shift kit
Old June 10th, 2007, 07:54 PM   #1
mmvi is on a distinguished road
Send a message via AIM to mmvi
shift kit
where can i get a shift kit for my car? is it reccomended?
Old June 10th, 2007, 07:55 PM   #2
sbland26's Avatar
2004 Mustang Mach 1
sbland26 is on a distinguished road
Send a message via AIM to sbland26
http://www.moddedmustangs.com/forums...s-vt15137.html
2004 Ford Mustang Mach 1
Old June 10th, 2007, 07:56 PM   #3
thanks
Old June 10th, 2007, 08:02 PM   #4
sbland26's Avatar
2004 Mustang Mach 1
no problem...actually thank green faleen ha he gives good info
Old June 10th, 2007, 08:03 PM   #5
MSTRB8N & MDR8N
BWAL's Avatar
2021 Mustang V15
Quad Turbo with nawz
BWAL has a reputation beyond reputeBWAL has a reputation beyond reputeBWAL has a reputation beyond reputeBWAL has a reputation beyond reputeBWAL has a reputation beyond reputeBWAL has a reputation beyond reputeBWAL has a reputation beyond reputeBWAL has a reputation beyond reputeBWAL has a reputation beyond reputeBWAL has a reputation beyond reputeBWAL has a reputation beyond repute
Originally Posted by sbland26
no problem...actually thank green faleen ha he gives good head
MM 1 am boner crew
Cars and mod list in garage
i like veiny meat sliding between my buttcheeks
Old June 10th, 2007, 08:11 PM   #6
okay, well, the items that are listed, the shift improvement kit stops at 97. I have a 99 auto. any reccomendations? or should i just follow what was given by green faleen?
Old June 10th, 2007, 08:13 PM   #7
sbland26's Avatar
2004 Mustang Mach 1
thankyouuuuu for changing what i said
Old June 10th, 2007, 08:13 PM   #8
MSTRB8N & MDR8N
BWAL's Avatar
2021 Mustang V15
lmao
MM 1 am boner crew
Old June 11th, 2007, 09:22 AM   #9
94v6blkndred's Avatar
02 Turboed Saleen Clone
faster than my v6
94v6blkndred will become famous soon enough
Send a message via Skype™ to 94v6blkndred
hahahah thats fuuuucked
Old June 11th, 2007, 10:01 AM   #10
Juggalo_X's Avatar
2001 Mustang 232/CBR600
14+@Slow
well you can get a tuner and ajust your tranny pressure and get the same effect of a shift kit
Old June 11th, 2007, 03:39 PM   #11
is the shift kit reccomended for daily use or just once and a while playing?
Old June 11th, 2007, 03:42 PM   #12
Juggalo_X's Avatar
14+@Slow
if u drive in snow ur going to regret the shift kit especially with out a traction lock. it will be all over the place you can get the same effect of a ship kit by buying a tuner and just programing the pcm to boost tranny pressure. that way u can reduce it if you need to.
Old June 11th, 2007, 03:51 PM   #13
so you do not reccomend buying a kit. okay, but say I did buy one, could I use it on a regular basis or only once and a while playing around?
Old June 11th, 2007, 03:56 PM   #14
Juggalo_X's Avatar
14+@Slow
once its installed, its there no matter what. it will shift firm all the time.
Old June 11th, 2007, 04:01 PM   #15
okay. the shift kit concept was just introduced to me, and its a whole new concept i am trying to learn about. ive been reading up on it, and people have said that using the shifter to upshift/downshift a lot hurts your tansmission, and others say that it wont do a thing. im just trying to find out whats what before i go buying something work 500 + dollars.
Old June 11th, 2007, 04:07 PM   #16
Juggalo_X's Avatar
14+@Slow
using the stock shifter wont hurt it shifting otherwise ford wouldn't have given u the ability, however not shifting at the right rpm will hurt it if u hang in the red line. also buying an after market shifter will give you better selection.
Old June 11th, 2007, 04:10 PM   #17
so, basically, if i get a shift kit, for my automatic, i can use it whenever i want (upshift and downshift) without damage to my car? (in your opinion)
Old June 11th, 2007, 04:12 PM   #18
Juggalo_X's Avatar
14+@Slow
no getting an after market shifter will let you do that and still if u down shift from 4th to 2nd at 4500 rpm say bye bye tranny.
Old June 11th, 2007, 04:20 PM   #19
an aftermarket shifter? such as the stuff that was given to me in the first link up above? the converter, shift kit, and shifter? i dont understand what the difference is between the aftermarket shifter alone and the shift kit?
Old June 11th, 2007, 04:22 PM   #20
http://www.bmracing.com/index.php?id...bcat=1&pid=356
Threads Similar to: shift kit
Won't shift into 4th Dallas01GT 99-04 3 August 13th, 2007 03:55 PM
Shift kit NEED HELP! theyanks904 V6 Mustangs 7 July 28th, 2007 10:29 AM
shift kit justinsstang V6 Mustangs 7 May 17th, 2007 12:02 AM
TC and shift kit Tony_90fox 5.0 Mustangs 0 November 27th, 2006 06:53 PM
