windstar intake swap - Forums at Modded Mustangs
post #1 of 35 Old July 11th, 2012, 03:01 PM Thread Starter
Ok I bought a windstar intake off of a 96 windstar. I want to keep my egr. So what all parts do I need to get off the windstar engine. Any write ups would be great thanks.
black_6er is offline
post #2 of 35 Old July 11th, 2012, 03:06 PM
Green_6er's Avatar
iTrader: 6 reviews
I already told you how lol. You need the low profile EGR piece off of the 96-98 windstar van, then you will have to cut the egr tube and either shorten or lengthen it ( idr which ) then connect it with a piece of heater hose.
Green_6er is offline
post #3 of 35 Old July 11th, 2012, 03:21 PM
2013 5.0
slonison's Avatar
This was the second result on Google after searching for "Windstar Swap"
99-04 V6 Windstar Manifold Swap | Mustang Forums at StangNet
Steve's House
120+ V6 How-To's
2013Black 5.0
2002 Black Vert - Sold
slonison is offline
post #4 of 35 Old July 11th, 2012, 03:31 PM
Green_6er's Avatar
iTrader: 6 reviews
Doesnt say anything about how to keep the egr
post #5 of 35 Old July 11th, 2012, 08:27 PM Thread Starter
What tb do I need to use stock mustang,windstar, or a gt tb?
post #6 of 35 Old July 11th, 2012, 08:44 PM
GreenShift's Avatar
I believe you can use either the windstar or the GT tb.
GreenShift is offline
post #7 of 35 Old July 11th, 2012, 09:49 PM
2013 5.0
slonison's Avatar
Went and picked up the intake gaskets...
Vatozone.
Upper to lower 12.99 (make sure you get a 99-04 mustang)
windstar to tb 3.99 (make sure you get 96-98 windstar)
On the move
Steve's House
120+ V6 How-To's
2013Black 5.0
slonison is offline
post #8 of 35 Old July 12th, 2012, 06:45 AM Thread Starter
What years gt tb will work on my car?
post #9 of 35 Old July 12th, 2012, 09:14 AM
2013 5.0
slonison's Avatar
99-04
Steve's House
120+ V6 How-To's
2013Black 5.0
slonison is offline
post #10 of 35 Old July 12th, 2012, 10:59 AM
Green_6er's Avatar
iTrader: 6 reviews
do they have the same throttle linkage? I know the linkage changed from a ball and socket type linkage in 99-00 to some different type of linkage in 01-04.
post #11 of 35 Old July 12th, 2012, 11:35 AM
GreenShift's Avatar
Yes I believe it does matter, you need one for a 99-00.
post #12 of 35 Old July 13th, 2012, 12:51 PM
mattf0509's Avatar
From when I did mine I contacted steven about wanting the gt tb on my 00. He said the gt tb is only compatible with 01-04 and mine would only work with the modified stock tb.
Sent from my SGH-T989 using AutoGuide.Com Free App
mattf0509 is offline
post #13 of 35 Old July 13th, 2012, 03:22 PM
2013 5.0
slonison's Avatar
So this question goes to anyone who did the windstar and kept EGR... Looking at these diagrams I so skillfully made..
It looks like one the original intake there are 5 places where vacuum hoses connect, however, the windstar only has 4 inlets.. can someone clarify if my diagrams are correct and if so, where does B connect?
Steve's House
120+ V6 How-To's
2013Black 5.0
slonison is offline
post #14 of 35 Old July 13th, 2012, 03:38 PM
mattf0509's Avatar
There is another place for vacuum line on the front bottom of the intake
post #15 of 35 Old July 13th, 2012, 03:58 PM
2013 5.0
slonison's Avatar
Where is this other place?
On the move
Steve's House
120+ V6 How-To's
2013Black 5.0
slonison is offline
post #16 of 35 Old July 13th, 2012, 04:49 PM
GreenShift's Avatar
You have to make it IIRC. By drilling a hole, putting a metal bit in and then epoxying it in place. Dont know the specifics about how to go about doing it though
post #17 of 35 Old July 13th, 2012, 05:20 PM Thread Starter
So the windstar throttle body should work rite?
post #18 of 35 Old July 13th, 2012, 05:56 PM
2013 5.0
slonison's Avatar
I'm working on this myself... however, I'm not really understanding how, since the windstar throttle pulls away from the intake instead of towards...
In the meantime, two questions
1. TB gasket... was it part number 60913, because that's what Autozone gave me but it looks like paper and too small..
2. Is this worth it? or garbage? 94-04 Mustang 3.8 V6 Air Intake Filter MAF Adapter MAS | eBay
Steve's House
120+ V6 How-To's
2013Black 5.0
slonison is offline
post #19 of 35 Old July 13th, 2012, 08:23 PM
GreenShift's Avatar
Maybe this'll help. 99BlueV6 sent this to me when I was asking about the windstar.
Originally Posted by 99 BLUE V6
Ill help you out some. windstar cost me 30.00 +2.00 enter fee. takes 15 min to remove. Then wash and cleaning .then iac port must me machined off.
i use bridge port mill, then upper needs to be drilled / taped for vac line, see picture 1 and 2.
I fill in the o-ring groove to eliminate vac leaks as (codeman red silicone) described,now use stock gasket. then drill and epoxy lower for iac vac line. see 3 and 4
after painting it ready for install with your IAC bracket,coil bracket and extended TB from VAP
post #20 of 35 Old July 14th, 2012, 12:16 AM
I have a few intakes laying around. i wish somebody would do a up to date write up on this install
Stangness is offline
Human Verification
LinkBack to this Thread: http://www.moddedmustangs.com/forums/v6-mustangs/269303-windstar-intake-swap.html
Windstar Intake Swap on 4.2_Yaelp Search This thread Refback October 24th, 2015 12:35 AM
Thread Windstar Intake Swap Questions? Look Here | Mustang Forums for All lFord Mustangs | BoardReader This thread Refback April 14th, 2013 08:54 PM
Thread egr trouble code after windstar intake swap | Mustang Forums for All lFord Mustangs | BoardReader This thread Refback February 12th, 2013 04:49 PM
Thread VAP windstar kit vs junkyard windstar intake | Forums at Modded Mustangs | BoardReader This thread Refback December 19th, 2012 12:34 AM
Thread 3.8 mustang/windstar head swap | Mustang Forums for All lFord Mustangs | BoardReader This thread Refback September 12th, 2012 07:38 AM
Thread WTB: Windstar Upper Intake Swap | Forums at Modded Mustangs | BoardReader This thread Refback September 11th, 2012 11:13 AM
