trouble codes '94 3.8
Anybody got info on trouble codes for the 94. I have a major short in one of my components and I'm trying to retrieve the last codes but no one seems to know how.
#2 | |
Re: trouble codes '94 3.8
Ford owners can check their check engine light using the diagnostic connector located at the engine compartment by the fender near the battery. Getting the obd1 codes need a couple of tools: a 4 inch long gage 16 jumper wire and a 12 volt test light. Both tools are hooked up to the diagnostic connector and when the ignition key is turned on (without starting engine) the codes will begin to flash in the test light, not in the dash panel. If there is no code, you will normally get code 11 or 111. On Fords, there are 2 test modes, the KOEO (key on engine off) and the KOER (key on engine running). Both test modes should be used to get the accurate evaluation of the stored fault codes.
Threads Similar to: trouble codes '94 3.8
| Trouble Codes | GTsetGO | Modular Mustangs | 15 | December 4th, 2007 03:13 PM |
| trouble codes...HELP!!! | sleezy | 96-98 | 6 | July 10th, 2007 10:06 PM |
| SCT Trouble Codes! What to do? | wormster00 | 2005 - 2010 | 10 | July 6th, 2007 03:14 PM |
| Trouble codes | bigbadtalontsi | 5.0 Mustangs | 3 | March 30th, 2007 12:26 AM |
| trouble codes.... | stang fanatic | General Tech | 0 | July 6th, 2006 11:36 PM |
