ATF + Oil Change Via Disptick
So today I tried to change my ATF and motor oil using a transfer pump via the dipstick tube, here are my results and questions for you guys:
1) The ATF change went smoothly. I was able to get about 4 quarts out before the suction tube went dry. I added the pretty much the same amount I pulled out, started the car, and got it to warm up a bit before taking it for a spin. The shifting became a little bit stiffer but you can feel a bit of improvement. However, when I looked under the car I noticed that there is a bolt / screw that goes into the rear of the transmission (driver side) and it is leaking few drops. Who knows what that bolt is for? And what is a good compound to use to create a gasket in that area of the tranny? 2) For the oil, I was unable to get the tube through the disptick. I feel that there is something blocking the tube (the tube is pretty fine, hence it did fit though the tranny dipstick tube). Any idea why? Thank you! |
you used ATF in your oil crankcase?
say it aint so...
why didn't you just drain it from the oil drain plug at the bottom of the pan like a normal person
![]() 95 Civic Ex, FnF1's, Morimoto Mini h1 retrofit, GSR, bbk intake, BDL tb, 57trim t3/t4 8psi, 297whp 96 Civic Ex 2dr, G3 HID retrofit, FnF type 1's, Si cluster, Obd1 Z6 swap |
what i'm thinking happened is he changed his oil and his ATF.
he drained them from the bottom and wants to fill them from the top... with the ATF actually it's not a bad idea (it keeps you from having to buy a pump and open up the tranny and fill there...) but obviously not the recomended way.... with your oil change... dude thats just damn lazy, open the valve cover cap and pour it in....
So this guy and his friend were like wanna race? i was like :stupid- the light turned and we and I went and his friend was like you got and I was like and went home and his wife. The End
#5 | |
Re: ATF + Oil Change Via Disptick
that is the wrong way to change the tranny fluid. i didnt change all of it and it just mixed the new fluid with the old shitty fluid still left in the tranny and converter and #2 dude WTF did u try to do with the engine? use the oil drain plug thats the reason it was put there. I see bad things in your future if you keep apply your mechanical wizardry to your car lol
#6 | |
Maybe I didn't explain myself correctly. I was trying to drain the oil through the dipstick, not fill through there! Pump suction gets more oil out than drain plug. Mainly because of the oil pan design.
I never had a problem with inserting the suction tube done the dipstick in my other cars. I wonder what is keeping the pump suction hose from reaching the pan... Also, any idea what that screw is on the rear housing of the tranny? |
#8 | |
Benz recommends that method. This is how I got used to it.
#10 | |
its one step up from washing cars haha id be worried about missing oil if i pumped it out by hand.
And that is what I am discovering... I was actually happy that I wont have to go under the car since the filter is very accessible. Guess I was wrong
#12 | |
Threads Similar to: ATF + Oil Change Via Disptick
| Oil disptick on GT | DanTheMan | 99-04 | 14 | November 6th, 2007 05:24 PM |
| how do i change my ip | nba1341 | The Clubhouse | 1 | August 13th, 2007 10:17 PM |
| change it up | kaizerdan | Visual | 12 | January 11th, 2007 06:15 PM |
| name change | QuEeNiEsTaNg | V6 Mustangs | 1 | December 17th, 2006 07:37 PM |
