97 V6 missing on cyl 4,5,and 6
Working on a friends car from 50 miles away so I don't have a lot to go off here. It's a 97 3.8L that misses on cyl. 4,5,and 6. There are no codes coming up. It had a tune up about 6 months ago. It's not a constant miss. It doesn't overheat. My first thoughts are cam sensor and O2 sensor, but I'm not familiar with those motors or thier common problems. Any help would be greatly appreciated. Thanks guys
If it ain't broke, fix it till it is! |
Wires or coil would cause a multiple cyl misfire either that or youve got the firing order mixed up on those cyl or possibly but i can see all 3 plugs being bad only on that side.
#3 | |
sounds like wire or coil.... u mixed the wires or bad spark plug...
The plugs and wires were changed 6 months ago. The problem just started in the last few weeks. The coil has been replaced to try to fix it along with the crank sensor. But, I'm just going off what my friend is telling me and she's 50 miles away. I haven't even seen the car yet. Do those things have a cam sensor on both sides? or a seperate timing belt/chain for either side? I'm still leaning towards an O2 sensor or possibly a cam sensor...
#5 | |
we only have one cam.... so yeah ne timing chain and one sensor i believe...
if the car has a code get it to autozone and post the code here..
It doesn't have any codes. I was told it's single overhead cam. That would make it have a cam on each head. I'm gonna go check it out as soon as I can, but I was just trying to get an idea of any common or likely issues.
#7 | |
no we aint sohc those r the v8's we r ohv
Plug wires or shitty plugs or its lost compression any over heating issues? buring oil?
No overheating. Not sure about the oil. I seems odd that it would be all plugs or wires going to just one side of the motor without something else causeing it. Plus it's pretty common but not constant. Ignition is usually under load everytime(from my experience)
it has to be your ignition
start cheap change your plugs first....765 autolites MAKE SURE you plug in your wires in the right plugs per cylinder if its still doing the same that car is old the wires are probably bad get some wires if its still then its the coil....replace your coil make sure your firing order is correct with an old car like that it could be either while your at do a full tune up fuel filter PCV valve aif filter oil change and evena radiator flush and seafoam none of that is related to your misfire just a good idea on an old car
She's taking it back to get the plugs and wires replaced today. She's gonna let me know how it goes. Thanks guys
Threads Similar to: 97 V6 missing on cyl 4,5,and 6
| What is the Mustangs missing ? | EmmaG | Modular Mustangs | 24 | July 1st, 2007 08:05 PM |
| Engine missing Q's | Rutcutter | 5.0 Mustangs | 21 | June 4th, 2007 06:05 PM |
| Random missing | nolife | 5.0 Mustangs | 8 | May 6th, 2007 07:55 PM |
| Car Missing Out Bad | bigbadtalontsi | 5.0 Mustangs | 7 | March 28th, 2007 06:14 AM |
| Car Missing Out | bigbadtalontsi | 5.0 Mustangs | 10 | March 11th, 2007 05:47 PM |
