engine cleaning.. and other things
Old June 25th, 2007, 04:10 AM   #1
muneris pro ego
Ninjawafers!'s Avatar
97 5.0 Exploder AWD
snow has nuthin on me
Ninjawafers! is a splendid one to beholdNinjawafers! is a splendid one to beholdNinjawafers! is a splendid one to beholdNinjawafers! is a splendid one to beholdNinjawafers! is a splendid one to beholdNinjawafers! is a splendid one to beholdNinjawafers! is a splendid one to behold
Send a message via AIM to Ninjawafers! Send a message via Yahoo to Ninjawafers!
my engine bay is completely covered in dirt.. i want to get it back shining like new.. i have heard to just get engine degreaser and spray the engine down with it then wash it off with a water hose... would that be the best way? i will also be ordering a UDP e piece set w/ belt from vmptuning later today.. and some new coils and livewires when i get paid again.. what is the easiest way to install the UDP set? i also have no clue about installing the coils and shit either... gotta love ex-body men huh? lol
Buy my M90 Kit and my Gears and T-Loc!
MM ZDC - Alaska Base Commander
MM+ Cleavage Club #24
MM Cares Crew / Military Crew
M2C2 President / USCG - OS2
Old June 25th, 2007, 04:14 AM   #2
[8MINUS2]
ESG-642T's Avatar
2002, Ford, v6
ESG-642T is a name known to allESG-642T is a name known to allESG-642T is a name known to allESG-642T is a name known to allESG-642T is a name known to allESG-642T is a name known to all
Re: engine cleaning.. and other things
If you like wasting money go ahead,
To clean it go to a car wash, degrease it and spray it down. :: repeat until a new shine ::
Hi, You can call me Kyle
Random ESG fact: Had a prochamber on his v6 before it was popular.
WTB: v6 BBK valve covers
Old June 25th, 2007, 04:17 AM   #3
muneris pro ego
97 5.0 Exploder AWD
there is no car wash's worth a damn in kodiak lol... and why would i be waisting money on coil packs and livewires? cricket had them and noticed a difference
Old June 25th, 2007, 04:31 AM   #4
[8MINUS2]
ESG-642T's Avatar
2002, Ford, v6
Because its a proven waste of money -
Ask cricket to show you a(an) dyno of his car before and after he added the car. the "sotp" dyno is mostly a mind thing unless you do some really big mod -
Old June 25th, 2007, 10:31 AM   #5
Juggalo_X's Avatar
2001 Mustang 232/CBR600
14+@Slow
No one said they gave you gains its a truer spark a colder spark and a resistance to spark fade. Thats the gains you get its not all about hp i wish you would go around telling every one everything is a waste of cash if it don't give you 100hp and a nos sticker for god sakes. if they were such a waste of money then how come the big boys are running them mr professional? The coil and wires will give you a bit of a crisper throttle and a truer spark there for fuel will be burn more efficiently and if you had an issue with unspent hydrocarbons before then you WILL notice a power difference because you will be burning all of the fuel in the cylinder now and more efficiently. and you cant say you dont gain a truer spark either less resistance = more current flow dude so i dont know where u get off saying u dont get shit from them. then you have a performance coil like accels for example that has 10-15% higher volts going to the plug then then oem. more current = better chance of a arch happening. and after all the plugs need to arch to spark.
Old June 25th, 2007, 10:36 AM   #6
Juggalo_X's Avatar
14+@Slow
P.S. A performance ignition system allows you to open up the spark-plug gap. This demands more voltage to jump the gap, but it usually creates a bit more complete combustion at low engine speeds.
Old June 25th, 2007, 11:01 AM   #7
Juggalo_X's Avatar
14+@Slow
and 3.8 bro if your going to wash under your good use a regular hose and degreaser and cover your coil and alternator with tinfoil otherwise if you get water then them they will internally arch and u will have to wait for them to dry or your car will run like a bad of shit my buddies 95 explorer used to do this every time we washed the engine till he got smart one day and tried the tinfoil trick. and dont use a pressure washer with my experience it has forced water into areas where the sun dont shine on your car and it makes it a lil uncomfortable just like you would be I washed my dads tempo back in the day at skool with a pressure washer and washed the engine too and ruined the TR sensor on the tranny that way. just trying to save yah some pain in the ass and money.
Old June 25th, 2007, 11:32 AM   #8
muneris pro ego
97 5.0 Exploder AWD
aight appreciate it jugg... ill definitely let my coil and alternator dry before i try to run it
Old June 25th, 2007, 01:28 PM   #9
I'm Hella From Nor*Cal
707Stang's Avatar
2008 GTI
14.65 @ 99.83
707Stang is a jewel in the rough707Stang is a jewel in the rough707Stang is a jewel in the rough
What i have learned is to use a fine mist from the hose attachement while the engine is cold. I did it to my truck and it came out great! i learneded that one from another mustang guy. his shit was clean!!!
The Curse 600 CFM Edelbrock, Hookers, Pertronix billet dizzy, Accel coil, GT40 heads, 5.0 h.o, dynomax exhaust, SSBC, FRPP 9mm wires, tci
Old June 25th, 2007, 02:13 PM   #10
2007 Mustang
Kuro has a spectacular aura aboutKuro has a spectacular aura about
wow... Juggalo_X just owned this thread.
[url]www.ctxracing.com[/url]
[url]www.tandlmedia.com[/url]
[SIGPIC][/SIGPIC]
Old June 25th, 2007, 02:16 PM   #11
Juggalo_X's Avatar
14+@Slow
haha now thats sig material lol
Old June 25th, 2007, 02:17 PM   #12
Juggalo_X's Avatar
14+@Slow
good tip ill try that out
Old June 25th, 2007, 07:56 PM   #13
707Stang's Avatar
2008 GTI
14.65 @ 99.83
Thanks! believe me it works!! i live in the frekin desert sandstorms and all that shit. it did wonders!
Old June 25th, 2007, 08:25 PM   #14
2000 Mustang V6
El_Cangri will become famous soon enough
Send a message via AIM to El_Cangri Send a message via MSN to El_Cangri
the cabls ans shit give u better spark.. its a good mod not the best good.... not wasting money in there..
about the engine I use Gunk engine degreaser just cover electrical parts and spay the degreaser heavy deposits willneed some lil brushing... after sprayinh ad brush u will have the motor looking like new in 15 minutes..
the spray eats wax so watchout for the paint if u spray it in the pain clean it fast...
Originally Posted by Fryrice
One time I stuck my dick in my own butt by accident.
Dont laugh it was dark in the room.
Threads Similar to: engine cleaning.. and other things
Engine Cleaning? Snipe061 Visual 14 September 22nd, 2007 12:04 PM
engine cleaning mustangrebuilder 2005 - 2010 26 August 18th, 2007 10:49 PM
Engine Cleaning tnknepp Classic Mustangs 4 July 23rd, 2007 06:48 PM
Cleaning engine MustanG_guy17 99-04 14 April 20th, 2007 09:22 PM
Cleaning Engine themav46 V6 Mustangs 15 October 9th, 2006 07:23 AM
