oil pressure
Old July 15th, 2007, 02:12 PM   #1
oasr87 is on a distinguished road
oil pressure
I just finished dropping my new 3.8 bored engine. and I didn't replace the pressure relief valve. does anyone know how long they last? should I take it all apart to change it? is it really important to replace it. I have not started the engine yet.
Old July 16th, 2007, 11:24 AM   #2
stephen has a spectacular aura aboutstephen has a spectacular aura about
I don't believe it will be any problem. Unless you had an oil pressure problem before it most likely is fine. After the engine is running you might measure the oil pressure and compare to specs.
Old July 16th, 2007, 12:19 PM   #3
Juggalo_X's Avatar
2001 Mustang 232/CBR600
14+@Slow
Re: oil pressure
it should be fine as long as your pressure was ok before you bored it out but may i suggest priming your oil pump with a oil pump primer too that way u don't get a dry start.
Old July 16th, 2007, 12:29 PM   #4
Good cuz i didnt feel like taking it all apart just for that. well you guys made me more confident about putting everything back on. ill post up pics of the engine later on oh Yea the oil pressure was good before.
thanx
Old July 16th, 2007, 12:40 PM   #5
Juggalo_X's Avatar
14+@Slow
thanx
then the by pass valve should be fine just on the first start watch the pressure if it doesn't drop like hell unless your revving it then its fine if u have to rev it to keep the pressure up youve got an issue with main bearing clearance or the pressure release valve is stuck. but u should be just fine.
Threads Similar to: oil pressure
oil pressure skid6 5.0 Mustangs 3 August 10th, 2007 11:50 AM
Low Oil Pressure 91lxhatch 5.0 Mustangs 2 July 29th, 2007 12:14 AM
low oil pressure kratos2250 5.0 Mustangs 4 March 1st, 2007 08:18 PM
oil pressure hmotes 5.0 Mustangs 8 January 18th, 2007 09:30 PM
oil pressure turp V6 Mustangs 1 August 19th, 2006 11:59 AM
