Possibly bad gas????
I just received a car from my dad which is a 98 mustang and drove it 1400 miles with no problems. Yesterday I filled up my tank and 2 miles later my car started bogging down and running choppy. It feels like something is holding the car back and not allowing it to accelerate like it should. The first thing my step dad asked me was "did you get gas today" and I told him yes I did. I put the gas in the car about 30 minutes after they filled up the tanks at the station and now things aren't right with my car. My step dad said it sounds like I got bad gas. I called the Ford dealership and they told me to try something called Heet and I did that today. It runs a little better but it is still doing the same thing. Can anyone out there give me any ideas on what might be happening with my car and how I can fix this problem. If it is bad gas, do I just run it through and get better gas next time or does it sound like something else? I also changed the fuel filter before I made my trip as well along with the air filter. Any information on what I should do would be appreciated.
#2 | |
bad gas..... continue running the car and get good gas later or u got a different octane maybe
Yes. It sounds like contaminated fuel. What is needed to fix it depends on how bad the contamination is. "heat" is an additive that gets water in the gas to mix with the fuel and be burned. If it didn't help it's probably not water. Sounds like the fuel filter is clogged. Drive it till the tank is near empty, replace the fuel filter, and refill with fresh gas. If the contamination is mild that should cure it. If you still have trouble run injector cleaner for one tank full and change the fuel filter again. Beyond that the injectors will need to be cleaned off the car and all the lines flushed out. In extreme cases the fuel tank may need to be removed and cleaned out. The gas station should have to pay damages, which may run to > $1K.
Pioneer gas is bad for that in canada i had a tank of water and so have # of ppl i know and they wouldn't pay for shit when we had to get our tanks drained i had half a 5 gal pail of water in my tank!!
Just throw some chevron premiun in to even it out
2000 V6 vert Mac LT headers, Mac O/R H-pipe, Mac CAI, ASP 25% underdrive pulley(r.i.p), SCT tune, 8.8 rear and 4.10 gears. |
wholly triple post batman!
would that really work, putting some Chevron Premium in to level it out?
#10 | |
#11 | |
seafoam?
#12 | |
#13 | |
seafoam is used for carbon deposits and eliminates moisture in fuel and motor oil...
so i'm thinking it has to work...
#14 | |
#15 | |
u got
![]() j/k lol
#16 | |
#17 | |
mmmm ur moms good...
#18 | |
sooo sony...
could u tell ur mom i'm waiting for another 9 hour round :wink
#19 | |
id have a come back but we could be here for hours lol
#20 | |
And with everything we have suggested inside the tank something will work
Threads Similar to: Possibly bad gas????
| Torque Converter? possibly? | RandoGT | 96-98 | 3 | November 4th, 2007 05:57 PM |
| possibly a HUGE problem.. HELP! | -cold-machine- | 2.3 Mustangs | 23 | September 26th, 2007 09:39 PM |
| Possibly the second best GIF image ever :D | Juggalo_X | The Clubhouse | 16 | September 5th, 2007 04:27 AM |
| Possibly best GIF image ever, or so im told lol | Juggalo_X | The Clubhouse | 27 | September 1st, 2007 05:58 AM |
