reverse knock
Old June 14th, 2007, 11:38 AM   #1
The George Forman of Keepers
JASonic's Avatar
JASonic is a name known to allJASonic is a name known to allJASonic is a name known to allJASonic is a name known to allJASonic is a name known to allJASonic is a name known to all
iTrader: 20 reviews
Send a message via AIM to JASonic
reverse knock
I had asked about this once before and got a good answer here. I hear a knock whenever I put it in reverse. Well, now its starting to do it at random points in forward gears...
what was the name of that seal or whatever I need to change? I think somebody said it was easy to swap out too. I think Im going to do it this weekend. I'll drag my laptop into the garage when I do it and hope somebodys online incase I F* it up and need help.
Can someone tell me what the deal is????
Old June 14th, 2007, 12:09 PM   #2
JSapit is on a distinguished road
the driveshaft u-joint.
Old June 14th, 2007, 12:22 PM   #3
02ponypackage's Avatar
02ponypackage is on a distinguished road
means your trans is probably F'd and so is the amount you'll spend...takes about 30min to get the trans out if its a Manual...i got mine fully rebuilt for 365$ which is a real good deal....Autos will be a real pain and more expensive...then a manual build...also mine was built as a side job not a shop...but the guy who did it knew his shit and wanted to make extra money then doing it at his job lol nothing wrong with that for me
just a V6 with a bad belt slip under the hood
Old June 14th, 2007, 12:50 PM   #4
Juggalo_X's Avatar
2001 Mustang 232/CBR600
14+@Slow
+1 if u hear a clunk when u put it in gear from park 99% of the time its a sloppy u-joint or a sloppy pinion bearing and seal. or both if your really un lucky.
Old June 14th, 2007, 01:28 PM   #5
chevy_killer's Avatar
2009 v6 Mustang
chevy_killer is on a distinguished road
Send a message via AIM to chevy_killer Send a message via Yahoo to chevy_killer
Re: reverse knock
+999999999991 with everyone else...its your ujoint.....ujoints are not hard at all to change...if you cant change a ujoint without messing something up then just step away from the car forever....jk...but seriously it is super easy to do...its just 2 bolts take the drive shaft off take old one out put new one in put drive shaft back on put bolts back in and your done....it shouldnt take you no longer than an hour to do both
The LS1 was finally subjected to a paternity test, and it's daddy was to '03 Cobra
Old June 14th, 2007, 01:59 PM   #6
JASonic's Avatar
iTrader: 20 reviews
Re: reverse knock
Do you have to "torque" any bolts to a specific pound? Thats where I freeze up. If its just a matter of taking it off and putting it back EXACTLY like it was, I'd be willing to give it a shot. I need to find a way to get the rear end off the ground enough to safely work under it. Maybe I'll get some ramps. I hate using jack stands. I get "puss" when it comes to these things because once its apart, its not like I can just drive it up somewhere with it in peices to have somebody put it back together.
i just moved into my house that was finished being built in March. I have a 3 car garage and NO excuses now to start doing these things more for myself now. I need to put that epoxy shit on the floor before I ruin it though.
Shit Chevy, if its real easy, I'll wait till your in the area for something and I'll pay you to do it. Better than paying some butthead down the street and I may learn something in the process!
Old June 14th, 2007, 02:21 PM   #7
Juggalo_X's Avatar
14+@Slow
Re: reverse knock
tighten them down till u cant tighten any more. its not a gasket so u dont have to worry about over torquing it and as long as u dont snap the bolt off ur good,
Old June 14th, 2007, 03:43 PM   #8
2009 v6 Mustang
Re: reverse knock
i live about ~45-1hr away from tampa (depending on how i drive)...but a really good investment for you if your going to do a lot of this stuff your self is go to autozone or discount and get you a copy of the haynes repair manual...but it says in the haynes book to torque them down 70-90 ft pounds
Old June 14th, 2007, 04:23 PM   #9
97TunedMustang's Avatar
97TunedMustang is on a distinguished road
Send a message via AIM to 97TunedMustang
i was under the impression the u-joints were pressed into place..
95 Civic Ex, FnF1's, Morimoto Mini h1 retrofit,
GSR, bbk intake, BDL tb, 57trim t3/t4 8psi, 297whp
96 Civic Ex 2dr, G3 HID retrofit, FnF type 1's, Si cluster, Obd1 Z6 swap
Old June 14th, 2007, 04:27 PM   #10
2009 v6 Mustang
no
Old June 14th, 2007, 07:56 PM   #11
it's an easy fix, and a new u-joint shouldn't cost you more than 20 or 30 bucks. you'll be able to unbolt and re-bolt no problem, like juggs said, tighten it until it won't come loose anymore.
Old June 14th, 2007, 09:50 PM   #12
joka187's Avatar
2000 Drop Top
joka187 is on a distinguished road
Send a message via Yahoo to joka187
it could possably be a bad motor or tranny mount... i had a mazda truck that when i reversed it knocked like crazy and come to find out it was a bad motor mount
Threads Similar to: reverse knock
spark knock mustangboy8909 96-98 1 September 18th, 2007 06:32 PM
knock knock 93fourbangerstanger 2.3 Mustangs 2 August 23rd, 2007 12:09 AM
Knock Knock MSTGGT00 99-04 3 May 31st, 2007 01:14 PM
Rod knock 5.0 Calypso 5.0 Mustangs 12 May 7th, 2007 09:16 PM
Reverse...wtf? marcfiebka 99-04 8 April 20th, 2007 05:18 PM
