System too lean (fail emissions)
Old June 14th, 2007, 02:29 PM   #1
Pharoh is on a distinguished road
i just had the egr sensor replaced a few months ago for haveing excessive flow and ford doesnt make the original sensor anymore its a new plastic one that suppose to better but i was told the service soon light would more than likely stay because of the part swap but i went in today for emissions and failed error code (p0171 system too lean) does anyone know exactly what this is or does it having anything to do with the newer part that was put in.
edit: i also have a cracked manifold i have yet to get fixed could that be the problem?
2000 Mustang V6 5spd. (deceased)
1988 Monte Carlo SS (cruiser)
1993 Mustang GT 5spd (bruiser)
Old June 14th, 2007, 02:49 PM   #2
Juggalo_X's Avatar
2001 Mustang 232/CBR600
14+@Slow
Get a new air filter, New plugs, Run some injector cleaner or get them professionally cleaned, New fuel filter and get an oil changed. If you have not already done this. If that does not solve your issues. its time for some new O2 sensors.
Old June 14th, 2007, 03:10 PM   #3
i had a tune up not too long ago and the plugs where changed after the tune up maybe less than 2 months ago how much is the 02 sensor going to run and are there any syptoms that i would notice that could let me know this is the problem
Old June 14th, 2007, 03:22 PM   #4
Juggalo_X's Avatar
14+@Slow
Check for a vacume leak after the MAF this can cause a system to lean because your getting un maffed air into the intake system. if that checks out replace the o2 sensors they range any where from 40-100 bux.
Old June 14th, 2007, 07:06 PM   #5
im also getting some electrical problems that just started after i lef the emission station, my cd deck started smoking i have power to windows and radio with no key in the ignition unplugged amp no problem but amp isnt plugged into anything but stereo and power to batt. rewired amp to fuse in fuse box same problem emission station says it couldnt have been there fault anyone have any ideas i have rewired radio and amp same problem took amp and speakers out already but i want to know y its haveing this problem now and not ever before.
Old June 14th, 2007, 07:15 PM   #6
provinggrounds is on a distinguished road
sounds like something is SERIOUSLY shorted.
Old June 14th, 2007, 07:29 PM   #7
i figured that but am i wrong to assume that this is the fault of the emission station or is it possible that this problem could have just developed because i had two tweleves and an amp hooked up to my system.
Threads Similar to: System too lean (fail emissions)
lean really lean plaese help 331 stroker stangzilla 331 94-95 8 January 30th, 2010 06:58 PM
Firefox /fail TurboLX The Clubhouse 12 October 4th, 2007 06:02 PM
01 gt emissions system problem? RTY 99-04 11 August 22nd, 2007 01:43 PM
fail safe problem! msolaas1 2005 - 2010 7 May 24th, 2007 08:49 PM
Lean! Clayhistorian V6 Mustangs 5 April 24th, 2007 11:07 AM
