Vibration at low RPMS..... hmm
Old June 14th, 2007, 08:38 AM   #1
Ole Yeller is on a distinguished road
Ok here's the scenario ladies....
04 V6 auto, when i'm driving and cruising speeds (45+) i have no problems, runs like a champ (minus the steering rack bushing's being destroyed, warranty repair replacing the whole rack... )
when i am at lower speeds (30 or below) and just cruising, like in my neighborhood or back roads... there is a vibration that feels like it's coming from the rear... it only happens at the lower speeds or lower RPMS and in the lower gears.... if i'm in 4th or 3rd at low RPMS no problem, mainly its when i'm in second..... don't know if that makes sense it's kinda the best i can explain it...
i just recently had the tranny flushed by my local shop and it did improve but is definitly still there....
know problems in the rear are a blown driver's side rear shock (tokiko's on the way!) besides that no issues....
thoughts?
Old June 14th, 2007, 11:03 AM   #2
Juggalo_X's Avatar
2001 Mustang 232/CBR600
14+@Slow
Re: Vibration at low RPMS..... hmm
thoughts?
have your rear end checked u could have a bearing gone, in turn that will chew ur rear end up. or you could have a bad u-joint.
Old June 14th, 2007, 12:34 PM   #3
The George Forman of Keepers
JASonic's Avatar
JASonic is a name known to allJASonic is a name known to allJASonic is a name known to allJASonic is a name known to allJASonic is a name known to allJASonic is a name known to all
iTrader: 20 reviews
Send a message via AIM to JASonic
Im sure you did, but did you consider all the simple shit? Tire balance and soforth?
Old June 15th, 2007, 02:21 AM   #4
Tree Fiddy Z
Breakout's Avatar
2006 Nissan 350Z
Breakout is a jewel in the roughBreakout is a jewel in the roughBreakout is a jewel in the rough
Send a message via AIM to Breakout
If it's only in lower rpm's then it could be gear rollover. but if it didn't happen before...then this is an unlikely problem. Have your tires balanced and go from there
Old June 15th, 2007, 07:29 AM   #5
didn't happen before??
it's happened since i've owned the car (3 whole weeks)
to me honestly it feels like the carwants to shift but doesn't want to shift, it's strange...
i'm no good at diagnosing autos... i'll get a balance and rotate when i get the rack work done.
So this guy and his friend were like wanna race? i was like :stupid- the light turned and we and I went and his friend was like you got and I was like and went home and his wife. The End
Old June 15th, 2007, 11:38 AM   #6
Juggalo_X's Avatar
14+@Slow
OH lol u got a rack problem y didnt u say so, thats most likely the issue. and they will give u an alignment when u get the rack fixed but be sure to get a tire balance just in case if all that and its still there ur rear end probably has a sloppy bearing and its causeing the backlash to be off by a bit.
Old June 15th, 2007, 06:44 PM   #7
2000 Mustang V6
El_Cangri will become famous soon enough
Send a message via AIM to El_Cangri Send a message via MSN to El_Cangri
jugg he did wrote about the rack problem... and yes it's the rack... if u change it and its the same then get ur rear end check.... but then i bet its the rack
Originally Posted by Fryrice
One time I stuck my dick in my own butt by accident.
Dont laugh it was dark in the room.
Old June 15th, 2007, 06:51 PM   #8
i thought it may be an alignment problem as well, i figured they would do that with the rack, if i still have the problem then i'll start exploring other options....
moving this weekend so after toinight i wont be posting for a while, but i'll be sure to put pictures of Ole Yeller at her new home!!
talk to you soon!
Old June 15th, 2007, 06:53 PM   #9
2000 Mustang V6
k see ya brother
Threads Similar to: Vibration at low RPMS..... hmm
7500 rpms? matfernan1 99-04 10 June 14th, 2007 02:36 PM
Ford C-6 rpms dr.gonzo! 5.0 Mustangs 7 June 9th, 2007 03:03 AM
HELP, Car shakes bad over 2,800 rpms YNOT 5.0 Mustangs 18 April 16th, 2007 07:38 PM
rpms jumping jh3rlh 5.0 Mustangs 4 March 26th, 2007 03:08 PM
dropping rpms rocket 5.0 Mustangs 6 August 21st, 2006 10:46 PM
