1993 5.ohhhh
12.97 @140mph
Spark plug gap
I just installed 764 auto line copper plugs. What is the proper gap... cause these are at 54 and the it's not running right. Motor shakes to much and idles ruff.
02 Pewter z28, hoosiers/lid/exhaust/spray...125mph 1993 gt Sold, already missed ![]() --Moates Quarter horse $225-- --Cobra intake $150-- --tremec 3550 bell and shifter $1100--
1993 5.ohhhh
12.97 @140mph
I have them for nitrous btw.
1993 5.ohhhh
12.97 @140mph
and does anyone have the 123 456 layout and what goes to what to make sure I have this right.
The passenger side head starts at 1 2 3... 3 being closes to the winsheild right... Then on the drivers side head its 4 5 6... being closest to the drivers side of the winsheild
#4 | |
http://www.muscularmustangs.com/2005/firingorder.php firing order enjoy
![]() Im'a Techno Head,Breakbeat Head,Muscle Head... i Got Style So Bite Me ! :] http://www.myspace.com/hostileact ---Beep--- |
and btw some plugs require to upgrade your wires to deliver the spark
get some jba or steeda wires
i need to replace my plugs i think..what kind should i get?? havn't done any modding yet...getting my rear axle tho so its nothing on my engine yet...
If you aren't first.....your last!
#7 | |
1993 5.ohhhh
12.97 @140mph
Well I got duralast wires. The idle is at like 900-950 and a tad bumpy.
When I put it in drive it start to squeak and gets real ruff. but it drops down to the normal idle then bounces a tad. Seems like it might be comming from the passenger head area.
#9 | |
also your maf might be dirty and hence why u idle at 900 when it should at 700 ... run some seafoam
#10 | |
1993 5.ohhhh
12.97 @140mph
Well I mean would the maf sensor really have something to do with the new plugs. It ran fine prior to the new plugs.
ok then its not your maf .... my maf got dirty when i passed through a construction zone so i cleaned it and idled perfect ... ok so your maf is ok .....
did u plug all the plugs in correctly ... once i thought i plugged it in and it was a bit loose ..... and dont worry if u misplaced a wire that stang would be backfire like a lil biatchhhhh
1993 5.ohhhh
12.97 @140mph
We did that few times... It just idles down normal in park but it's just ruff as shit and goes up and down a 100 or so rpms and my check engine light is flashing.
#14 | |
strange...
go to autozone and get the code readed.. also did u disconect the battery while changing plugs? or w.e
#15 | |
are the plugs made for your stang?? and i think it sounds like a gap issue
1993 5.ohhhh
12.97 @140mph
I might have figured out my problem... the lady that I got them from at autozone I asked for ngk autoline and she gave me autolite saying these were the ones for my car. Either I will return to stock plugs or try to find autoline.
#17 | |
#18 | ||
im gonna use 764s soon...
did you use antizeez with the plugs? advance auto parts sells a spark plug wire tester 764's are correct for one heat range colder then stock 765s are stock
Also one more thing
do you have it gapped at .054 or .54..that would be bad
Threads Similar to: Spark plug gap
| spark plug gap...wat does it need to b? | VSR13 | V6 Mustangs | 7 | January 30th, 2008 06:48 PM |
| spark plug gap | white93pony | 5.0 Mustangs | 8 | October 13th, 2007 11:51 AM |
| spark plug ?'s | tgk | 94-95 | 1 | August 25th, 2007 08:29 AM |
| Spark Plug Gap?? | smokiebear911 | 99-04 | 6 | July 19th, 2007 12:26 PM |
| Spark plug gap? | 8A_Honda | V6 Mustangs | 5 | July 6th, 2007 02:43 PM |
