Threw a P0401
Threw that "EGR Flow Insufficient" after replaceing EGR valve... what could be next
2000 V6 Performance Red @ Cardomain Was fun but a waste... 1987 LX Hatch | Soon to be a 600hp monster |
It is the DPFE............. The Differential Pressure Feedback Sensor
2003 Mustang Mach1 1995 Thunderbird LX 4.6L; 1995 Mustang 4.2L; Eaton MPX Supercharger, 11.61 @ 118mph |
as i did some reading about the DPFE sensor... the description of the problems sounds exactly the same. Where is it located and can it be cleaned... ill try to clean it but if it doesn't work ill just buy a new one
im hoping this will be the end of this SHIZIT
1999 Ford Mustang V6
did you fix your exhaust leak?
...even fire and single cammin 1986 Ford F-150 5.0L 2WD 1994 Toyota Pickup 2.4L 4WD 1999 Ford Mustang 3.8L V6 2002 Jeep Grand Cherokee 4.0L 2WD 2008 GMC Sierra Denali 6.2L AWD |
just repl it. they can't be cleaned and it will take care of your problem. I can't remember the last time I replaced an egr valve. they don't go bad anymore......
no i didn't fix the exhaust leak yet
o well i have a new one in so i don't have to worry about that anymore ill run to the store today and get one thanks for the help guys i hope this works
#7 | |
Make sure you clean the crud out of the rubber hoses running to the DPFE sensor too.
Threads Similar to: Threw a P0401
| MicronXD visits the drive threw | HMUSN | The Clubhouse | 58 | July 28th, 2007 11:08 AM |
| Threw a rod, need new stuff. | BiGD12590 | 99-04 | 39 | May 3rd, 2007 09:52 PM |
| 3.73 Gears threw off my speedo. Help | 95blackbeauty | 94-95 | 6 | April 24th, 2007 03:58 PM |
| Threw Some Codes HELP! | CrazyHorse | 99-04 | 5 | November 8th, 2006 01:59 AM |
