cold air intake problem. need help quick
ive had a bit of an annoyance. i recently put in my cold air intake and im getting a p101 system too lean air. how do i fix this so that stupid check engine light stays off
48.47@ 12.58
yea...
more info please? like what year and engine size... what kind of cold air intake?
ive got a 95 3.8l v6 with a bbk cold air intake
48.47@ 12.58
check your mass airflow sensor.
you could have damaged it wile taking it off
Mayb...did you plug all the holes
2000 V6 vert Mac LT headers, Mac O/R H-pipe, Mac CAI, ASP 25% underdrive pulley(r.i.p), SCT tune, 8.8 rear and 4.10 gears. |
im pretty sure i didnt damage anything and the only thing that was kinda scketchy about the install was im missing a bolt that all it does is help hold it to the fender. could that be whats causing this?
no, your maf sensor has to be cleaned or something cause its not reading correctly or you filter is on badly
2006 GT
11.99@114
Did you remove your positive cable from the battery before installing the CAI? If not remove for a half hour or longer replace and see if it clears.
![]() 2006 GT (Fastest) 2004 COBRA (Faster) 1990 LX 5.0 (Fast) |
Check for any loose gaskets or holes left around the rubber fittings. If everything's in their tight, either your computer just isn't used to it yet (i.e. it needs to be reset) or you roughed up your MAF during install.
sweet so i checked the intake and theres nothing damaged about it and i reset the battery got the light off now i just gotta wait and see if it comes back on
thanks
sometimes its ok to ignore the "suggested" speed limit |
¡ʇsnq ɹo uʍop ǝpısdn
GL with that ...
if their are any holes after the MAF that aren't plugged it will throw a CEL
From what i have read BBk require a PCM tune on some Mustangs to prevent the car from starving its self of fuel after it is getting more air.
2002 V6 Mustang
I dont wanna steal the thread but i just put my CAI in a few weeks ago. is it normal to hear a whistling sounds after i shift, it sounds cool but is it normal?
Ghost Ride The Whip!!!
just a leak somewhere
Threads Similar to: cold air intake problem. need help quick
| short ram intake or cold air intake????? j/w | Stangbro8994 | V6 Mustangs | 32 | September 18th, 2008 08:20 PM |
| problem with cold start | 6banger96 | V6 Mustangs | 5 | November 7th, 2007 03:49 PM |
| Cold Air Intake quick ? | 00SoSlow | V6 Mustangs | 30 | March 1st, 2007 08:11 PM |
| Cold weather problem? | 04Pony | 99-04 | 5 | January 21st, 2007 08:56 AM |
| My cold air induction has a problem | SlvrStang | V6 Mustangs | 17 | January 14th, 2007 08:58 PM |
