IAC Restrictor to help speedy RPM drop
good read great little free mod will help your rpms drop faster and will give you a different exhaust note check it out. http://www.mustangforums.com/m_3233880/tm.htm
nice...but wouldn't that kinda restrict airflow, giving less horsepower?
#3 | |
Kinda cool...couldn't that be done with a tuner too though, by lowering the idle rpms
2000 V6 vert Mac LT headers, Mac O/R H-pipe, Mac CAI, ASP 25% underdrive pulley(r.i.p), SCT tune, 8.8 rear and 4.10 gears. |
#5 | |
#6 | ||
#7 | |||
I did this mod cuz i was board it definitely give u that rumble at idle and has no effect on driveability.
¡ʇsnq ɹo uʍop ǝpısdn
so what are they doing ... just allowing more air to flow in or less or what... im not sure how restricting the flow on one of the intakes to the IAC will help a car... seeing as the factory did it that way for a reason ...
thats why im hesitant to fully give in to this... im just a little like... huh? ish about it
#10 | |
hey Jug, did you make yours out of sheet metal or something like that? how did you cut metal to that shape? drilling the holes would be easy...but cutting the shape? =\
#12 | |
if you were a manual why would you want the idle to drop quickly. then they idle would end up jumping up again as you went to the next gear. but i cant see how this would help in an auto either so what exactly is this suposed to do?
![]() 95 Civic Ex, FnF1's, Morimoto Mini h1 retrofit, GSR, bbk intake, BDL tb, 57trim t3/t4 8psi, 297whp 96 Civic Ex 2dr, G3 HID retrofit, FnF type 1's, Si cluster, Obd1 Z6 swap |
#14 | |
#15 | |
hmm...
i'm like omz... ....cheap .. yes worth..?... i'm a freaking manual.. i can throw my shifts fast as hell.. but then if i give the car to my parents.. it will sux to em.... then i will not need to borrow the car anymore to them
SCT tune on my car when i hit the clutch to switch at the track the rpm needle jumps 1000rpms higher then when i switch to the next gear it drops to w/e rpm
makes sense for racing in way... burnouts are a bitch in the begining though cause it takes a while for the needle to drop...and i dont wana put it reverse at 3000rpms
#17 | |
i never tho that was possible
Threads Similar to: IAC Restrictor to help speedy RPM drop
| iac restrictor plate? | gtdan | 96-98 | 28 | September 18th, 2007 10:59 PM |
| EGR restrictor???? | 97Cobra | 96-98 | 4 | April 29th, 2007 08:27 AM |
| iac restrictor gasket | k2boarder3187 | 96-98 | 1 | March 26th, 2007 10:52 PM |
| IAC Restrictor Plate | smokiebear911 | 99-04 | 2 | March 26th, 2007 12:52 PM |
| EGR Restrictor Plate | smokiebear911 | 5.0 Mustangs | 2 | March 21st, 2007 12:17 PM |
