ideas to help me mod
Old July 17th, 2007, 03:24 PM   #1
Killer_Bee is on a distinguished road
Hello every one i am a new member just joined this morning so this is whats up. i have just bought a 98 Mustang 3.8l v6 totally stock 5G. I want to beef this car up some. my ideas so far is to Chip it, short ram or cold air intake (opinions on both would be good) Cat back exhaust, larger fuel injectors(ijust moved and i was working on a 65 mustang w/ a 302) so im not to familiar with fuel injected systems. and a turbo or supercharger (opinions on thos would be great to) + anything else that would be agood idea. remember simple upgrades i could do myself and preferably cheap i know that if you need it good then the cost goes up Thanks guys and gals
Old July 17th, 2007, 03:28 PM   #2
Juggalo_X's Avatar
2001 Mustang 232/CBR600
14+@Slow
youve covered everything except the split port swap and ud pulleys and a traction lock and gears also if your looking for a tuner look at the review in my signature
Old July 17th, 2007, 03:35 PM   #3
ok thanks man what is the split port swap?? tho
Mean green Import stomping machine
Old July 17th, 2007, 04:30 PM   #4
CosmoRide is on a distinguished road
Re: ideas to help me mod
Juggalo is right ...split port swap is the way to go ! ! !
Then ...gears, t-lock,pulleys,exhaust,cai,cam,p&p,tune....you'll be happy
Old July 17th, 2007, 04:36 PM   #5
CyberPrey is on a distinguished road
Actually....
if you DO go with the split port swap, be VERY VERY sure to get the supercharger kit for the 99-04 3.8...... and when supercharging, the HP gains are not as readily apparent from the swap as they would be under normal aspiration...
And.. does anyone know where to purchase the Split Port swap kit anymore?? RPM doesn't seem to have it anymore on his website....
Old July 17th, 2007, 04:39 PM   #6
Originally Posted by CyberPrey
Actually....
I think supersix is got them...morana might too
Old July 17th, 2007, 04:41 PM   #7
Thanks
Old July 17th, 2007, 04:46 PM   #8
Very sorry man, I jacked your thread there for a minute... but anyway...
the 98 and earlier 3.8 V6's are what is called "single port" motors, meaning the intake/cylinder heads have 1 air passage in them, or 1 port.
the 99 and newer V6's are Dual Port. They have a low rpm passage/port and a high rpm passage/port. This was done in order to increase throttle response along with horsepower/torque at low to medium RPM's and to increase the horsepower gains at high rpm's.
One of the biggest horsepower gains for a 94-98 mustang can be gotten by simply doing the changeover to a split port head/intake system. It actually gives our motor a bit more of a punch than the 99 & newer because we have a slightly more aggresive cam in our motors... (like a 1 to 3 hp gain over the stock 99+)
HOwever, this mod is not for the newb mechanic unless you purchase a Split port kit... If you purchase the kit, it will come with everythign you need in order to make the swap successful along with instructions.
If you do NOT purchase a kit, then it becomes a bit more difficult as there are some other parts/items needed to make the changeover along with wiring harness modifications and ignition coil mounting. This is the part that makes it a bit more difficult for the newb mechanic to successfully make the changeover without a kit or directions.
Just for quick power gain calculations, your motor stock is about a 150hp motor, the 99+ are about a 190hp motor... the changeover will gain you anywhere from 35-45hp.. everyone seems to have different hp gains depending on who you talk to... My friend did it to his 97 and got a 39hp boost on 1 dyno run, and the 2nd run showed a 41hp boost... average 40hp gain.. which isn't bad at all....
Old July 17th, 2007, 06:06 PM   #9
1968 302 Coupe
WeCircleTheProblem is on a distinguished road
Send a message via AIM to WeCircleTheProblem
the 99+ have dual port? interesting...i was unaware of that
Old July 17th, 2007, 06:13 PM   #10
¡ʇsnq ɹo uʍop ǝpısdn
Onemanzu's Avatar
well its more like they have to sets of intake runners that dump into a single port in the head... so their is only one valve but depending on your rpm their are two different ways for the air to get to the valve
Old July 17th, 2007, 07:01 PM   #11
1968 302 Coupe
yeah i know what your saying but i though 99+ still had only 1 but its good to know that it doesn't makes me feel more special than those 98- even though im not
Old July 17th, 2007, 07:44 PM   #12
00 V6 & 09 GT
13.37@104.4mph--BONE stock GT
a split port is a good idea
but think...
which v6 is the fastest and what kinda upper intake it has..
so surprisingly a single port turbo v6 is the fast v6 mustang known of as for now.
[SIGPIC][/SIGPIC]
Acmillr loves me
Old July 17th, 2007, 08:01 PM   #13
Onemanzu's Avatar
oh yea under ssms's website they have a garage sell section or something like that ... one their they have split ports... for 800 ... it comes with everything including a special fuel rail
Old July 17th, 2007, 08:04 PM   #14
Onemanzu's Avatar
http://www.supersixmotorsports.com/p...GarageSale.pdf
Old July 17th, 2007, 10:00 PM   #15
wow thanks guys learned alot in that little bit on info right there im not to familiar with newer engines
Threads Similar to: ideas to help me mod
ideas on new car for mom cooktheworld The Clubhouse 49 September 27th, 2007 12:00 AM
I need some ideas mustang1072 V6 Mustangs 13 May 14th, 2007 07:05 PM
HEY Cam ideas Onemanzu V6 Mustangs 8 February 11th, 2007 12:58 PM
New Mod Ideas? superkeege 2005 - 2010 16 January 29th, 2007 02:57 PM
