Surging and poor Throttle Response after mod - Page 2
Old June 15th, 2007, 06:38 PM   #21
Ole Yeller is on a distinguished road
Cangri... awesome answer brother...
So this guy and his friend were like wanna race? i was like :stupid- the light turned and we and I went and his friend was like you got and I was like and went home and his wife. The End
Old June 15th, 2007, 06:40 PM   #22
2000 Mustang V6
El_Cangri will become famous soon enough
Send a message via AIM to El_Cangri Send a message via MSN to El_Cangri
These kind of mods r my thing i know my shit about injector maf and other
Originally Posted by Fryrice
One time I stuck my dick in my own butt by accident.
Dont laugh it was dark in the room.
Old June 15th, 2007, 08:24 PM   #23
02ponypackage's Avatar
02ponypackage is on a distinguished road
the air/fuel will be thrown off...regardless of the intake being ported/polished...your taking in more then usual air...even from just a CAI alone....so it will run better when the car is tuned for the correct settings over the stockers.....this has nothing to do with the MAF sensor...you dont make enough power and take in enough air to worry about that
just a V6 with a bad belt slip under the hood
Old June 15th, 2007, 11:26 PM   #24
2000 V6
ByPopularDemand is on a distinguished road
Send a message via AIM to ByPopularDemand Send a message via MSN to ByPopularDemand
He doesnt need a tune for those mods, he can get away without it
2000 V6 vert
Mac LT headers, Mac O/R H-pipe, Mac CAI, ASP 25% underdrive pulley(r.i.p), SCT tune, 8.8 rear and 4.10 gears.
Old June 18th, 2007, 06:07 PM   #25
Aviatrix is on a distinguished road
Ah HA! I found it.
After putting on the Headers and the exhaust I found that one of the spark plugs had cracked. It appears that those NGK iridium plugs are extremely fragile.
Some casual conversation at the Auto Parts shop was quite enlightening. The counter nerd said that they have a very high return rate on those because they are so delicate. It seems that they have a high breakage rate from the factory and just any bump at all will cause them to fracture. They are MUCH more fragile than a standard platinum plug. His comment is that they probably have one in every 5 sets that is broken by the time it gets to the customer.
I had completely missed this because it would run fine with the lead tester and every plug was firing and all the wires checked perfect. Same case with the Mass Air and the oxy sensor on the exhaust. All tested great on the stand. BUT... on the road under load it would just start missing and backfiring like a demon. I decided to just start from ground zero and pulled out all the plugs and #6 just fell apart in my hand when I took it out.
Hope this helps someone down the road (so to speak).
Thanks everyone for your suggestions and comments. I hope this solves the problem. I'm off to take it for a long ride in the hills just to make sure.
Old June 18th, 2007, 08:57 PM   #26
2000 Mustang V6
now get a PnP (port and polish) to take advantage of the new bigger t.b
Old June 18th, 2007, 10:33 PM   #27
2000 V6
And I dunno how I overlooked that, I cracked one when I was doing my headers
2000 V6 vert
Old June 19th, 2007, 08:06 AM   #28
awesome! congrats!!
i never understood using the iridium plugs myself...... or plats....
copper is a better conductor than plat, so yah i may have to change it sooner, but i think i'll deal with the couple of bucks...
and the only point of those multi plugs (2 and 4) is that you don't have to change them as often, plus they come gapped from the factory so you can't even check them!
as we all know electricity takes the path of least resistance (shortest) so it doesn't matter if you have 4 prongs, it's only hitting on one of them. the point of having 4 is so that when the first one gets out of gap, it fires on the next, so on and so forth....
save your money... NGK coppers....
Old June 20th, 2007, 01:19 PM   #29
I'd love to get a PnP, but my finances are limited for at least the rest of the year on this project. I can do a little at a time here and there, so I'm done for a while.
On the plugs - I have no idea what you are talking about with the Multi-plugs. The NGKs are standard configuration with electrode/anode just like a traditional plug. The only difference is the shape of the electrode. It has a smaller diameter with a ball on the end, but not 3 or 4.
The whole idea with the iridium plugs is that they spark hotter to provide a more complete burn. And, as I understand it, they also tend not to corrode or foul as easily as platinum or standard copper.
Time will tell.
Old June 20th, 2007, 03:13 PM   #30
00 V6 & 09 GT
13.37@104.4mph--BONE stock GT
DO NOT USE PLATINUM PLUGS
use coppers
autolite copper or motocraft...NGKs are w/e
the tr5s are good for bolt ons you dont need a step colder for just bolt on mods though...its pointless
nitrous
s/c or turbo
and i would say 280rwhp you should use a step colder
seeing that almost no v6 on the site is pushing that much power yet aside from maybe 3-4 we should all be using stock plugs
[SIGPIC][/SIGPIC]
Acmillr loves me
Old June 20th, 2007, 03:15 PM   #31
00 V6 & 09 GT
platinums are for cars with a lot of miles really...or when a car thats needs more oil burnt they'll use hotter then stock plugs such as platinum
do not ever buy a bosch spark plugs
if your using double platinums or platinum 4s your an idiot.... you might think they look cool but they're bad for your car
bosch str8 up SUCKS when it comes to spark plugs
[SIGPIC][/SIGPIC]
Acmillr loves me
Old June 20th, 2007, 03:27 PM   #32
does this mean i don't get the Christorres8 seal of approval???
Av. i was simply saying that iridium plugs are... well... a waste... anything but a simple copper plug is a waste in my opinion.. i don't drive a nascar, i drive a V6 mustang... E.O.S.
Old June 20th, 2007, 05:01 PM   #33
The George Forman of Keepers
JASonic's Avatar
JASonic is a name known to allJASonic is a name known to allJASonic is a name known to allJASonic is a name known to allJASonic is a name known to allJASonic is a name known to all
iTrader: 20 reviews
Send a message via AIM to JASonic
so whats the stock plug that Ford thinks is best??
Old June 20th, 2007, 05:09 PM   #34
2000 Mustang V6
they recommend motorcraft..
Old June 20th, 2007, 09:00 PM   #35
myPONYisHARD is on a distinguished road
how much would it be to port and polish my manifold also where would i go to get this done
Boost in the works
Old June 20th, 2007, 09:05 PM   #36
2000 Mustang V6
a machine shop if u have time u could DIY it's easy let me check 4 the link...
***EDIT***
PnP
Threads Similar to: Surging and poor Throttle Response after mod
poor throttle responce on 4.0 al101e 2005 - 2010 6 June 25th, 2007 02:06 PM
minor throttle response issue usmcsawgunner 5.0 Mustangs 12 May 29th, 2007 02:13 AM
throttle response/computer 95StangSVT 94-95 1 May 7th, 2007 02:20 PM
Throttle Response GTJUNKIE 2005 - 2010 10 December 6th, 2006 07:42 PM
Throttle Response Dennis 96-98 8 September 28th, 2006 12:12 AM
