weird noise
Old June 30th, 2007, 11:23 AM   #1
muneris pro ego
Ninjawafers!'s Avatar
97 5.0 Exploder AWD
snow has nuthin on me
Ninjawafers! is a splendid one to beholdNinjawafers! is a splendid one to beholdNinjawafers! is a splendid one to beholdNinjawafers! is a splendid one to beholdNinjawafers! is a splendid one to beholdNinjawafers! is a splendid one to beholdNinjawafers! is a splendid one to behold
Send a message via AIM to Ninjawafers! Send a message via Yahoo to Ninjawafers!
weird noise
i keep hearing this weird noise coming from my passenger side rear (96 v6)... i dont know where exactly it is coming from. it sounds kinda like a metal on metal noise.. kinda grinding but its not heavy or loud. it only does it when i turn the steering wheel left or sometimes when i let off the gas... i just had new exhaust put on and just put on new rims and tires.. i did a lil visual inspection just a few minutes ago and everything looked fine.. any ideas?
Buy my M90 Kit and my Gears and T-Loc!
MM ZDC - Alaska Base Commander
MM+ Cleavage Club #24
MM Cares Crew / Military Crew
M2C2 President / USCG - OS2
Old June 30th, 2007, 12:47 PM   #2
Tree Fiddy Z
Breakout's Avatar
2006 Nissan 350Z
Breakout is a jewel in the roughBreakout is a jewel in the roughBreakout is a jewel in the rough
Send a message via AIM to Breakout
it may be the rear brakes. more specifically the shoes and/or the drums...have them checked out
Old June 30th, 2007, 12:50 PM   #3
muneris pro ego
97 5.0 Exploder AWD
they are disk breaks... and they looked fine... weird that it only does it when i turn the steering wheel left or slow down with no brake applied... when i press the break i dont hear it.. unless im turning the steering wheel left
Old June 30th, 2007, 12:51 PM   #4
Tree Fiddy Z
Breakout's Avatar
2006 Nissan 350Z
i didn't think they put disc brakes on a 96. hmm...i must be outta the loop. well now i feel like an idiot
Old June 30th, 2007, 12:52 PM   #5
Tree Fiddy Z
Breakout's Avatar
2006 Nissan 350Z
well it's most likely suspension. but i've never heard suspension make a metal on metal noise
Old June 30th, 2007, 12:53 PM   #6
muneris pro ego
97 5.0 Exploder AWD
me either.. thats why im so confused with it.. i checked everythign out and it didnt look like anything would be rubbing against each other... so im completely clueless
Old June 30th, 2007, 12:55 PM   #7
Tree Fiddy Z
Breakout's Avatar
2006 Nissan 350Z
yeah...i dunno...it could be a joint too...but like i said..metal on metal noise...that's a 1st for me if your brakes are fine...did you check the caliper? It may be sticking...
Old June 30th, 2007, 12:58 PM   #8
muneris pro ego
97 5.0 Exploder AWD
i was thinking somethin to do with the brakes.. but when i turn the steering wheel left? like i could barelyt nudge it left and it makes the noise... that is what boggles my mind... that would have absolytely nothing to do with the brakes
Old June 30th, 2007, 01:05 PM   #9
Tree Fiddy Z
Breakout's Avatar
2006 Nissan 350Z
i'm not sure about your year mustangs...but they could have what's called "floating" calipers. my 1995 oldsmobile achieva had it...and when my calipers stuck and i made a turn...once my brake pads were worn down enough, the indicator rubbed on the rotor. that may be your problem. but i'm not sure if your year used floating calipers
Old June 30th, 2007, 01:09 PM   #10
muneris pro ego
97 5.0 Exploder AWD
i dunno.. ill check it though. but ima get me some sleep right now.. night shift sucks... keep the ideas comin!!! lol
Old June 30th, 2007, 08:25 PM   #11
chevy_killer's Avatar
2009 v6 Mustang
chevy_killer is on a distinguished road
Send a message via AIM to chevy_killer Send a message via Yahoo to chevy_killer
it sounds like a bearing is bad????
The LS1 was finally subjected to a paternity test, and it's daddy was to '03 Cobra
Old July 1st, 2007, 11:47 PM   #12
muneris pro ego
97 5.0 Exploder AWD
well i think i can rule out a bad bearing because if one went bad id hear grinding the whole time... to me it sounds like when the brake pads are bad and it grinds agains the rotor... but the pads look good. it did it today onle when i turned the steering wheel left, or hit a bump.. a friend of mine thinks it could be a joint or somethin... any more ideas?
Old July 2nd, 2007, 12:34 AM   #13
Tree Fiddy Z
Breakout's Avatar
2006 Nissan 350Z
it definately sounds like a frozen caliper
Old July 2nd, 2007, 01:12 AM   #14
muneris pro ego
97 5.0 Exploder AWD
im starting to think its that also... ill check it tomorrow when i do some body work to the stang... if i find out what it is ill definitely let yall know
Old July 2nd, 2007, 04:18 PM   #15
MustanG_guy17's Avatar
2007 Mustang GT/CS
MustanG_guy17 will become famous soon enough
I bet it's your exhaust.. Mine made a ton of noise when i first got it.. I took it back and they got rid of most of it.. But when i hit a bump it knocks. And when im in parking lots. turning it rattles.. ANNOYING
2007 Mustang GT/CS 5spd: Flowmaster hushpower axle back,O/R X pipe,JLT CAI,93 Bama tune..laser interceptor dual jammers, Escort Redline RD,Laser Veil G4.
MAVERICKS!!!!!!!!!! BABYYYY.. DALLAS COWBOYS
Old July 2nd, 2007, 08:07 PM   #16
Florida Mustang is on a distinguished road
Noise
You said you had a new exhaust put on, maybe the exhaust pipe is touching the driveshaft when you turn?
Florida Mustang
Old July 2nd, 2007, 09:44 PM   #17
tsp_2177's Avatar
2005 Civic
GAY!
tsp_2177 will become famous soon enoughtsp_2177 will become famous soon enough
well not to insult you or anything but how would the exhaust move any more going straight than turning last time i checked all the exhausts ive had have been pretty good not to move
slow car member twinky times two
the stangs gone
pypes mid muffler catback with their X-pipe
In the top 20 cool peoples list on MM
potsticker in training
Old July 2nd, 2007, 11:02 PM   #18
2000 Mustang V6
El_Cangri will become famous soon enough
Send a message via AIM to El_Cangri Send a message via MSN to El_Cangri
cause sometimes the hanger or w.e its called gets loose making the exhaust to move...
Originally Posted by Fryrice
One time I stuck my dick in my own butt by accident.
Dont laugh it was dark in the room.
Old July 2nd, 2007, 11:07 PM   #19
MM's Database Error
WLJohnson05's Avatar
2004 Mustang V6
322.8 rwhp
WLJohnson05 has much to be proud ofWLJohnson05 has much to be proud ofWLJohnson05 has much to be proud ofWLJohnson05 has much to be proud ofWLJohnson05 has much to be proud ofWLJohnson05 has much to be proud ofWLJohnson05 has much to be proud ofWLJohnson05 has much to be proud of
iTrader: 9 reviews
then thas not good, if its exhaust someone messed up
SCT Mass Air Flow Sensor $200
Old July 3rd, 2007, 09:37 AM   #20
Juggalo_X's Avatar
2001 Mustang 232/CBR600
14+@Slow
im pretty sure its a drum disk combo on the rear how els would ur ebreak work i could be wrong tho
Threads Similar to: weird noise
weird noise? ricerraper33 V6 Mustangs 11 August 11th, 2007 02:31 AM
weird noise? mustang sallie 96-98 4 June 13th, 2007 11:23 AM
Weird noise... Keegan_Vann 99-04 19 April 19th, 2007 04:12 PM
weird noise k2boarder3187 96-98 3 March 11th, 2007 11:32 AM
weird noise holtte 99-04 4 December 14th, 2006 12:23 PM
