U Joint - Forums at Modded Mustangs
post #1 of 22 Old May 15th, 2012, 12:50 PM Thread Starter
Exclamation U Joint
How much will it cost to buy a new one? I'm pretty sure it's the U Joint. The whole car shakes when I slow down.
XSlashDashX is offline
post #2 of 22 Old May 15th, 2012, 12:56 PM
M112'd Sixxer
Shakes when you press the brake pedal or when you left off the gas pedal? Cause shaking while braking is warped rotors.
Sent from my droid using my fingers.
Garage:
1999 Mustang V6 M112 4R70W (Elise) Sponsored by Ortiz Performance
2013 Fiat 500 Turbo C510 (Rosso Rocket)
Fink is offline
post #3 of 22 Old May 15th, 2012, 01:15 PM
99 BLUE V6's Avatar
I paid about $20.00 each. Installed myself So I don't know what labor would cost.
(wholesale price)
99 BLUE V6 is offline
post #4 of 22 Old May 15th, 2012, 01:18 PM
M112'd Sixxer
U joint are one of the hardest pieces to install on a car. ive done a handful and always have a problem getting the last cup seated.
You should only be charged an hour of labor max for a u joint. Less if you take the shaft off yourself and bring it to them.
Garage:
Fink is offline
post #5 of 22 Old May 15th, 2012, 01:47 PM
Efficiency is Performance
izzy1111's Avatar
Yeah u-joints are a PITA to replace. But i dont think they would cause shaking, they do more of a clanking sound on slow downs and speed ups when worn. Just like Fink said, its most likely your rotors (had the same issue), take them to get re-surfaced, and new brake pads while your add it.
'95 4.2L V6 Mustang 5-speed
'13 Fusion
izzy1111 is offline
post #6 of 22 Old May 15th, 2012, 02:00 PM
u joint
U joint will make a cluck noise if they are gone ,they make a clunk noise when you go from park to reverse and also maybe reverse to drive ,vibrating on breaking does not seem like a u joint problem to me, usually you get a vibration when driving along,a good quality u join will cost around 40-50$ dont get a low cost u joint as they are a very important part as they are attached to your driveshaft.If you do not hear a clunk noise and it only vibrates under breaking it is probably your rotors
craigstang1 is offline
post #7 of 22 Old May 15th, 2012, 02:15 PM
maybe its an automatic tranny problem
1989 ford ranger 2.9v6 sold
2000 mustang v6 stolen
2014 mustang v6 daily
Justin_v6stang is offline
post #8 of 22 Old May 15th, 2012, 02:38 PM Thread Starter
Yeah, when I slow down (pressing the brakes) the car shakes. Also when I switch from Park to Drive or Park to Reverse I hear the clank noise.
post #9 of 22 Old May 15th, 2012, 03:14 PM
M112'd Sixxer
Warped rotores and a bad rear u joint.
Garage:
Fink is offline
post #10 of 22 Old May 15th, 2012, 03:45 PM Thread Starter
How much in total will it cost me?
post #11 of 22 Old May 15th, 2012, 03:56 PM
M112'd Sixxer
How much is labor rates in your area?
At my shop it would cost you $200 just on labor + another 100-150 for parts.
Garage:
Fink is offline
post #12 of 22 Old May 15th, 2012, 04:12 PM
HMUSN's Avatar
iTrader: 11 reviews
That is all pretty cheap if you do the work yourself.
Here is a go-by for the u-joint:
How to Change the Universal Joint in a Mustang | eHow.com
and for the rotors i'm too lazy too search so:
loosen wheel lugs
jack up car
place jack stand
remove wheel and lug nuts
Remove two banjo bolts
Take off caliper
(good time to replace pads while you are in here, but skipping those steps for now)
DON'T let caliper hang!
Remove caliper bracket bolts
Pull off rotor. (may need a slight tap with a rubber hammer)
Clean new rotor of all grease
Put on new rotor.
From there take the caliper, take out the brakes, use a c-clamp or a brake tool to put in the piston, put the old pads back in. (good idea to re-grease them)
Put caliper bracket back on
Put caliper back on and grease the banjo bolts
Put wheel back on
Drive off the jackstand while doing one wheeled burnouts in your grandmothers garage.
Don't forget to hit the cat.
HMUSN is offline
post #13 of 22 Old May 15th, 2012, 04:14 PM
I Poop Entirely Way Too Much
If you can remove the axle yourself and have the joint pressed it could be done for under $100.
Nothing says "were dating" like sticking your dick in her.
03_StangGuy is offline
post #14 of 22 Old May 16th, 2012, 10:35 AM
a.k.a. Racecougar
Tang Stang's Avatar
A vise (or even a C-clamp) and three sockets is all it takes to swap out a U-Joint. I definitely wouldn't call it one of the hardest pieces to install on a car.
The axles don't have U-Joints...the driveshaft does.
Rod @ AzzKicker Cars
2004 Ford Mustang GT-The Driver-BBK CAI, PP TB & Inlet, Steeda UD's, SLP LM1, & 3.73's.
1990 Mercury Cougar XR7-The Meth Addict-5.0L DOHC Stroker w/2.1L KB SC.
1995 Ford F150-Mud Toy-5.0L, 4x4, 33's, & Warn 8274 Winch
Tang Stang is offline
post #15 of 22 Old May 16th, 2012, 12:37 PM
Doh! I ment driveshaft.
post #16 of 22 Old May 16th, 2012, 01:30 PM
M112'd Sixxer
Getting the cups seated properly so you can install the snap rings is the hardest part of the install.
Garage:
Fink is offline
post #17 of 22 Old May 16th, 2012, 08:13 PM
stephen is offline
post #18 of 22 Old May 19th, 2012, 05:30 AM Thread Starter
Took my Stang to the shop. Everything been replaced pretty much by the previous owner. New Front end, New U joints. So I have no idea what the problem is now.
post #19 of 22 Old May 21st, 2012, 12:33 PM
My car would shake whe slowing down, turned out to be a wheel that lost the weights.
post #20 of 22 Old May 22nd, 2012, 02:51 PM
I had a u joint put on
I just had 2 u joints put on my car ,they are around 50$ each with tax and 75$ for labour so around 175$ for everything i paid ,get a local mechanic you trust dont go to a place that charges by the book hourly or you will pay twice as much for labour
Human Verification
