Mustangs | 16 | March 4th, 2007 03:20 PM |
| '90 mustang will not start. HELP!! | dkrch | General Tech | 11 | June 23rd, 2006 11:10 AM |
