99-04; pcv oil contamination fix concept
Old June 28th, 2006, 02:01 PM   #1
99mustang232's Avatar
1999 Ford Mustang V6
99mustang232 is on a distinguished road
If have a 99-up model with overly effective PCV system that contaminates the intake manifolds and impairs performance? If you intend to leave the PCV system intact, here’s a potential quick fix that you may try. Remove the PCV valve cover. Enlarge the drain back hole in the baffle. Stuff the baffle with coarse stainless steel wool but don’t pack it too tightly. The steel wool should help by “straining” the oil from the air flow.
Has anyone heard of this before? I would still preffer the catch can/oil separator method but hadn't heard of this one before.
...even fire and single cammin
1986 Ford F-150 5.0L 2WD
1994 Toyota Pickup 2.4L 4WD
1999 Ford Mustang 3.8L V6
2002 Jeep Grand Cherokee 4.0L 2WD
2008 GMC Sierra Denali 6.2L AWD
Old June 28th, 2006, 02:48 PM   #2
AtlanticBlue99's Avatar
14.79 @ 92.15
I would prefer a catch can container or a filtered vent straight off the valve covers. http://www.vmptuning.com/cart/produc...&cat=50&page=1
ModdedAutos
1999 Mustang V6
Old June 28th, 2006, 03:17 PM   #3
that caption came from supersix, but an interesting concept as long as you could prevent the stainless steel wool from leaving the valve cover baffle. i don't really like the breather method because as soon as you turn on your hvac all crankcase fumes are vented into the cabin.
http://www.supersixmotorsports.com/pdf/PCV%20Bypass.pdf
Threads Similar to: 99-04; pcv oil contamination fix concept
91 Mustang LX 5.0 w/ Concept X bodykit mustangclint Pictures 6 October 17th, 2007 01:08 AM
Bio Concept DanishStallion 2005 - 2010 5 September 7th, 2007 10:51 PM
speed concept?? itschristorres8 Shops 1 July 30th, 2007 12:42 PM
GT-R Concept Casper98GT The Clubhouse 5 June 3rd, 2006 11:06 PM
concept: BMW coupe 99mustang232 The Clubhouse 1 June 3rd, 2006 08:48 AM
