Cooling Fan wont turn on!
Old July 21st, 2007, 07:25 PM   #1
oasr87 is on a distinguished road
I just finished dropping my rebuilt motor and started it with no problem. I saw that the temp kept going up and i know the thermostat works because i checked it in boiling water.
I did notice that the cooling fan wont turn on. Any help, how can i diagnose it??? thanx
Old July 21st, 2007, 07:30 PM   #2
Zoolander
04 Cobra #2260/3768 1/820
iTrader: 5 reviews
Is everything connected? Seriously go out and check.
MM Cobra Club #18
Team Tini Racing
I don't know jack shit...
Old July 21st, 2007, 09:24 PM   #3
2000 Mustang V6
El_Cangri will become famous soon enough
Send a message via AIM to El_Cangri Send a message via MSN to El_Cangri
check all r connections or it could be the motor died...
i change the filter on my mirage and coincedaly the motor of my fan died the same day....
strange coincedance can happen
Originally Posted by Fryrice
One time I stuck my dick in my own butt by accident.
Dont laugh it was dark in the room.
Old July 21st, 2007, 10:10 PM   #4
Ok i connected the motor directly to the battery and it turned on no problem. so then i connected everything back and started up the engine and the fan would not turn on, so this time i disconnected the engine coolant temp sensor and outomatically the fan turned on at high speed. I dont know what could be wrong
i just left the coolant temp sensor off so the fan could always be working and my engine wont heat up.
Any ideas???
Old July 21st, 2007, 10:19 PM   #5
thisisme is on a distinguished road
Any ideas???
Just put an electric water pump on there and youll be alright
Old July 21st, 2007, 10:43 PM   #6
2000 Mustang V6
so... something is busted... when u disconnect the coolant temp sensor the fan will turn on so that way u dont heat up... u have a tuner? or have u mess up with the fan temp activation or w.e....
why would the problem would be corrected by a electric water pump if that not even the prob... its the fan not the pump...
Old July 22nd, 2007, 12:04 AM   #7
¡ʇsnq ɹo uʍop ǝpısdn
Onemanzu's Avatar
check the fuse and check for shorts.. mine shorted on me so that is a possibility
Old July 22nd, 2007, 12:32 AM   #8
im glad you caught that. I meant to say get a thermal kit. the thermal kit consists of an electric coolant pump, electric fan, electronic thermostat, optimized radiator and heat exchangers, along with a feedback control system. Though, if he's not going to be modding his car too much, he may not want to get one...
Old July 22nd, 2007, 02:58 AM   #9
I checked the Haynes book for wiring diagrams but there isn't one for the 3.8L, so i dont know what fuse or breaker goes to the fan.
WoA i never knew an electronic thermostat existed. All that sounds real neat but you are right I wont mod my car I just want to get that fixed.
Old July 22nd, 2007, 03:32 AM   #10
nope i dont have a tuner and have not messed with the computer.
wut do you think it is
Old July 22nd, 2007, 03:38 AM   #11
Billy Weston
C MY 4D's Avatar
2003 Cobra
11.14@124.36
iTrader: 8 reviews
check your relays on the drivers fenderwell.
TT Build in progress.......
Old July 22nd, 2007, 05:07 PM   #12
2000 Mustang V6
fuse relay w.e check all the fuse like C MY 4D wrote...
Old July 22nd, 2007, 07:58 PM   #13
the fuses are good, how do u check relays? thanx for the help
Old July 22nd, 2007, 09:41 PM   #14
2000 Mustang V6
i just change em.. for example u got the fan relay and a blinker fluid relay.. put the blinker fluid relay in the fan relay spot.. if its good well it will turn on meaning ur fan relay was bad...
Old July 22nd, 2007, 10:04 PM   #15
orale thanx I'm going to try it as soon as I get out of work.
Old July 24th, 2007, 03:14 PM   #16
ok i switched the relays and it didnt work
Old July 24th, 2007, 08:58 PM   #17
2000 Mustang V6
ok... so the fan just hates u
well men idk it could be some kind of short..... some mechanichs can check the volstages and things (at leas mine can) check for short then..
Old July 25th, 2007, 10:45 AM   #18
Juggalo_X's Avatar
2001 Mustang 232/CBR600
14+@Slow
the fan motor could be fucked its that simple. easiest way to check is to remove the fan and jump it to the battery if it spins you have a wiring issue.
Old July 25th, 2007, 11:37 AM   #19
CyberPrey is on a distinguished road
Change the coolant temp sensor?
Old July 25th, 2007, 11:41 AM   #20
Juggalo_X's Avatar
14+@Slow
if it was just the sensor then he wouldnt have been through 2 head gaskets. i have a feeling its a coolant blockage in the block or rad and or a tranny issue.
Threads Similar to: Cooling Fan wont turn on!
wont turn over skid6 5.0 Mustangs 5 November 4th, 2007 06:26 PM
HELP! Headlights Wont Turn Off GTVert00 Modular Mustangs 3 September 22nd, 2007 12:58 PM
Cooling fan wont turn on oasr87 Audio/Video 3 July 25th, 2007 10:32 AM
Cooling Fan Stangzilla 5.0 Mustangs 23 March 25th, 2007 10:15 AM
cooling zhunter V6 Mustangs 2 January 25th, 2006 06:18 PM
