transmission build time
Old July 16th, 2007, 01:04 AM   #1
2000 V6
ByPopularDemand is on a distinguished road
Send a message via AIM to ByPopularDemand Send a message via MSN to ByPopularDemand
Ok, so I have the tranny out of a 94 V6 sitting in my garage...the plan is to beef it up, and rebuild it but I don't know how to. So I know ill need a better torque converter, and a shift kit, can someone elaborate on that? What's involved in a rebuild? Also since I'm rebuilding I probably wouldn't want stock parts...is there a way to upgrade the parts used in a rebuild...help me out guys
2000 V6 vert
Mac LT headers, Mac O/R H-pipe, Mac CAI, ASP 25% underdrive pulley(r.i.p), SCT tune, 8.8 rear and 4.10 gears.
Old July 16th, 2007, 01:15 AM   #2
chevy_killer's Avatar
2009 v6 Mustang
chevy_killer is on a distinguished road
Send a message via AIM to chevy_killer Send a message via Yahoo to chevy_killer
ok i would not suggest that you do your tranny rebuild....i would take it to a shop that specializes in trannys....and ask them to put high performance tranny parts in it.....and i would put a shift kit in and instead of a torque coverter i would get a stall converter....they let you get your rpms up befor you launch
The LS1 was finally subjected to a paternity test, and it's daddy was to '03 Cobra
Old July 16th, 2007, 01:30 AM   #3
2000 V6
I might have meant stall convertor...I'm not sure. Is that the one that makes it take off harder when you hit the gas? And I was gonna have everyrhing put in at a shop but I need to know what to get first
2000 V6 vert
Old July 16th, 2007, 11:24 AM   #4
CyberPrey is on a distinguished road
Get a Hi-Perf transmission kit.. I think B&M has them for that year...
Get a Shift Improver kit (These are not hard to install)
Get a Hi-Stall Torque converter..
If you have an SCT or similar tuner, make sure that you ask them to firm the shifts...
If you have rebuilt transmissions before, then go for it... The ford isn't any harder/easier than some of the others out there...
If you have NEVER done anything with an Auto before, then take it in. Auto transmissions are not like anythign else, and even one tiny little error or even 1 tiny piece of dirt/crud can cause the transmission not to function properly....
If you really do want to learn how to fix/rebuild your transmission, see if anyone you know has an old Chrysler/Dodge/Plymouth vehicle that needs tranny work.. the older A904/A727 transmissions are just about the easiest of the automatics to work with, and once you can work on thise, then moving up to the ford isn't going to be a big deal... Also the older C4/C6 fords are just about as simple as the 904/727.... However the nice thing about a 904/727 is that they do NOT require a complete rack of specialty transmission tools....
**EDIT** also, i notice your car is a 2000, and the transmission you have is a 1994... Are you rebuilding the trans for use in your 2000? They are different transmissions in case you did not know... Yoour 2000 is a 4r70W, the 1994 is an AODE... very similar transmissions, but the 4r70W has lower 1st/2nd gears for better acceleration...
Threads Similar to: transmission build time
New Transmission Time! gills99stang 99-04 46 February 21st, 2008 10:33 AM
Build Manual Transmission azeitli1 Modular Mustangs 4 September 20th, 2007 12:25 AM
New member first time poster long time fan kpmorris New Members Introductions 14 August 19th, 2007 11:53 PM
automatic build or switch transmission triggerhappy101 5.0 Mustangs 5 June 5th, 2007 07:44 PM
Time to make my decision. Build the GT or purchase a Term? Chris02 99-04 17 December 15th, 2006 10:27 AM
