HOW TO FILL UP TORQUE CONVERTER?
Old July 9th, 2007, 10:33 PM   #1
oasr87 is on a distinguished road
SO I TOOK THE ENGINE OUT OF MY CAR AND IT IS GETTING REBUILT AT A SHOP.
I HAVE A QUESTION THOUGH
WHEN I PULLED OUT THE ENGINE FROM THE TRANNY IT LEAKED A BUNCH OF ATF FROM THE TORQUE CONVERTER. WHEN I GET THE ENGINE BACK DO I NEED TO PUT AFT ON THE TORQUE CONVERTER OR IT WILL PUMP ITSELF AND ILL JUST FILL IT AT THE DIPSTICK...
THANX
Old July 10th, 2007, 01:00 AM   #2
mm's nitrous mod
SWEET2KSTANG's Avatar
2000 mustang gt
11.79@115.83 (old set up)
iTrader: 8 reviews
as long as the converter has at least 2 qrts in it, it will be fine. when installing a new converter, that is what is on the instructions. it is just to deep from a dry start, and will fill itself when you put fluid in it.
Old July 10th, 2007, 11:21 AM   #3
thanx
but how do you fill it up and keep it from spilling when you are installing the engine?
Old July 10th, 2007, 04:58 PM   #4
stephen has a spectacular aura aboutstephen has a spectacular aura about
The torque convertor is supposed to stay on the front of the transmission.
You were supposed to remove the torque convertor to flex plate bolts before removing the engine.
To install it you need to check for seal damage which may have occured when the torque convertor came out bolted up to the engine. If the seals are OK just put some trans fluid in the convertor and install it on the transmission. Then lower the engine in and bolt it up. As soon as the engine starts stop it and add trans fluid.
Threads Similar to: HOW TO FILL UP TORQUE CONVERTER?
torque converter 06Stanger 2005 - 2010 0 July 29th, 2007 11:16 AM
Installing a Torque Converter?? MustangJon255 2005 - 2010 1 July 15th, 2007 03:06 PM
torque converter barksdaleammo 99-04 5 April 3rd, 2007 06:20 PM
Torque converter for our cars JASonic V6 Mustangs 21 March 5th, 2007 01:51 AM
Torque Converter ? BraggStang General Tech 5 August 11th, 2006 06:57 AM
