Discussing TRANSMISSION FLUID in the V6 Mustangs Forum. SO IM ABOUT TO CHANGE IT BUT HAVE NO IDEA HOW TO PUT SOME BACK ...
Old July 12th, 2007, 08:33 PM   #1
ROUSHME661's Avatar
TRANSMISSION FLUID
SO IM ABOUT TO CHANGE IT BUT HAVE NO IDEA HOW TO PUT SOME BACK IN ...I TIRED LOOKING FOR SOMEWHERE TO PUT IT IN BUT CANT FIND ANYWHERE ...HELP PLEASE ..YES I KNOW LAME...IF IT HELPS 01 V6 AND ITS 5 SPEED
Old July 12th, 2007, 08:42 PM   #2
chevy_killer's Avatar
2000 v6 Mustang
the top "bolt" that is in your tranny take it out and put it in that way
The LS1 was finally subjected to a paternity test, and it's daddy was to '03 Cobra
Old July 12th, 2007, 09:20 PM   #3
When your under the car, it will be on the right (passenger) side of the transmission.
It will be right above the drain bolt. You cant just pour it in. You need a "grease gun" (or similar design) to put it in. When its full, it will over flow. Its not that bad of a job. Have fun.
EDIT: To add. they dont look like a regular bolt. They are flat with the tranny and you need hex keys to take them off.
Old July 12th, 2007, 10:24 PM   #4
ROUSHME661's Avatar
YEA I FOUND BOTH THOSE PLUGS THANKS APPRECIATE THE HELP...MAN I LOVE THIS FORUM HAHA
BUT I GUESS IMMA BE WORKING ON IT TOMMOROW SINCE IM ALREADY DONE WITH EVERYTHING ELSE AND IM ALREADY ALL CLEAN SO ITLL HAVE TO WAIT LOL
Old July 12th, 2007, 11:11 PM   #5
JASonic's Avatar
2004 V-6 232
speaking of tranny fluid, I asked how much it was to have it changed by Goodyear and they said $170! WTF!!! He said Ford uses some crazy synthetic now and its cost a bundle. That seems like BS.
All you need to do is drain the old and rplace with new right? How much can that shit cost??
http://www.youtube.com/watch?v=yeQLUyYg3EA
^^^^Ok... for a 232^^^^
http://www.youtube.com/watch?v=ah1EbIOdAZE
PhotoClub Co-Founder
K&N FIPK
Dual Flowmasters
Xcal III
Old July 13th, 2007, 12:11 AM   #6
stang300a's Avatar
2004 Mustang V6
i got mine done at the ford dealership for 120 bucks and thats with a new fuel filter too. the good thing about having it done at the dealership i heard is that they flush it out.
2004 Mustang 3.9L V6 with K&N intake, Dual Flowmaster Super 40s, Motoblue 42% Pulley, GT rear sway bar, drilled and slotted rotors, SCT tuner, Black FR500's 17 by 10.5 and 17 by 9, 4.10 motive gears and FRPP T-Lock.
Old July 13th, 2007, 12:14 AM   #7
The only way it would be so much is if you have a manual. Manuals dont use tranny fluid. They use Heavy weight gear box oil. the gear box oil is more money then tranny fluid.
Old July 13th, 2007, 12:15 AM   #8
changing your tranny fluid/oil basically is flushing it. If you want to get technical, all you have to do it leave the drain plug open while you pump new fluid/oil in it.
Old July 13th, 2007, 01:21 AM   #9
ROUSHME661's Avatar
YEA JUS DO IT UR SELF
AND YEAH U HAVE TO USE SPECIAL SYNTHETIC FLUID
I WORK AT AUTOZONE AND LOOKED IT UP ON THE DUMB COMPUTER
IT JUST SAID ANY MERCON AS LONG AS ITS SYNTHETIC IT RUNS ABOUT 6 BUCKS A QUART AND IT SAID IT ONY TOOK 2 2/3 QUARTS SO YEAH I9TS WAY CHEAPER TO DO IT YOURSELF
IM GOING TO DO IT TOMMOROW HOPEFULLY ITS NOT TOO BAD
Old July 13th, 2007, 11:35 AM   #10
By draining it from the plug are you draining it from the torque converter too?? Any1 know. I think thats why they charge a lot cuz theres about 2 quartz in the torque converter and the rest in the tranny... they have to flush everything out and install a new filter with gasket
Old July 13th, 2007, 02:31 PM   #11
JASonic's Avatar
2004 V-6 232
Dude, thanks for sharing that. Thats good stuff. It will help me figure out if its worth me trying to screw up myself.
Thats a TON cheaper. Thats too cool. But this topic has raised other issues like the fluid in the torque converter. Does it fill back up from the fill hole? I'll keep watching this topic.... thanks Roush..
K&N FIPK
Dual Flowmasters
Xcal III
Old July 13th, 2007, 05:02 PM   #12
yeah, it drains out.
Old July 13th, 2007, 05:04 PM   #13
No. it doesnt. You need to fill it up from the Dip stick to fill up the torque converter. If you do it from underneath, you are not going to fill everything up correctly.
Old July 13th, 2007, 06:35 PM   #14
JASonic's Avatar
2004 V-6 232
so how much do you put in the dip stick hole and how much goes to the filler hole?
K&N FIPK
Dual Flowmasters
Xcal III
Old July 13th, 2007, 06:40 PM   #15
You put it in the filler hole until it overflows. Then you turn the car on and start putting it in the dipstick hole until it is full. Put 1/2 a quart in it, and check the level with the dip stick (keep the car running when checking the level). Stop when its full.
Old July 13th, 2007, 06:43 PM   #16
ROUSHME661's Avatar
i think only autos have dip sticks and 5 speeds dont have filters its only autos too
but if you fill it from that hole it will recirculate to the converter
and yeah i think this topc will help a lot of people out i kow it sure helped me
the computer at work said it only takes like 2 2/3 or something like that ...tats including the converter
might be different for autos ill check tommorow
Old July 13th, 2007, 07:36 PM   #17
your computer is wrong. lol. It holds almost 5 quarts. lol. and to get it to recirculate to the converter properly, you have to do it through the dip stick.
Autos do only have dip sticks. 5 speeds do not have filters.
Old July 14th, 2007, 02:04 PM   #18
Couple months ago I called the dealer with 40,000 on mine and asked for fluid change. He asked me year and vin # and promptly replied that does not need changing until 150,000 or 5 years. Has synthetic. He saved me $135.00 IMO would have Ford dealer do it. I also use Mobil 1, Full Synthetic motor oil and change every 10,000 at $50.00 per change. Been using synthetic since 1975 and get same mpg at 150,000 ; Same when bought new. FYI
2006, V-6, Auto, Black, 16 inch, Pony Pkg, S&B CAI, Mobil 1[Full Syn], Klasse AIO
2007 GMC Acadia - Wife's
"I am always ready to learn, although I do not always like being taught." Winston Churchill
Threads Similar to: TRANSMISSION FLUID
What Transmission Fluid? Murderjetz General Tech 8 November 10th, 2007 11:39 PM
Transmission fluid color in an 04 JASonic The Clubhouse 10 October 4th, 2007 11:30 PM
Should I get the transmission fluid changed? throwedoff Drivetrain 10 June 13th, 2007 03:14 PM
transmission fluid firefly1241 5.0 Mustangs 10 April 1st, 2007 04:33 PM
transmission fluid 1990CA50 5.0 Mustangs 1 December 12th, 2006 01:48 PM
