Service engine light wont go away!!!!
Old June 22nd, 2007, 05:48 PM   #1
The soul stealing Ginger
dgt_mustang's Avatar
2001 Mustang 3.8l
dgt_mustang is a jewel in the roughdgt_mustang is a jewel in the roughdgt_mustang is a jewel in the rough
Send a message via AIM to dgt_mustang Send a message via Skype™ to dgt_mustang
okay, recently after installing a CAI my cars service engine light went off. the code for it was the oxygen sensors, i replaced the one that is said was burnt out but i believe it continued to say the same one was broken as well as another one. is this a result of the CAI or my car reaching 100,000 miles? I just reached 98,000. please help.
Old June 22nd, 2007, 06:03 PM   #2
Juggalo_X's Avatar
2001 Mustang 232/CBR600
14+@Slow
Re: Service engine light wont go away!!!!
did you have the fault code cleared with an OBD2 tool? if not it will remain there until you clear it.
Old June 22nd, 2007, 06:09 PM   #3
aj28 is on a distinguished road
Like Juggalo said, you have to clear your codes to make them go away. Unfortunately while most AutoZone stores would be more than happy to read your codes, I don't believe they're exactly "allowed" to erase them for you due to ethics and whatnot. You can pick up a scanner pretty cheap though ($60-80 for a mini with erase).
The alternative is that your CAI threw something off. Make sure all the gaskets and rubber connectors are sealed up tight so you're not leaking or anything. Also, what brand is it? A bad filter could likely set off your sensors.
The idea that your mileage throwing it off is unlikely though, especially after you already replaced the one. My '98 has over 140,000 and I've never had issues like the ones your seeing.
Old June 22nd, 2007, 06:40 PM   #4
2001 Mustang 3.8l
i went back to autozone where they read the codes and they did erase them but the code popped back on after Driving a day or two.
the CAI is from americanmuscle.com (mustang tuning magazine)
Old June 22nd, 2007, 06:42 PM   #5
Juggalo_X's Avatar
14+@Slow
then you have another sensor that is bad or a vaccume leak in the intake system. can you tell me the exact error code?
Old June 22nd, 2007, 06:49 PM   #6
2001 Mustang 3.8l
How would i go about finding the vacume leak? i know im probably going to replace another O2 Sensor just to see the outcome buty how do you go about finding the leak? ill get the code from autozone and post it on here tomorrow.
Old June 22nd, 2007, 06:51 PM   #7
Juggalo_X's Avatar
14+@Slow
use an unlit propane torch and open the valve so it seeps out and run it around ur intake if ur idle increases you have a leak in that general area. u can also use TB and Choke cleaner spray for this. do it outside in a ventalated area so u dont die from the fumes, thats a tip thats kept me kickin lol
Old June 22nd, 2007, 06:56 PM   #8
2001 Mustang 3.8l
lol alright, I'll attempt to try that, thanks, look for the code on here tomorrow, ill probably replace the sensor tomorrow to.
Get another job, get 2 more jobs, get your own place, work, live, fuck, eat, life, happy.
Old June 22nd, 2007, 06:57 PM   #9
Juggalo_X's Avatar
14+@Slow
k ill check back when i get an email with a reply
Old June 22nd, 2007, 07:36 PM   #10
2000 V6
ByPopularDemand is on a distinguished road
Send a message via AIM to ByPopularDemand Send a message via MSN to ByPopularDemand
I thought if you fixed the problem, after enough driving cycles the light would go off
2000 V6 vert
Mac LT headers, Mac O/R H-pipe, Mac CAI, ASP 25% underdrive pulley(r.i.p), SCT tune, 8.8 rear and 4.10 gears.
Old June 22nd, 2007, 08:18 PM   #11
Juggalo_X's Avatar
14+@Slow
It takes 3 Driving cycles to make the code pending and then 40 warm up periods to get rid of an O2 code from the freeze frame and pending DTC storage area on the pcm
Old June 24th, 2007, 09:00 PM   #12
MustangMo's Avatar
1993 1.8 Acura Integra Ls
Slow
MustangMo is on a distinguished road
Send a message via AIM to MustangMo Send a message via Yahoo to MustangMo Send a message via Skype™ to MustangMo
I have the same problem, but i don't understand how people were sayin to get it to go off.
{Burn Rubber Not Your Soul}
Old June 24th, 2007, 10:47 PM   #13
00 V6 & 09 GT
13.37@104.4mph--BONE stock GT
did you hook the CAI up correctly 100%....if you messed up the MAF or the other sensor it's a good chance it'll go off
you could always get a XCAL2 and clear it
[SIGPIC][/SIGPIC]
Acmillr loves me
Old June 24th, 2007, 10:51 PM   #14
2000 Mustang V6
El_Cangri will become famous soon enough
Send a message via AIM to El_Cangri Send a message via MSN to El_Cangri
lol i know some asshole that confused one of the sensors with the bypass..
double check everything... i wouldn't erase the code with a xcal or any other tuner... get the code and post it here so we can tell u if its safe to erase it
Originally Posted by Fryrice
One time I stuck my dick in my own butt by accident.
Dont laugh it was dark in the room.
Old June 25th, 2007, 04:19 PM   #15
MustangMo's Avatar
Slow
How do i get the code?
Old June 25th, 2007, 07:26 PM   #16
Racerchik02's Avatar
Racerchik02 will become famous soon enough
Send a message via AIM to Racerchik02 Send a message via Yahoo to Racerchik02
This may sound ridiculous...but make sure your gas cap is tightened correctly...a lot of times the check engine light is just that.
Preview for Street Racers Gone Wild - Putfile.com
"The Official Hottie of MM"
The Future Mrs. Mofobucs
Old June 25th, 2007, 09:01 PM   #17
2000 Mustang V6
true.. happened to me one after cleaning the t.b and it was the cap... when not seal perfect it will send a ligth
Old June 26th, 2007, 03:32 PM   #18
MustangMo's Avatar
Slow
No its not my gas cap checked that its somethin to do with my cai or than its somethin else. But its just came on after i put the cai in, so i am guessing it has something to do with that.
Old June 26th, 2007, 04:01 PM   #19
MustangMo's Avatar
Slow
Ok i think i found the problem, the hose that goes from ur cai to were ur oil pan or whatever u wanna call it, was disconected, the problem is that hose is to short n i rele had to stretch it to get it on n it just pulls out, so i am gonna try to get another hose. What do ya'll think?
Old June 26th, 2007, 04:02 PM   #20
Juggalo_X's Avatar
14+@Slow
yes it will light your check fuel cap light :wink sounds to me like this isnt the case
Threads Similar to: Service engine light wont go away!!!!
the dreaded service engine soon light dark-samurai2 V6 Mustangs 26 August 1st, 2007 08:01 PM
Dam Service Engine LIght on AGAIN!!! jrfan4life 99-04 31 March 30th, 2007 10:11 PM
Service engine soon light blinking..... jrfan4life 99-04 26 March 20th, 2007 10:18 AM
Help Me (Service Engine Light) sgrcltpunk 99-04 3 March 10th, 2007 12:57 AM
SERVICE ENGINE SOON LIGHT ROUSHME V6 Mustangs 4 June 15th, 2006 12:31 AM
