still heating up.....
Old June 19th, 2007, 11:38 PM   #1
lwhitetrash88l's Avatar
2004 Mustang
lwhitetrash88l is on a distinguished road
Send a message via AIM to lwhitetrash88l
so i replaced my thermostat today with a 180 degree FailSafe and when kicking the engine up a lil bit to about 90ish it still gets hot.....around town driving though is cooler.....so im thinking maybe the radiator is going possibly? i dont know....any suggestions?
Old June 19th, 2007, 11:39 PM   #2
Tree Fiddy Z
Breakout's Avatar
2006 Nissan 350Z
Breakout is a jewel in the roughBreakout is a jewel in the roughBreakout is a jewel in the rough
Send a message via AIM to Breakout
is your radiator fan working properly?
Old June 19th, 2007, 11:41 PM   #3
2004 Mustang
it kicks on and off......i dont know about properly though lol how would i check if its working properly?
Old June 20th, 2007, 12:09 AM   #4
Tree Fiddy Z
Breakout's Avatar
2006 Nissan 350Z
whether or not the fan(s) spin. I've never seen a radiator go bad and only let your car overheat while stationary. What do you mean when you kick your engine up a little bit to 90ish? what's 90ish?
Old June 20th, 2007, 11:09 AM   #5
Juggalo_X's Avatar
2001 Mustang 232/CBR600
14+@Slow
Having the lower thermostat in you should tune ur fan to come on at 180 now that will help. other wise you have a block in your cooling system and need a flush and fill and if that dont help then you have a bent valve or a warped head. that can cause over heating. I would suggest trying a colder plug, this will bring the temp down. maybe ur running plugs that are to hot.
Old June 20th, 2007, 03:42 PM   #6
stephen has a spectacular aura aboutstephen has a spectacular aura about
Re: still heating up.....
If I understand this, you are saying the engine runs cool around town but heats up at speed on the road (90 mph?).
This means as in the previous posts that the fan is working OK, but you could have some flow restriction in the cooling system.
Perhaps you need a new water pump or the radiator is partially clogged.
Also be sure to bleed the air out of the cooling system.
Better get this sorted out soon or you will be redoing the head gasket job.
Old June 20th, 2007, 03:45 PM   #7
By the way, I don't see any advantage to a 180 degree thermostat compared to stock, since the thermostat is fully open when the engine is running above normal operating temperature.
Old June 20th, 2007, 03:56 PM   #8
Juggalo_X's Avatar
14+@Slow
running cool in town but heating up when hitting highway might be a sign or running plugs that are to hot. not passing the heat off from the combustion chamber to the cooling system fast enough or effectively.
Old June 20th, 2007, 05:20 PM   #9
2000 Mustang V6
El_Cangri will become famous soon enough
Send a message via AIM to El_Cangri Send a message via MSN to El_Cangri
strange.... at 90mph u could run at normal temp even with flow obstroction unles u have all ur car covered when running
could be damage sensor?
or water pump not working correctly making the flow slower than normal or a clog.
i dont know i think it could be a sensor WHO THE FUCK COULD RUN HOT AT 90MPH!!!
Originally Posted by Fryrice
One time I stuck my dick in my own butt by accident.
Dont laugh it was dark in the room.
Old June 21st, 2007, 04:04 PM   #10
2004 Mustang
Can i do the radiator flush myself? or do you recommend taking it to a shop to do? also how do i bleed the air out of the system??? it might be that becuase i never heard of such a thing....and what kind of plugs do you suggest i run on the car? one last thing.....what sensor could it be?
Old June 21st, 2007, 05:36 PM   #11
2004 Mustang
Old June 21st, 2007, 05:38 PM   #12
Juggalo_X's Avatar
14+@Slow
u can do it ur self but i suggest a pro does it if you really think you have a blockage because they have a machine that forces the old coolant out and this may free any obstruction /air in the system.
Old June 21st, 2007, 05:46 PM   #13
2004 Mustang
what about bleeding the air?
Old June 21st, 2007, 05:49 PM   #14
Juggalo_X's Avatar
14+@Slow
bu the fuel rail and alternator there is a air bleeding plug if u look on the rad cowl it will even tell you where they air bleeding plug is and YOU HAVE TO REMOVE IT to properly flush ur cooling system or u will trap air and damage your engine
Old June 21st, 2007, 05:58 PM   #15
2004 Mustang
oh boy......when are you suppose to do this.....cuz maybe i already have damaged it?
Old June 21st, 2007, 05:59 PM   #16
2004 Mustang
and how much does a flush usually cost?
Old June 21st, 2007, 08:39 PM   #17
2004 Mustang
anyone?
Old June 21st, 2007, 08:47 PM   #18
2000 Mustang V6
idk how a flush cost. It has to be cheap tho
Old June 22nd, 2007, 02:53 AM   #19
2004 Mustang
any other thoughts guys?
Old June 22nd, 2007, 03:42 AM   #20
2000 Mustang V6
well check 4 all we mention...
Threads Similar to: still heating up.....
Over Heating Problem? Fox2102 V6 Mustangs 11 November 9th, 2007 11:25 PM
A/C and over heating problems? JONJON 5.0 Mustangs 3 October 28th, 2007 11:22 PM
engine heating up slowmotion00 Modular Mustangs 18 October 17th, 2007 11:59 PM
over heating jersey98gt 96-98 40 September 20th, 2007 02:54 PM
over heating? kreil45 5.0 Mustangs 8 May 24th, 2007 04:47 PM
