The soul stealing Ginger
Passenger window does not want to go down
it sucks, my passenger window worked fine, now all of a sudden one side goes down faster than the other, it only goes down about an 2 inches or so then stops, when i try to roll it back up, it stops about an inch to a half inch or so from closing all the way, any ideas???? its a power window and the motor seems to be working just fine. think its off track or something?
could be off track or you just need a new motor
the motors you can get at an auto store(advance auto parts, autozone w/e) track idk if you can get there. either way you gotta take a part the door bezel to see
#3 | |
the motor works its just the side attached to the car itself doesnt go down as fast, but the other side is going at its correct speed. i couldnt see anything after taking the panel off, then the watershield, is the bezel the next piece of metal? |
it sounds like it just popped off track.....take the door panel off and try and get it back on tack but whatever you do dont let it slip all the way down because it might crack and it will be the biggest pain in the ass trying to get it back up.....i know from experiance..lol
bang on the inside of the door hard a few times it will go down common issue
Make sure u do it on the inside of the door.
#6 | |
also look at ur fuses when windows fuses r going bad both or one of the windows gets slower
turns out the window regulator was bent, just bent it back the right way and things look okay for now.
#8 | |
Threads Similar to: Passenger window does not want to go down
| Re-Gluing The Passenger Window..... | lwhitetrash88l | General Tech | 11 | September 26th, 2007 12:19 PM |
| Passenger window leaking......help? | lwhitetrash88l | V6 Mustangs | 14 | August 8th, 2007 12:04 PM |
| Passenger window switch problem | Plays With Squirrels | Audio/Video | 9 | July 4th, 2007 08:46 PM |
| need new passenger door | wadepetersen | Visual | 2 | June 14th, 2007 11:17 AM |
