Loss of Power when a/c is turned on and more...help please!
Old July 11th, 2007, 08:21 PM   #1
jsteves1313's Avatar
jsteves1313 is on a distinguished road
Ok, so here are the problems that I'm dealing with...
1. When I turn on the a/c, I feel a loss in power. The car basically drives sluggish. The idle is all over the place and the car just doesn't drive as smooth.
2. The a/c will blow ice cold during a quick ride, however, it will stop blowing from the vents after a long ride. I can still feel it cold around the vents, but nothing is blowing out. It sounds like it's blowing out of the defrost vents, but I can't feel any air coming out there either.
3. I don't know if this is normal or not, but the outer part of the a/c compressor clutch spins with the pulley. It might sound like it is supposed to do that but it spins really slow, while the pulley spins really fast.
4. It seems like only when the a/c and the stereo are on together, I hear a high pitch humming noise from the left side of my dash. As soon as I turn the stereo off, it goes away. It doesn't do this unless the a/c is on too though. This problem is also tempermental. It seems like it will only do this after a longer ride.
I know these problems are out of the ordinary, but any help would be greatly appreciated. Thanks everyone!
Old July 11th, 2007, 08:24 PM   #2
HMUSN's Avatar
iTrader: 9 reviews
this is normal.
you are robbing power from your car when you turn on you a/c
try recharging you ac system.
to fix the air issue
Old July 11th, 2007, 08:27 PM   #3
this is normal.
I don't think i need to recharge it because when it does blow, it blows really cold. It will just stop blowing all together after a longer ride. It sounds like it's blowing but nothing is coming from the vents.
Old July 11th, 2007, 08:29 PM   #4
HMUSN's Avatar
iTrader: 9 reviews
do you get a weird sound at all before it stops blowing?
could be a bad blower motor.
Old July 11th, 2007, 08:35 PM   #5
¡ʇsnq ɹo uʍop ǝpısdn
Onemanzu's Avatar
if your a.c system doesn't have any oil or coolant or anything in it the whole unit can freeze up... happened to my brothers car...
Old July 11th, 2007, 09:14 PM   #6
[8MINUS2]
ESG-642T's Avatar
2002, Ford, v6
ESG-642T is a glorious beacon of lightESG-642T is a glorious beacon of lightESG-642T is a glorious beacon of lightESG-642T is a glorious beacon of lightESG-642T is a glorious beacon of lightESG-642T is a glorious beacon of light
this is normal.
Normal? I think not, turning on the ac shouldn't make a car feel sluggish, or non smooth, idle may move a slight bit but if its enought where your complaning I think you have a problem.
Hi, You can call me Kyle
Old July 11th, 2007, 09:16 PM   #7
HMUSN's Avatar
iTrader: 9 reviews
people tend to over state their ails sss.. you know that.
if it happens when he turns on his A/C.. it's probably his A/C system failing or one of it's components or partner components.
Old July 12th, 2007, 09:47 AM   #8
dave78 is on a distinguished road
Ok I use to do heating and ac before I found a Better paying job.
The reason you ac is blowing really cold air for a short time Is because you are low on freon. That is allso why after a long run you have no air flow out the vents.
What is happening is because you are low on freon you evaporator coil is icing up. It is getting so cold that ICE is forming on it and BLOCKING the air.
Look under the hood and make sure you have a system that take 134a refrigant. Then go to walmart and get a can with oil to shoot in the system. Follow the directions.
Old July 12th, 2007, 10:31 AM   #9
makes sense. thanks! i really hope this is the problem, easy fixes are sweet. any idea on the humming sound?
Old July 12th, 2007, 10:36 AM   #10
HMUSN's Avatar
iTrader: 9 reviews
try recharging you ac system.to fix the air issue
makes sense to me too :wink
like I said before.. I think it might be your blower motor starting to give out.
Old July 12th, 2007, 10:54 AM   #11
thanks for the advice too..by any chance, do you know where the blower motor is located? that was actually my first thought when all this started happening. not that expensive of a part, but i was reading other a/c threads and i guess it's a bitch to put it in? any help on installation?
Old July 12th, 2007, 11:17 AM   #12
HMUSN's Avatar
iTrader: 9 reviews
it's in your lower dash and yes it's a bitch to get to.
I haven't had to do it myself but I do remember of one guy on here that has.. I'll look up his info so he can help you out on the install.
Old July 12th, 2007, 11:21 AM   #13
good looking out..thanks man!
Old July 12th, 2007, 05:00 PM   #14
2000 V6
ByPopularDemand is on a distinguished road
Send a message via AIM to ByPopularDemand Send a message via MSN to ByPopularDemand
While we are at it my ac blows air but it isn't cold at all...would that be a freon problem...where do I check/add more
2000 V6 vert
Mac LT headers, Mac O/R H-pipe, Mac CAI, ASP 25% underdrive pulley(r.i.p), SCT tune, 8.8 rear and 4.10 gears.
Old July 12th, 2007, 07:54 PM   #15
Ole Yeller is on a distinguished road
just go buy a refill kit from an auto store or wal mart or something it has instructions on how to do it.
So this guy and his friend were like wanna race? i was like :stupid- the light turned and we and I went and his friend was like you got and I was like and went home and his wife. The End
Old July 12th, 2007, 08:08 PM   #16
02ponypackage's Avatar
02ponypackage is on a distinguished road
u lose power with the AC on period
just a V6 with a bad belt slip under the hood
Threads Similar to: Loss of Power when a/c is turned on and more...help please!
Could This Cause Loss Of Power VSR13 V6 Mustangs 24 December 14th, 2007 11:08 AM
Loss Of Power! Help Please! alamo11 V6 Mustangs 8 December 14th, 2007 09:34 AM
power loss? xedubx 99-04 16 June 20th, 2007 10:52 PM
Loss of low end power ByPopularDemand V6 Mustangs 24 May 10th, 2007 10:00 PM
Power Loss the hammr 5.0 Mustangs 8 August 17th, 2006 09:48 PM
